Armitage2 Skrevet 25. oktober 2011 Rapporter Del Skrevet 25. oktober 2011 Usikker på om dette er blitt postet i tråden før, men fra BF3 forum kommer dette: Subject: ***Must Read*** How to fix LOCKUP/FREEZE... ok so I was having the dreaded lockup and freeze issues that a few(ok alot) of people were having. I took the liberty of researching and doing various diagnostic tests. I'll share what I did to fix my freeze/lockup issue, I had in singleplayer and multiplayer. This could be caused by couple things but If you follow all these steps, I believe alot of you can resolve this same problem. Step 1: make sure you are out of BF3 and Origin. Uninstall Punkbuster Services from the Add/Remove programs through control panel Step 2: Update your graphics card to the newest drivers possible or the most stable. (I did the newest) Step 3: Restart PC Step 4: Make sure you do not adjust any special gaming settings(AA settings AF settings ect) in ur catalyst or nvidia control panel. Leave all your settings default Step 5: Log back into origin and when it loads up, Right click on your battlefield game and click update. If your fully up to date then you need to click repair so origin can now reinstall punkbuster. Side Notes: Disable any antivirus or antispyware programs especially those that run in the background. If you still getting issues last thing to check is in battlefield video settings. Adjust the Anisotropic value to 8x or below once that is all done test the game out and hopefully you now have a working non-frozen battlefield. Har ikke prøvd selv da, siden jeg ikke har fått spillet enda, men kanskje noen har allerede prøvd? 1 Lenke til kommentar
værdama Skrevet 25. oktober 2011 Rapporter Del Skrevet 25. oktober 2011 (endret) Usikker på om dette er blitt postet i tråden før, men fra BF3 forum kommer dette: Subject: ***Must Read*** How to fix LOCKUP/FREEZE... ok so I was having the dreaded lockup and freeze issues that a few(ok alot) of people were having. I took the liberty of researching and doing various diagnostic tests. I'll share what I did to fix my freeze/lockup issue, I had in singleplayer and multiplayer. This could be caused by couple things but If you follow all these steps, I believe alot of you can resolve this same problem. Step 1: make sure you are out of BF3 and Origin. Uninstall Punkbuster Services from the Add/Remove programs through control panel Step 2: Update your graphics card to the newest drivers possible or the most stable. (I did the newest) Step 3: Restart PC Step 4: Make sure you do not adjust any special gaming settings(AA settings AF settings ect) in ur catalyst or nvidia control panel. Leave all your settings default Step 5: Log back into origin and when it loads up, Right click on your battlefield game and click update. If your fully up to date then you need to click repair so origin can now reinstall punkbuster. Side Notes: Disable any antivirus or antispyware programs especially those that run in the background. If you still getting issues last thing to check is in battlefield video settings. Adjust the Anisotropic value to 8x or below once that is all done test the game out and hopefully you now have a working non-frozen battlefield. Har ikke prøvd selv da, siden jeg ikke har fått spillet enda, men kanskje noen har allerede prøvd? Jeg er godt igang med å prøve dette nå, holder på og repaire.. kommer tilbake med tilbakemelding snarest.. Setter pris på informasjonen=) Edit: fungerte ikke for meg. skal ta en test til hvor jeg skrur av AA. Endret 25. oktober 2011 av værdama Lenke til kommentar
