Prosessor og Skjermdriver fungerer ikke som før!
Hei, pcen min fungerer ikke som den en gang gjorde, den har blitt mye tregere og nå klarer den ikke en gang å starte minecraft: Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 03.10.11 16:38
Minecraft: Minecraft Beta 1.8.1
OS: Windows 7 (amd64) version 6.1
Java: 1.6.0_20, Sun Microsystems Inc.
VM: Java HotSpot 64-Bit Server VM (mixed mode), Sun Microsystems Inc.
LWJGL: 2.4.2
[failed to get system properties (java.lang.NullPointerException)]
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:185)
at org.lwjgl.opengl.Display.createWindow(Display.java:311)
at org.lwjgl.opengl.Display.create(Display.java:856)
at org.lwjgl.opengl.Display.create(Display.java:784)
at org.lwjgl.opengl.Display.create(Display.java:765)
at net.minecraft.client.Minecraft.a(SourceFile:233)
at net.minecraft.client.Minecraft.run(SourceFile:629)
at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT 13a55b2f ----------
Specsa mine er dette:
System Information
Time of this report: 10/3/2011, 16:53:25
Machine name: MATHIAS-PC
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.110622-1506)
Language: Norwegian (Bokmål) (Regional Setting: Norwegian (Bokmål))
System Manufacturer: Alienware
System Model: M15x
BIOS: Ver A08 1.00
Processor: Intel® Core i7 CPU Q 740 @ 1.73GHz (8 CPUs), ~1.7GHz
Memory: 4096MB RAM
Available OS Memory: 4084MB RAM
Page File: 2359MB used, 5807MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name:
Manufacturer:
Chip type:
DAC type:
Device Key: Enum\
Display Memory:
Dedicated Memory: n/a
Shared Memory: n/a
Current Mode: 1152 x 864 (32 bit) (1Hz)
Driver Name:
Driver File Version: ()
Driver Version:
DDI Version:
Driver Model: ukjent
Driver Attributes: Final Retail
Driver Date/Size: , 0 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B70EE0-4340-11CF-B123-B03DAEC2CB35}
Vendor ID: 0x0000
Device ID: 0x0000
SubSys ID: 0x00000000
Revision ID: 0x0000
Driver Strong Name: Unknown
Rank Of Driver: Unknown
Video Accel:
Deinterlace Caps: n/a
D3D9 Overlay: n/a
DXVA-HD: n/a
DDraw Status: Enabled
D3D Status: Not Available
AGP Status: Enabled
Sound Devices
Description: Høyttalere / Hodetelefon (IDT High Definition Audio CODEC)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_111D&DEV_7604&SUBSYS_102802A2&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: stwrt64.sys
Driver Version: 6.10.6241.0000 (English)
WHQL Logo'd: Yes
Date and Size: 9/15/2009 21:49:02, 499712 bytes
Other Files:
Driver Provider: IDT
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX 2.0 Listen/Src: No, No
I3DL2 Listen/Src: No, No
Sensaura ZoomFX: No
Kan noen hjelpe meg med hvilke drivere jeg må ha, eller hva annet jeg må gjøre?
Problemet her på forumet er vi ikke er synske.
Løsningen har du egentlig selv kommet med: "Hei, pcen min fungerer ikke som den en gang gjorde, den har blitt mye tregere og nå klarer den ikke en gang å starte minecraft: Bad video card drivers! "
Listen over "specs" inneholder ingen info rundt skjermkortet ditt. Men du kan gå til produsentens hjememside og laste ned nyeste drivere derfra (pass på å velge riktig modell og operativsystem siden dette påvriker hvilken driver du skal ha).
