Den store Playstationkaféen
CypheroN
Noen andre som har fått denne mailen?
Security update regarding your Ubisoft account
- please create a new password
Dear Member,
We recently found that one of our Web sites was exploited to gain unauthorised access to some of our online systems. We instantly took steps to close off this access, investigate the incident and begin restoring the integrity of any compromised systems.
During this process, we learned that data had been illegally accessed from our account database, including user names, email addresses and encrypted passwords.
Please note that no personal payment information is stored with Ubisoft, meaning your debit/credit card information was safe from this intrusion.
As a result, we are recommending that you change the password for your account: ..............
To enter your new password, click the link below:..............................
Out of an abundance of caution, we also recommend that you change your password on any other Web site or service where you use the same or a similar password.
You can find more information here.................................
For any additional support enquiries, please contact our customer service via our support web site at https://support.ubi.com
We sincerely apologise to all of you for the inconvenience. Please rest assured that your security remains our priority.
The Ubisoft team
Jeg har også fått den. Sjekket nettopp ubi.com og den er nede. Noe rart er det her...
Hey. Vet noen hva problemet er når en PS3 ikke vil oppdage HDMI i det hele tatt. Går inn på innstillinger og setter på HDMI, men blir bare sort og går tilbake til vanlig igjen. Skjedde etter jeg hadde fjernet kabelen en gang.
BTW: Vil heller ikke fungere på PC. Kan det være kabelen som er defekt?
Noen tips som jeg kan prøve?
Prøver å bruke Playstation Store, men får bare beskjed om at den er under vedlikehold. Flere som får dette?
Var akkurat inne og startet nedlastningen på GT6 demoen og The Ballad of Gay Tony, så virker fint for min del.
Hmm nå trenger jeg hjelp.
Kjører optisk lyd til forsterker, HDMI til tv'en. Alt av lyd har funka hele tiden, men nylig har jeg av og til fått skurring på lyden, at den bruddvis forsvinner eller at den forsvinner helt.
Alle innstillinger er riktige, også på HDMI sound ut osv.
Har byttet optisk kabel og får samme problemer. Det som krydrer problemstillingen litt er at når jeg oppdaterer HDMI-innstillingene så hører jeg interferens i lyden, som om PS3'en veksler fra HDMI-lyd til optisk lyd (selv om innstillingene alltid har stått på optisk). Noen ganger gjør dette at jeg får lyd igjen, ihvertfall kortvarig, men så forsvinner det eller begynner å hakke igjen..
Mine teorier:
1: PS3'en er i ferd med å knele
B: HDMI-relatert problem, noe overstyrer optisk ut og fucker alt sammen
III: Det er allikevel noe jeg plutselig ikke har gjort riktig på innstillingene.
Mine innstillinger:
Video Output Settings = HDMI = AUTOMATIC
Video Settings* BD Audio Output Format (Optical Digital) = BITSTREAM
Audio Output Settings = DIGITAL OUTPUT (OPTICAL)
Disse innstillingene har som sagt funket for meg så lenge jeg kan huske, men plutslig sliter lyden...
Endret av Ham 550
