Sliter med mye bluescreen
Hei
Som overskriften sier så sliter jeg endel med bluescreen. Re-innstalerte windows 7 idag for å se om det hjalp, men det gjorde det ikke. Kjørte Windows Update en liten stund så kom plutselig den blå skjermen :dontgetit:
Legger ved minidump fi:
MODULE_NAME: Ntfs
FAULTING_MODULE: fffff80002e1f000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 4a5bc14f
EXCEPTION_RECORD: fffff88008391348 -- (.exr 0xfffff88008391348)
ExceptionAddress: fffff80002e8785e (nt+0x000000000006885e)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
CONTEXT: fffff88008390ba0 -- (.cxr 0xfffff88008390ba0)
rax=0000000000000702 rbx=7ffffa8009a61908 rcx=7ffffa8009a61908
rdx=fffff8a0137a0301 rsi=fffff88008391700 rdi=fffff88002f64180
rip=fffff80002e8785e rsp=fffff88008391580 rbp=0000000000000000
r8=0000000000000000 r9=fffffa8007d45180 r10=0000000000000004
r11=fffff880083916c8 r12=fffffa800a6be580 r13=fffffa800b04bfb0
r14=0000000000000001 r15=fffffa800a925c20
iopl=0 nv up di pl zr na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010046
nt+0x6885e:
fffff800`02e8785e f0480fba696000 lock bts qword ptr [rcx+60h],0 ds:002b:7ffffa80`09a61968=????????????????
Resetting default scope
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x24
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from fffffa8007a1f2c0 to fffff80002e8785e
STACK_TEXT:
fffff880`08390368 fffff880`0127a3d8 : 00000000`00000024 00000000`001904fb fffff880`08391348 fffff880`08390ba0 : nt+0x71f00
fffff880`08390370 00000000`00000024 : 00000000`001904fb fffff880`08391348 fffff880`08390ba0 fffff800`02e8785e : Ntfs+0x213d8
fffff880`08390378 00000000`001904fb : fffff880`08391348 fffff880`08390ba0 fffff800`02e8785e fffff8a0`00212620 : 0x24
fffff880`08390380 fffff880`08391348 : fffff880`08390ba0 fffff800`02e8785e fffff8a0`00212620 00000000`00000000 : 0x1904fb
fffff880`08390388 fffff880`08390ba0 : fffff800`02e8785e fffff8a0`00212620 00000000`00000000 fffff880`0134f45b : 0xfffff880`08391348
fffff880`08390390 fffff800`02e8785e : fffff8a0`00212620 00000000`00000000 fffff880`0134f45b fffff880`012aa56c : 0xfffff880`08390ba0
fffff880`08390398 fffff8a0`00212620 : 00000000`00000000 fffff880`0134f45b fffff880`012aa56c fffff880`083916d0 : nt+0x6885e
fffff880`083903a0 00000000`00000000 : fffff880`0134f45b fffff880`012aa56c fffff880`083916d0 fffff880`083916d0 : 0xfffff8a0`00212620
STACK_COMMAND: kb
FOLLOWUP_IP:
Ntfs+213d8
fffff880`0127a3d8 ?? ???
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: Ntfs+213d8
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: Ntfs.sys
BUCKET_ID: WRONG_SYMBOLS
Followup: MachineOwner
Fikk også lest feil koden:
0x0000001A (0X0000000000041284, 0X0000000014E4D001, 0X0000000000008DF, 0XFFFFF70001080000)
Har altså ikke peil på hva jeg skal, så hvis noen hadde giddet å hjelpe så hadde det vært fint :-)
Edit: legger ved pc specs
Edit 2: virker som om det er bare når jeg kjører win update egentlig, har ikke oppdatert BIOS siden jeg ikke har peil på hvordan.
Specs:
intel core i5 2500k
ASUS P8P67 pro (brukte program som fulgte med til å overklokke)
ASUS gtx 560 TI
Corsair xms3 ram, har fylt opp alle 4 slots med brikker 2gb på hver brikke.
Corsair HX 650W
Samsung spinpoint f3 iTB
Endret av Ownbeef
Reset BIOS settings til fabrikk instilinger antar jeg. :-)
Dette hjalp ikke, lasta ned ett spill på steam og bare var på facebook osv så fikk jeg plutselig bluescreen igjen. Har nå oppdatert, reset bios og fjerna overclocken.
Peil på hva jeg kan gjøre nå?
edit: ser i hendelseliste at Kernel-power 41 står på kritisk feil, har prøvd å google dette men finner ikke ut noe spesielt
Endret av Ownbeef
