uTorrent - slettet/stoppe torrenten automatisk når den er ferdig?
lur4d
Det eneste som er verre enn en kjeltringer er usolidariske kjeltringer...
men du laster selvfølgelig kun ned lovlig materiale distribuert gjennom bittorrent-teknologien, og utorrent har flere instillinger du kan bruke, f.eks seed ratio, down/up limit, og scheduler.
Endret av SirAmp
Vil bare opplyse om at Utorrent inneholder Maleware nå for de som ikke vet dette.
Startside blir highjacket, man får en masse filer på maskinen som "nesten" blir umulig å få fjernet.
Filene lar seg ikke fjerne med Malwarebytes filassasin eller Lockhunter.
De må fjernes manuelt, og de ligger under skjulte mapper.
Står noe om dette her:
https://forum.utorrent.com/viewtopic.php?id=90082&p=1
Programmet inneholder også en toolbar
Innlegg fra tidligere brukere:
I've been using uTorrent for years, as it has clearly been the lightest, safest, and cleanest torrent program out there. I'm not normally one to complain about things, let alone go through the trouble of creating yet another account on the internet just to do so, but I registered today purely to come here and let you know how furious I am about this fucking browser bar.
I open uTorrent a bit ago, and it tells me there's an update with improvements and whatnot, so I figure, "hey, why not" and click okay to proceed with the update. During the update process not one time was I asked or even told that a browser bar, which seems dangerously close to a browser highjacker, would be installed.
When I reopened Firefox, my homepage had been changed, my search bar was changed, a new ugly toolbar had been added, and on top of that, when I removed the toolbar I discovered it had left another extension installed behind it.
This is absolutely unacceptable, and you guys should know better. I'm honestly concerned as to what else was installed on my system without my knowledge, and how my other browsers may have been highjacked or compromised. Should I be worried that I unknowingly gave permission for some kind of trojan to be installed on my system as well? This is disgusting, and really not something I have time to deal with today.
At the absolute least, we deserve a full disclosure of everything that was installed with the update, or could have been installed with the update. In addition, right fucking now you guys should be working on an emergency patch for this update, and the current update should be pulled until then.
I'm sure I sound a bit sanctimonious here, but seriously, this is a major breach of privacy and trust, and you will lose a lot of users over this. I hope you guys can resolve it soon.
Update: It highjacked IE as well, changed the homepage and the search provider, and installed god knows what else.
Thanks uTwat for posting the HijackThis tips. For those that aren't familiar with it, cnet has a clean download and a tutorial for it here.
The very fact that we have to use HijackThis to remove this shit has officially moved uTorrent into the realm of malware. You guys should be better than this.
Edit: oh, and it's real nice that the homepage it changes your browser to is mocked up to look as much like Google as possible. Hoping some of the less tech-savvy users won't notice? I hope Conduit gave you guys a fat fucking check, cuz you just alienated your entire user base.
Edit 2: Looks like there's more than just those three items to remove in HijackThis. This is what I found in my scan:
R3 - URLSearchHook: uTorrentBar Toolbar - {bf7380fa-e3b4-4db2-af3e-9d8783a45bfc}
- C:\Program Files (x86)\uTorrentBar\tbuTor.dll
O2 - BHO: Conduit Engine - {30F9B915-B755-4826-820B-08FBA6BD249D}
- C:\Program Files (x86)\ConduitEngine\ConduitEngine.dll
O2 - BHO: uTorrentBar Toolbar - {bf7380fa-e3b4-4db2-af3e-9d8783a45bfc}
O3 - Toolbar: uTorrentBar Toolbar - {bf7380fa-e3b4-4db2-af3e-9d8783a45bfc}
O3 - Toolbar: Conduit Engine - {30F9B915-B755-4826-820B-08FBA6BD249D}
- C:\Program Files (x86)\ConduitEngine\ConduitEngine.dllAnd, after running a clean operation, twice, with all other windows closed, THREE of the five items still show up. What the fuck guys? This is some evil shit you let through onto our computers.
Vær oppmerksom på Conduit uninstallation
og Conduit mapper.
Sjekk tillegg som dere har på deres nettlesere.
Bruk Highjackthis for å finne skjulte filer, men disse må letes etter manuelt også i mapper som ligger skjult.
Bruk derfor - vis skjulte filer og mapper.
Har nå brukt bitcomet såvidt men var forferdelig treg.
Bruker nå Bittorrent - samme oppsett nesten som Utorrent, men får ikke dette Conduit - toolbar og highjacking av startside.
Endret av Vårbris
  Mr. A skrev (På 23.9.2011 den 15.58):
Har brukt µtorrent lenge, og har ikke hatt noen av problemene der. Sikkert karen som har installert en infisert versjon av µtorrent.
Ditto - jeg har brukt utorrent i åresvis, og har aldri opplevd noe i nærheten av det som beskrives. Jeg vil jo påstå at jeg kan nok til at om disse tingene skjedde så hadde jeg oppfattet det rimelig fort. Legg til at Utorrent gjevt over regnes som den mest populære bittorrent klienten så tviler jeg på at noe sånt ikke ville fått rimelig store reaksjoner fort.
Jeg er kort sagt meget skeptisk.
Vel og merke - jeg installerer aldri valgfri "toolbar" tillegg som man ofte får tilbud om ved installasjon av gratis software. Jeg naer ikke om dette kan ha gråsone malware i seg. Det hadde jeg ikke vært så skeptisk til å tro på - men det er jo irellevant så lenge du kan velge å ikke installere den.
Jeg har dog ikke researchet inn i dette i detalj. Om dette er noe som er blitt endret på i relativt nyere tid så kan det være jeg bare ikke har brukt den versjonen enda.
edit. leste fort gjennom de første par sidene i tråden og ser at det er tillegg-toolbaren som er problemet, men at du kan bare velge å ikke installere denne som jeg nevnte tidligere (det jeg alltid har gjort). Folk bare reagerer på at dialogvalgene er litt gråsune uærlige i det at det lett i misforstå at du godtar å isntallere toolbaren - mens du egentlig tror at du godtar å installere bare utorrent. Bare klikk "no thanks" når du blir spurt om toolbar installasjonen så går det greit :)
-Stigma
Endret av Stigma
Gjest medlem-82119
Eldre utorrent hadde ikke installasjon i det hele tatt. Har ikke sjekket den nye med installasjon. Generelt har jeg opplevd lignende ting når man oppdaterer programvare fra programmet. Oppdatert versjon legger inn alle default valg som registeroptimalisering, toolbars, malware osv. Ikke knyttet til utorrent, såvidt jeg vet.
Derfor avinstallerer jeg alltid alt og fjerner alle rester fra register og settinger før jeg legger inn ny versjon lastet ned fra utvikler og følger med hvilke valg man får under installasjon.
Forøvrig, har man en god brannmur elelr antivirus vil de beskytte mot slike forandringer i nettleseren.
La før inn quick media converter, og der må man velge enten å forandre startside, søkemotor eller legge inn toolbar. Valgte å forandre hjemmeside, og da ble dette blokkert og programmet installert uten slikt tull.