herzeleid Skrevet 25. oktober 2011 Rapporter Del Skrevet 25. oktober 2011 Har tenkt a bestille folgende laptop: http://www.multicom.no/main/SystemConfigurator.aspx?q=st:10600327;c:100561;fl:0#2185-10600332-1;2186-4206736-1;2190-10501975-1;2321-3754188-1;2191-10582288-1;2193-10500502-1;2456-10607588-1;2187-10606016-4;2189-10606373-1;2188-10571620-1 Hvordan tror dere den vil takle BF3. Har dere eventuelt noe tilbakemeldinger til kjopet, noe som burde endres. Far forovrig 28% rabatt sa ender fort pa en 13000 for vidunderet. Setter pris pa all input Lenke til kommentar
Armitage2 Skrevet 25. oktober 2011 Rapporter Del Skrevet 25. oktober 2011 Ja, uansett ville jeg nok ikke følge rådet om å slå av Antivirus..det i seg selv er jo vågalt.. Lenke til kommentar
værdama Skrevet 25. oktober 2011 Rapporter Del Skrevet 25. oktober 2011 Ja, uansett ville jeg nok ikke følge rådet om å slå av Antivirus..det i seg selv er jo vågalt.. Har fortsatt crashes etter kort tid med spilling. helt på trynet at de ikke har klart og fikse dette _før_ release. Lenke til kommentar
jihn Skrevet 25. oktober 2011 Rapporter Del Skrevet 25. oktober 2011 For dere/oss med problemer med negative mouse acc. The beta felt fine in regards to mouse responsiveness, now it feels disgusting, please change it back. Here is a temporary fix until DICE does something: how to fix the negative mouse accel issue: 1. go here: C:\Users\YOU\Documents\Battlefield 3\settings 2. Open PROF_SAVE_profile with notepad++ (can download for free) 3. Change the following variables: GstInput.MouseSensitivity 0.050000 ;1st one is the normal mouse sens. USE whatever you like, or keep it the way it is. These two however I edited and it solved many problems for me. GstInput.Scheme0Sensitivity 0.000000 GstInput.Scheme1Sensitivity 0.000000 GstInput.Scheme2Sensitivity 0.000000 Always make a Back up or remember the original values folks! http://forums.electronicarts.co.uk/battlefield-3/1444629-remove-negative-accel-mouse.html Lenke til kommentar
Multiverktøy Skrevet 25. oktober 2011 Rapporter Del Skrevet 25. oktober 2011 Har tenkt a bestille folgende laptop: http://www.multicom.no/main/SystemConfigurator.aspx?q=st:10600327;c:100561;fl:0#2185-10600332-1;2186-4206736-1;2190-10501975-1;2321-3754188-1;2191-10582288-1;2193-10500502-1;2456-10607588-1;2187-10606016-4;2189-10606373-1;2188-10571620-1 Hvordan tror dere den vil takle BF3. Har dere eventuelt noe tilbakemeldinger til kjopet, noe som burde endres. Far forovrig 28% rabatt sa ender fort pa en 13000 for vidunderet. Setter pris pa all input dan burde klare bf3 på en blanding av high-ultra Lenke til kommentar
