Kan jeg få innspill på hvordan sammensetningen av denne PC-en er?
Har prøvd å sette sammen en pc til 10000 på komplett.no, men er litt blank på dette. Kan noen komme med noen tips, synspunkt på den listen jeg har satt opp?
Produktnavn
Cooler Master Centurion 5 II Special Ed.
- Vifter: 1x 140mm Front, 1x 120mm Bak, 19 dBA, ATX, mATX, Rød LEDs Av/På
Kingston HyperX SSD 120GB 2.5"
- SATA 6 Gb/s (SATA3.0), 555MB/510MB/s read/write, SandForce®
Silver Power SP-SS750M 750W PSU
- ATX 12V V2.3, 80 Plus Silver, Modular, 4x 6+2pin PCIe, 11x SATA, 120mm Vifte
Western Digital Caviar® Green™ 2TB
- SATA 6Gb/s, (SATA 3.0), RPM = IntelliPower, 64MB
ASUS P8Z68-V PRO, Socket-1155
- ATX, Z68, DDR3, 3xPCIe(2.0)x16, CFX&SLI, SATA 6Gb/s,USB3.0,FW, VGA,DVI,HDMI, EFI
Intel® Core™ i7-2600 Processor
- Socket-LGA1155, Quad Core, 3.4Ghz, 8MB, 95W, Boxed w/fan
Akasa 455 Kjølepasta
- 5 gram. High performance, spreader card
Corsair Dominator DHX DDR3 1600MHz 8GB
- Kit w/2x 4GB XMS3 DHX, CL9-9-9-24, for Core i3/i5/i7, w/Connector, 1.65v
Logitech Wireless Desktop MK260
- KB Layout Pan-Nordic
BenQ 24" LCD G2420HD
- 1920x1080, 40000:1, 2ms, VGA/DVI/HDMI
Lite-On DVD±RW Writer IHAS124-19
- SATA, DVD±R: 24x, DVD+RW: 8x, DVD-RW: 6x, DVD-RAM: 12x, Bulk, BLACK
Sapphire Radeon HD 6850 1GB GDDR5
- PCI-Express 2.1, 2xDVI-I, HDMI, DisplayPort, 775MHz, Lite-Retail
Her har du et bedre oppsett til en mindre pris:
Fractal Design Define R3 Black Pearl
Corsair TX V2 650W PSU
Gigabyte GA-Z68XP-UD3, Socket-1155
Intel® Core™ i5-2500K Processor
Crucial m4 SSD 2,5" 64GB
ASUS Radeon HD 6870 1GB GDDR5
Kingston DDR3 HyperX blu 1600MHz 8GB
Samsung SpinPoint F3 1TB
Acer 24" LCD P246HBD
Sony Optiarc DVD±RW Writer, AD-5280S
Logitech Desktop MK120 (Nordic)
http://www.komplett.no/k/ki.aspx?sku=648534
http://www.komplett.no/k/ki.aspx?sku=623444
http://www.komplett.no/k/ki.aspx?sku=638695
http://www.komplett.no/k/ki.aspx?sku=619274
http://www.komplett.no/k/ki.aspx?sku=630674
http://www.komplett.no/k/ki.aspx?sku=620247
http://www.komplett.no/k/ki.aspx?sku=639465
http://www.komplett.no/k/ki.aspx?sku=496258
http://www.komplett.no/k/ki.aspx?sku=630662
http://www.komplett.no/k/ki.aspx?sku=645800
http://www.komplett.no/k/ki.aspx?sku=597565
Jeg ville gått for denne setupen som jeg nettopp bygde til en kamerat som er strålende fornøyd. Du får blant annet et litt kraftigere skjermkort.
SF: http://www.komplett.no/k/ki.aspx?sku=601838
Case: http://www.komplett.no/k/ki.aspx?sku=579816
HK: http://www.komplett.no/k/ki.aspx?sku=601184
CPU: http://www.komplett.no/k/ki.aspx?sku=587218
GPU: http://www.komplett.no/k/ki.aspx?sku=639513
Ram: http://www.komplett.no/k/ki.aspx?sku=437583
HD: http://www.komplett.no/k/ki.aspx?sku=627518
Evt tilbehør:
Pasta: http://www.komplett.no/k/ki.aspx?sku=302913 (bruker denne selv, og er strålende fornøyd)
CD: http://www.komplett.no/k/ki.aspx?sku=605829
W7: http://www.komplett.no/k/ki.aspx?sku=498097
Håper dette er til hjelp.
Enig. Se på Sveibuen sitt om det er gaming du skal bruke den til. Forøvrig er det sikkert billigere på Dustinhome.no. Hvis du driver med 3D, videoredigering eller lyd så gå for en i7-2600k, hvis ikke, stick to the i5 som gir deg samme ytelse i spill for nesten 1000kr mindre.
Kjølepasta har du ikke bruk for. Det kommer forhåndssmurt på kjøler.
Endret av phlake
