[Løst] Hvordan installere Windows på en tom harddisk?
Jeg har kjøpt Windows 7 på nettet, lastet ned installasjonsfilene og intsallert den nye Windows på min bærbare PC. Jeg valgte alternativet hvor jeg sletter alt på datan, og sitter igjen med kun det nyinstallerte Windows.
Nå vil jeg bytte ut harddisken med en nyinnkjøpt 500GB SSD hybrid harddisk.
Kan jeg gjøre dette uten å måtte bruke penger på et program eller en kabel som kloner harddisken? Hvordan installerer jeg Windows på en helt blank harddisk?
Hva skjer når jeg trykker på på-knappen på datan etter å ha satt inn en helt blank harddisk direkte fra butikken..??
Endret av ChrisAndre
Den siden gir meg ikke svar... :-/ Det står bare:
Installing and reinstalling Windows 7
There are two options to choose from during the Windows 7 installation process:
Upgrade. This option replaces your current version of Windows with Windows 7, and keeps your files, settings, and programs in place on your computer.
Custom. This option replaces your current version of Windows with Windows 7, but doesn't preserve your files, settings, and programs. It's sometimes referred to as a clean installation for that reason.
In this article you'll find detailed instructions for installing Windows 7 and reinstalling Windows 7.
For more information about installing Windows 7, see Installing Windows 7: frequently asked questions and Windows 7 installation problems: frequently asked questions. For more information about upgrade options, go to Upgrading to Windows 7: frequently asked questions on the Windows website.
Show all
How to buy Windows 7
Common ways to install Windows 7
Before you begin installing Windows 7
Using the Upgrade installation option
Using the Custom installation option without formatting the hard disk
Using the Custom installation option and formatting the hard disk
Using the Custom installation option if no operating system is installed
Installing a 64-bit version of Windows 7 on a computer running a 32-bit version of Windows
Reinstalling Windows 7
Activating Windows 7
Was this helpful?
Og ingenting skjer når jeg prøver å trykke på "Using the Custom installation option if no operating system is installed"... Den samme siden bare laster på nytt...
Har du fortsatt installasjonsfilene fra forrige installering? Da kan du bare lage en .iso fil av dem og brenne ut på cd og kjøre clean install på den nye harddisken.
Hvis ikke, får du bare laste ned det på nytt og brenne over på CD og installere derfra. Enklere blir det ikke.
Det hørtes ganske enkelt ut, men jeg vet ikke hvordan man lager .iso-fil.
Jeg må laste ned installasjonsfilene på nytt, da de forsvant under installasjonen, men det er jo en smal sak. Så når jeg har de tre filene, hva gjør jeg med dem for å brenne dem som en .iso-fil?
Vent, når jeg nå skal laste ned filene igjen, ser jeg at det er følgende alternativer: 32-biters, 64-biters, 32-biters ISO og 64-biters ISO.
Hvis jeg bare laster ned den 64-biters ISO, kan jeg bare brenne filen(e) som lastes ned direkte på en CD på vanlig vis, og voilà?
Bør være det ja. Dog du trenger en DVD da det ikke er plass på cd.
Husk og at .ISO-filen er et DVD-image. Altså du skal ikke legge ISO-filen på DVD'en. Men åpne den i et brenneprogram og brenne sånn. (Du skal ende opp med endel filer på dvd'en.) Ikke pakk ut filene med et pakkeprogram som winrar el. Da får du ikke med boot sectoren.
Personlig foretrekker jeg å gjøre det via USB.
http://www.teknofil.no/artikler/slik_installerer_du_windows_7_fra_usb/87228
Endret av kule-ku
Ikke glem at Windows 7 har innebygd ISO brenning .
Så om man skal "brenne" ISO fil til DVD på en PC som kjører Win 7 trenger man ikke noe 3'parts program.
Trykk Win7 start meny/knapp og skriv isoburn i søkefeltet.
(isoburn.exe ligger førøvrig i C:\Windows\system32 mappen)
Enkleste er å høyreklikke på ISO filen - velge - Åpne med .. - Windows Disk Image Burner
Endret av syar2003
Dersom du har kjøpt en oppgraderingsversjon av Windows, så krever den i utgangspunktet at det er installert en tidligere versjon av Windows på harddisken. Det finnes dog en "fix" for dette dersom du har en blank harddisk.
Er det en fullversjon går du rett på installasjon, men du må først ha foretatt en backup av alle viktige filer.
Dersom du har behov for å ta en sikkerhetskopi av brukerprofil, brukerdata osv., så kan jeg anbefale Windows Easy Transfer.
Endret av Nuffern