N o r e n g Skrevet 25. oktober 2011 Rapporter Del Skrevet 25. oktober 2011 (endret) Har tenkt a bestille folgende laptop: http://www.multicom.no/main/SystemConfigurator.aspx?q=st:10600327;c:100561;fl:0#2185-10600332-1;2186-4206736-1;2190-10501975-1;2321-3754188-1;2191-10582288-1;2193-10500502-1;2456-10607588-1;2187-10606016-4;2189-10606373-1;2188-10571620-1 Hvordan tror dere den vil takle BF3. Har dere eventuelt noe tilbakemeldinger til kjopet, noe som burde endres. Far forovrig 28% rabatt sa ender fort pa en 13000 for vidunderet. Setter pris pa all input Istedet for å kaste bort 1300 kr på 1600MHz og 8GB ekstra minne, hadde jeg holdt meg til 8GB 1333MHz, du taper ca 1-2% ytelse av dette. GTX 580M er så overpriset at det er stygt, 6990M yter godt og vel 95-105% så bra og koster også betydelig mindre. For ikke å nevne at 6990M spiser mindre strøm. EDIT: Hvor god grafikk du vil få blir avhengig av dine krav til fps. Medium vil jeg tippe sånn ca uansett om du har 6990M eller 580M for å få 60fps stabilt, men jeg har ofte høyere krav enn majoriteten. Med de innsparte pengene kjøper du en 320M 160GB SSD og en 500GB 7200RPM-HDD. Da får du en langt mer balansert workstation til lavere pris med bedre brukeropplevelse. EDIT2: GTX 580M og 6990M gir tilsvarende ytelse mot skrivebordskort i rundt 1000-1200kr. http://www.notebookcheck.net/Computer-Games-on-Laptop-Graphic-Cards.13849.0.html Endret 25. oktober 2011 av arni90 2 Lenke til kommentar
anonym11114 Skrevet 25. oktober 2011 Rapporter Del Skrevet 25. oktober 2011 (endret) Jeg hadde ikke muligheten til å teste betaen men jeg har forhåndsbestilt BF3. Jeg er dog i tvil om jeg kommer til å kunne klare å kjøre det ordentlig. Tror dere jeg kommer til å klare å kjøre det? Operating System MS Windows 7 32-bit SP1 CPU Intel Core 2 Duo E8400 @ 3.00GHz Wolfdale 45nm Technology RAM 4,00 GB Dual-Channel DDR2 @ 400MHz (5-5-5-31) Motherboard ASUSTeK Computer INC. P5N-D (Socket 775) Graphics VW225 (1680x1050@59Hz) 896MB GeForce GTX 260 (XFX Pine Group) Endret 25. oktober 2011 av Joikamed Lenke til kommentar
værdama Skrevet 25. oktober 2011 Rapporter Del Skrevet 25. oktober 2011 (endret) Fikk nettopp overstått min første bf3 runde på ultra med OK fps. Måtte installere de eldre beta driveren for at det skulle fungere=) Edit: fungerte bare på kharg island.. typisk Endret 25. oktober 2011 av værdama Lenke til kommentar
N o r e n g Skrevet 25. oktober 2011 Rapporter Del Skrevet 25. oktober 2011 Jeg hadde ikke muligheten til å teste betaen men jeg har forhåndsbestilt BF3. Jeg er dog i tvil om jeg kommer til å kunne klare å kjøre det ordentlig. Tror dere jeg kommer til å klare å kjøre det? Operating System MS Windows 7 32-bit SP1 CPU Intel Core 2 Duo E8400 @ 3.00GHz Wolfdale 45nm Technology RAM 4,00 GB Dual-Channel DDR2 @ 400MHz (5-5-5-31) Motherboard ASUSTeK Computer INC. P5N-D (Socket 775) Graphics VW225 (1680x1050@59Hz) 896MB GeForce GTX 260 (XFX Pine Group) Du passerer minimumskravet på prosessor og skjermkort med ca 50% Vil det kjøre bra? Mest sannsynlig vil du oppnå ~50 fps på 1280x720 og low Lenke til kommentar
dTd Skrevet 25. oktober 2011 Rapporter Del Skrevet 25. oktober 2011 Bleh, kjører alt på low for å ha en tilfredstillende fps på min maskin... (70-80+, laveste var vel nede på 70 ish)... Har følgende maskinvare: Xfx 6870 Phenom x II 965 BE 6 gb croshair dominator DHX+ 1600mhz @1680x1050 noe som er litt skuffende, men spillet ser imo helt ok ut for det Lenke til kommentar
