Hardware/Teknisk til Battlefield 3
Synd at nyeste high-end skjermkortene fra ATI ikke kommer før første kvartal i 2012...
Da blir det vel ikke ultra instillinger i julaften, tviler veldig på at 6950 2gb som jeg har klarer alt med AA og 1920x1200 oppløsning...
EDIT: Kanskje 6950 crossfire vil redde julaften ? Vi får vente å se :thumbup:
Endret av Iceman22
Jeg jeg fant fra diverse nettsteder som har postet informasjon fra Dice:
If you?re sitting smugly back in your chair glancing at your best-money-can-buy GTX580, you may want to sit up for this. Matros has said that actually, you?ll be needing two of those. Two. To put that in perspective, a single GTX 580 right now is going to cost you around R5000.
The fact is, there are very few people who will be able to enjoy Battlefield 3 to its full capabilities, but that shouldn?t deter you. Even at medium, the game will most likely be very pretty, and gameplay should always trump graphics.
Noe mer:
However, if you want to play the game in all its glory, as shown in the breathtaking gameplay videos that have been released, then you might want to start thinking about upgrading if your PC doesn't meet the recommended specs.
Fra enterbf3.com:
However, developers have been spotted stating that two of the ultra-high end nvidia GTX 580 cards would be required. Another developer has said that they (DICE) commonly uses two ATI 6970 video cards for game development. Whatever the final 'ultra' requirements for Battlefield 3 entails will be very expensive, yet very powerful. If you're still not even sure if your computer will even run the game at all, then please check out this awesome tool: www.systemrequirementslab.com/cyri/ (make sure to select "Battlefield 3" from the dropdown)
Dette ser ikke bra ut for meg ihvertfall!
Det er jo bare fordi at den leser spesifikasjonene dine og måler mot anbefalte specs.
Så hvis du har et bedre kort klarer den ikke alltid å se dette her, da det sikkert er noe annet enn det som står anbefalt.
Ellers så kan dere prøve ut denne game-o-meter.
Endret av Lami
Nei, ekke sjalu. Jeg synes bare ultra og enkelte settings er generelt unødvendig, og ting en egentlig ikke bryr seg så mye om uansett - eller legger godt merke til om en ikke ser veldig godt etter.
Er jo blitt sakt nå at recommended = high settings ( har ikke lest siste postene her :p)
Så da lurer jeg litt på hvilken res han fyren som sa du må ha SLI Gtx580 spiller på :p
Sikkert jævelhøy oppløsning med 16xaa og sånne tulle ting.
