reneraymond Skrevet 20. oktober 2011 Del Skrevet 20. oktober 2011 Jeg har bestilt komponenter til en ny pc som skal brukes hovedsakelig til gaming. Har relativt lite erfaring med gaming pc'er.. Er det noe mer jeg trenger? Mer kjøling eller lignende..? Planen er å spille Battlefield 3 Amentio: - Hovedkort: ASUS Mainboard S-1155 P67 ATX 3xPCI-E Audio7.1 GbLAN 1394 SATA3 USB3.0 Raid DDR3 BT2.1 CrossfireX/ SLI B3-step (P8P67 PRO B3) http://www.amentio.no/Mainboard-S-1155-P67-ATX-3xPCI-E-Audio71-GbLAN-1394-SATA3-USB30-Raid-DDR3-BT21-CrossfireX-SLI-B3-step-ASUS/cat-p/c/p3804594.html 1 074,- - Prosessor: INTEL Core™ i5 Quad Processor i5-2500K 3, 3GHz, Socket LGA1155, 6MB, Boxed (BX80623I52500K) http://www.amentio.no/Core™-i5-Quad-Processor-i5-2500K3,3GHz,-Socket-LGA1155,-6MB,-Boxed-INTEL/cat-p/c/p3663574.html 1 574,- - Minne: CORSAIR 8GB Kit DDR3 Dominato PC3-12800, 1600MHz, 2x240 DIMM (CMP8GX3M2A1600C9) http://www.amentio.no/8GB-Kit-DDR3-Dominato-PC3-12800,-1600MHz,-2x240-DIMM-CORSAIR/cat-p/c/p3197925.html 697,- - Skjermkort: GIGABYTE GeForce GTX 580 1536MB PhysX PCI-Express 2.0, "Super Overclock", GDDR5, 2xDVI, HDMI, "Windforce 3X", 855MHz (GV-N580SO-15I) http://www.amentio.no/GeForce-GTX-580-1536MB-PhysXPCI-Express-20,-Super-Overclock,-GDDR5,-2xDVI,-HDMI,Windforce-3X,-855MHz-GIGABYTE/cat-p/c/p3977989.html 3 820,- - CD/DVD: SONY OPTIARC Sony Optiarc DVD±RW Burner, AD-7280S SATA, DVD±R: 24x, DVD+RW, DVD-RAM, Bulk, BLACK (AD-7280S-0B) 184,- - PSU COOLERMASTER Cm Silent Pro 700W (RS-700-AMBAD3-EU) http://www.amentio.no/Cm-Silent-Pro-700W-COOLERMASTER/cat-p/c/p2033166.html 835,- - Harddisk: SEAGATE Barracuda7200.12 1TB HDD SATA (ST31000524AS) http://www.amentio.no/Barracuda720012-1TB-HDD-SATA-SEAGATE/cat-p/c/p3689459.html 441,- Mobilestore: - Kabinett: CORSAIR Obsidian 650D Midi Tower Sort Vifter: 1x 200mm Front, 1x 200mm Topp, 1x Bak 120mm, ATX, mATX (CC650DW-1) http://www.mobilestore.no/PartDetail.aspx?q=p:3929307 1 428,- Sum 10 302,- Takker for svar Lenke til kommentar
stinger82 Skrevet 20. oktober 2011 Del Skrevet 20. oktober 2011 Ville gått for dette hovedkortet Denne rammen Og denne strømforsyningen Dette er til og med litt billigere enn hva du hadde satt opp:) Stinger Lenke til kommentar
reneraymond Skrevet 24. oktober 2011 Forfatter Del Skrevet 24. oktober 2011 Takker Jeg valgte ram og hovedkortet du anbefalte, men gikk for denne PSU'en Så har jeg nok power når jeg må ha sli Lenke til kommentar
emiven Skrevet 24. oktober 2011 Del Skrevet 24. oktober 2011 850w er mere en nok for to 580'ere Lenke til kommentar
ragnarocc Skrevet 24. oktober 2011 Del Skrevet 24. oktober 2011 750" kan vell til og med nesten gå til to 580. 1200 er ihvertfall monster overkill. Lenke til kommentar
reneraymond Skrevet 25. oktober 2011 Forfatter Del Skrevet 25. oktober 2011 Grafikk kortet krever jo minimum 750W... Men det kan vel ikke skade noen andre komponenter i pc'en å ha for stor psu? Lenke til kommentar
stinger82 Skrevet 25. oktober 2011 Del Skrevet 25. oktober 2011 Neida, gjør ikke noe og ha noen ekstra watt og gå på. HER Kan du regne ut hvor mye kraft du egentlig trenger. Kommer langt med 750W om du ikke har tusen andre ting i pc'n. Kos deg med den nye maskinen din Stinger Lenke til kommentar
emiven Skrevet 25. oktober 2011 Del Skrevet 25. oktober 2011 (endret) Grafikk kortet krever jo minimum 750W... Men det kan vel ikke skade noen andre komponenter i pc'en å ha for stor psu? det er tull og tøys, på nvidias side, sier de at det er minimum 600w, det betyr ikke at et 580 drar 600w, men at hele systemet vil trenge det. 850w er mere en nok for to 580ere http://www.dustinhome.no/corsair-hx-850w-atx12v-23-eps12v/product/5010314589 Og btw, bf3 kom ut i utlandet i går, og en fyr kjørte det med ALT på ultra inkludert AA, med en 570 http://www.youtube.com/watch?v=4EGkx3Rrsfw EDIT: spol til 3:05, så ser du at 850w er nok Endret 25. oktober 2011 av emiven Lenke til kommentar