herzeleid Skrevet 25. oktober 2011 Rapporter Del Skrevet 25. oktober 2011 Har tenkt a bestille folgende laptop: http://www.multicom.no/main/SystemConfigurator.aspx?q=st:10600327;c:100561;fl:0#2185-10600332-1;2186-4206736-1;2190-10501975-1;2321-3754188-1;2191-10582288-1;2193-10500502-1;2456-10607588-1;2187-10606016-4;2189-10606373-1;2188-10571620-1 Hvordan tror dere den vil takle BF3. Har dere eventuelt noe tilbakemeldinger til kjopet, noe som burde endres. Far forovrig 28% rabatt sa ender fort pa en 13000 for vidunderet. Setter pris pa all input Istedet for å kaste bort 1300 kr på 1600MHz og 8GB ekstra minne, hadde jeg holdt meg til 8GB 1333MHz, du taper ca 1-2% ytelse av dette. GTX 580M er så overpriset at det er stygt, 6990M yter godt og vel 95-105% så bra og koster også betydelig mindre. For ikke å nevne at 6990M spiser mindre strøm. EDIT: Hvor god grafikk du vil få blir avhengig av dine krav til fps. Medium vil jeg tippe sånn ca uansett om du har 6990M eller 580M for å få 60fps stabilt, men jeg har ofte høyere krav enn majoriteten. Med de innsparte pengene kjøper du en 320M 160GB SSD og en 500GB 7200RPM-HDD. Da får du en langt mer balansert workstation til lavere pris med bedre brukeropplevelse. EDIT2: GTX 580M og 6990M gir tilsvarende ytelse mot skrivebordskort i rundt 1000-1200kr. http://www.notebookcheck.net/Computer-Games-on-Laptop-Graphic-Cards.13849.0.html Forstar jeg det riktig om 6990 presterer like bra som 580? Hva er fordelene med den andre typen hardisk? Lenke til kommentar
greenman Skrevet 25. oktober 2011 Rapporter Del Skrevet 25. oktober 2011 Det er vel en del av dere som har spillt litt allerede. Noen av dere som har lik hardware som meg og kan si hvilken fps dere fikk? Se signatur for deler. Lenke til kommentar
N o r e n g Skrevet 25. oktober 2011 Rapporter Del Skrevet 25. oktober 2011 Har tenkt a bestille folgende laptop: http://www.multicom.no/main/SystemConfigurator.aspx?q=st:10600327;c:100561;fl:0#2185-10600332-1;2186-4206736-1;2190-10501975-1;2321-3754188-1;2191-10582288-1;2193-10500502-1;2456-10607588-1;2187-10606016-4;2189-10606373-1;2188-10571620-1 Hvordan tror dere den vil takle BF3. Har dere eventuelt noe tilbakemeldinger til kjopet, noe som burde endres. Far forovrig 28% rabatt sa ender fort pa en 13000 for vidunderet. Setter pris pa all input Istedet for å kaste bort 1300 kr på 1600MHz og 8GB ekstra minne, hadde jeg holdt meg til 8GB 1333MHz, du taper ca 1-2% ytelse av dette. GTX 580M er så overpriset at det er stygt, 6990M yter godt og vel 95-105% så bra og koster også betydelig mindre. For ikke å nevne at 6990M spiser mindre strøm. EDIT: Hvor god grafikk du vil få blir avhengig av dine krav til fps. Medium vil jeg tippe sånn ca uansett om du har 6990M eller 580M for å få 60fps stabilt, men jeg har ofte høyere krav enn majoriteten. Med de innsparte pengene kjøper du en 320M 160GB SSD og en 500GB 7200RPM-HDD. Da får du en langt mer balansert workstation til lavere pris med bedre brukeropplevelse. EDIT2: GTX 580M og 6990M gir tilsvarende ytelse mot skrivebordskort i rundt 1000-1200kr. http://www.notebookcheck.net/Computer-Games-on-Laptop-Graphic-Cards.13849.0.html Forstar jeg det riktig om 6990 presterer like bra som 580? Hva er fordelene med den andre typen hardisk? 6990M og 580M er ganske like i ytelse ja. SSD er ca 100 ganger raskere under vanlig bruk av datamaskinen, og gir deg den største oppgraderingen for pengene på lang vei. Årsakene er mange, men kort oppsummert er det to grunner: Tilgangstider på en brøkdel av tiden en tradisjonell snurredisk bruker. Ca 100 ganger raskere lesing av 4kB-filer. Min laptop med en i3-380M og 3GB RAM er raskere enn 90% av alle laptoper til surfing og kontorarbeid, og det er kun fordi den har en SSD. Lenke til kommentar
