Teamturtall Skrevet 6. november 2011 Del Skrevet 6. november 2011 (endret) Hei en av diskene røyk på serveren byttet den ut med en ny en og bootet opp serveren HP Smart Array P400 Controlleren skal bygge opp disken automatisk, men det gjør den ikke 776 (Ready for Recovery) Logical Drive 2 (683.5 GB, RAID 5) is queued for rebuilding. Slik står den bare helt til serveren går i lås, går en 5-10 timer Går det ann å bytte minnet på kontrolleren ? noen tips ? Array Accelerator Array Accelerator Present True Cache Status OK Cache Status Details A cache error was detected. Run a diagnostic report for more information. Array Accelerator (Cache) Ratio 0% Read / 100% Write Total Cache Size 512 MB Cache Backup Power Source Batteries Battery/Capacitor Pack Count 1 Battery/Capacitor Status OK Cache Failure Failed From Cache Data Loss Status --------------------------- ------------- False Informational Expand Failure Success (0x00) Unit Flags 0x00 Big Drive Failure Map All Zeroes (16 x [0x00]) Big Remap Count All Zeroes (128 x [0x0000]) Big Replacement Drive Map All Zeroes (16 x [0x00]) Big Active Spare Map All Zeroes (16 x [0x00]) Big Spare To Replace Map All Zeroes (128 x [0x00]) Big Replaced Marked OK Map All Zeroes (16 x [0x00]) Big Drive Rebuilding 0x00 Big Blocks Left To Recover 0x0000000000000000 Never Accessed LBA Zones Map 0xfe00 Unwritten LBA Zones Map 0xfe00 Source Resource Volume Flag 0x00 Replica State 0x00 Extended Drive Rebuilding 0x0000 Offset To Extended Drive Failure Map 0x041a Offset To Extended Replacement Drive Map 0x043a Offset To Extended Active Spare Map 0x045a Offset To Extended Replaced Marked OK Map 0x047a Offset To Extended Spare To Replace Map 0x049a Offset To Extended Remap Count 0x0698 Offset To Drive Rebuild Percentage 0x0896 Maximum Physical Devices Supported 255 (0x00ff) Total Structure Length 0x000009d5 Offset To Extended Redundant Path Failure Map 0x0995 Redundant Cabling Flags 0x00 Big Redundant Path Failure Map All Zeroes (16 x [0x00]) Fixed Structure Length 0x0000041a Extended Drive Failure Map All Zeroes (32 x [0x00]) Extended Replacement Drive Map All Zeroes (32 x [0x00]) Extended Active Spare Map All Zeroes (32 x [0x00]) Extended Replaced Marked OK Map All Zeroes (32 x [0x00]) Extended Spare To Replace Map All Zeroes (127 x [0x0000]) Extended Remap Count All Zeroes (127 x [0x0000]) Extended Redundant Path Failure Map All Zeroes (32 x [0x00]) ADUReport.txt Endret 6. november 2011 av Teamturtall Lenke til kommentar
conundrum Skrevet 6. november 2011 Del Skrevet 6. november 2011 "776 (Ready for Recovery)" er typisk en melding som kommer opp dersom kontrolleren må foreta rebuild av et array, men ikke kan begynne med dette før en annen operasjon er fullført. Utfra ADU-rapporten ser jeg at du har to arrays, et speilsett (RAID 1) og et RAID 5-sett, og at det er Array B som har problemer. Problemene ser ut til å være relatert til dette: - Kontrolleren har data i minnet (med batteri-backup) som den ikke får skrevet til diskene ("Dirty Cache Line Unable To Flush To Drives") - Du har muligens mer enn én defekt disk, siden du har feilmeldingen "Mark Bad Failed (0x05)" på diskene 1I:1:8 og 1I:1:6. Se hva BIOS-setup-verktøyet til kontrolleren sier om saken. Hvis ikke det der fremgår tydelig hva problemet er, bør du kontakte HP. Lenke til kommentar
Teamturtall Skrevet 6. november 2011 Forfatter Del Skrevet 6. november 2011 Hei takker for info BIOS-setup-verktøyet ligger det klart (hurtigtast) Eller er det et slags offline verktøy som man må boote fra en cd plate ? ikke vært borti dette før mvh kim Lenke til kommentar
conundrum Skrevet 6. november 2011 Del Skrevet 6. november 2011 (endret) Jada, Smart-kontrolleren kommer med en melding under oppstart, der du kan trykke en eller annen F-tast for å komme inn i et enkelt, menybasert oppsett. På nye servere er alle slike meldinger skjult bak en fancy HP-logo, men det kommer opp en melding som sier noe slikt som "press any key to see option ROM messages", og hvis du da trykker space eller noe, kommer du tilbake til vanlig tekstmodus og kan se meldingene. Endret 6. november 2011 av conundrum Lenke til kommentar