Nizzen Skrevet 25. oktober 2011 Rapporter Del Skrevet 25. oktober 2011 Ja, uansett ville jeg nok ikke følge rådet om å slå av Antivirus..det i seg selv er jo vågalt.. Antivirus er for noobs 1 Lenke til kommentar
RoXx Skrevet 26. oktober 2011 Rapporter Del Skrevet 26. oktober 2011 Har tenkt a bestille folgende laptop: http://www.multicom.no/main/SystemConfigurator.aspx?q=st:10600327;c:100561;fl:0#2185-10600332-1;2186-4206736-1;2190-10501975-1;2321-3754188-1;2191-10582288-1;2193-10500502-1;2456-10607588-1;2187-10606016-4;2189-10606373-1;2188-10571620-1 Hvordan tror dere den vil takle BF3. Har dere eventuelt noe tilbakemeldinger til kjopet, noe som burde endres. Far forovrig 28% rabatt sa ender fort pa en 13000 for vidunderet. Setter pris pa all input Kommer til å kjøre BF3 glatt på ultra:) Lenke til kommentar
Skjelvgråt Skrevet 26. oktober 2011 Rapporter Del Skrevet 26. oktober 2011 g har i SP på alt på høyt, ultra på textures. 16xAA, og sånne ting på. Laveste jeg lå hitill enda masse action skjer var 49-51 fps. Elllers opp til 60-70. Og i den jagerfly-scenen 80+ Med alt på ultra ligger jeg ca 41-49 ++ ca. Så, vil jeg klare mp greit da tro med samme instillinger tro? Krever egentlig spillet spesielt i det hele tatt? F.eks slik som kompis sin 2-3 år gamle laptop kan ta det flytende på medium-high. Han klarte ca mediun i betaen så. Lenke til kommentar
Merk. Skrevet 26. oktober 2011 Rapporter Del Skrevet 26. oktober 2011 (endret) Noen som vet om den fullstendige versjonen er mer optimalisert enn betaen? Hadde mindre enn akseptabel fps ( like under 30), og gidder ikke å investere i spillet om det ikke blir bedre. Komponentene mine er: Nvidia GeForce GTX 560 4GB RAM Intel E8400 3.0 GHz Flaskehalsen er nok CPU-en, som jeg forsåvidt kan klokke til 3.6 GHz. Kommer det til å hjelpe på bildehastigheten? Om ikke kommer jeg vel til å punge ut for en i5 2500 i en nær framtid. Endret 26. oktober 2011 av Merk. Lenke til kommentar
Hyd Skrevet 26. oktober 2011 Rapporter Del Skrevet 26. oktober 2011 (endret) Noen som vet om den fullstendige versjonen er mer optimalisert enn betaen? Hadde mindre enn akseptabel fps ( like under 30), og gidder ikke å investere i spillet om det ikke blir bedre. Komponentene mine er: Nvidia GeForce GTX 560 4GB RAM Intel E8400 3.0 GHz Flaskehalsen er nok CPU-en, som jeg forsåvidt kan klokke til 3.6 GHz. Kommer det til å hjelpe på bildehastigheten? Om ikke kommer jeg vel til å punge ut for en i5 2500 i en nær framtid. Jeg kan garantere deg at det er CPU'en som er problemet. Jeg har en I7 2600K og har ingen problemer i det hele tatt. Har et Asus GTX560TI. 2500K og 2600K er jo helt identiske omtrent når det kommer til spillyttelse så gå for 2500K du Edit: Jeg vil jo samtidig innrømme at ikke alt går smooth på Ultra. Må ned på medium/high i 1920x1080 for å få en okei fps. Skal nok ha meg et nytt skjermkort da jeg er glad i fps. Endret 26. oktober 2011 av Hyd Lenke til kommentar
