Hei, driver for tiden å tukler litt med java, skrev denne her idag, men har noen små problemer, tror enten det er en feil i repaint, eller en feil i inkrementeringen, noen som har en løsning?
dette er classen jeg har problemer med:
class HelloComponentX extends JComponent {
int theY;
int theX;
String theMessage;
public HelloComponentX( String message ) {
	theMessage = message;
// check the arrow keys and adjust vars
public void keyPressed(KeyEvent e) {
//if up arrow is pressed
    if (e.getKeyCode() == KeyEvent.VK_UP ) {
   theY = theY - 1;
//if down arrow is pressed
    if (e.getKeyCode() == KeyEvent.VK_DOWN) {
   theY = theY + 1;
//if left arrow is pressed
    if (e.getKeyCode() == KeyEvent.VK_LEFT) {
   theX = theX - 1;
 //if right arrow is pressed
    if (e.getKeyCode() == KeyEvent.VK_RIGHT) {
    theX = theX + 1;
//drawing
public void paintComponent( Graphics g ) {
   	int X = 200 + theX;
   	int Y = 200 + theY;
	g.drawString("test", X, Y);
	repaint();
Jeg er definitivt ingen GUI-programmerer, men dette virker hos meg:
import java.awt.event.KeyEvent;
class HelloComponentX extends javax.swing.JComponent implements java.awt.event.KeyListener {
  int theY;
  int theX;
  int i;
  String theMessage;
  public HelloComponentX(String message) {
  @Override
     int x = 0, y = 0;
     if(e.getKeyCode() == KeyEvent.VK_UP) y -= 1;
     if(e.getKeyCode() == KeyEvent.VK_DOWN) y += 1;
     if(e.getKeyCode() == KeyEvent.VK_LEFT) x -= 1;
     if(e.getKeyCode() == KeyEvent.VK_RIGHT) x += 1;
     if(x != 0 || y != 0) {
        theY += y;
        theX += x;
        repaint();
  @Override
  public void keyTyped(KeyEvent e) {}
  @Override
  public void keyReleased(KeyEvent e) {}
  //drawing
  public void paintComponent(java.awt.Graphics g) {
     int X = 200 + theX;
     int Y = 200 + theY;
     g.drawString("test " + i++, X, Y);
  public static void main(String[] args) {
     javax.swing.JFrame me = new javax.swing.JFrame("En liten test");
     HelloComponentX hcx = new HelloComponentX("test");
     me.add(hcx);
     me.addKeyListener(hcx);
     me.show();
Takker, men her er hele koden satt sammen i en stor klasse, fungerer ikke helt og klarer ikke å finne ut hvorfor, driver å lærer java så dette er vell egentlig over mitt kunnskapsnivå innenfor temaet! :p
meningen er at man skal kunne styre teksten rundt med piltastene!
import java.awt.*;
import javax.swing.*;
public class HelloJavaX {
	JFrame frame = new JFrame( "Hello JavaX" );
	frame.getContentPane().add( new HelloComponentX( "Hello" ) );
	frame.setSize( 450, 450);
	frame.setDefaultCloseOperation( JFrame.EXIT_ON_CLOSE );
       frame.setVisible( true );
class HelloComponentX extends javax.swing.JComponent implements java.awt.event.KeyListener{
   int theY;
   int theX;
   int i;
   String theMessage;
   @Override
      int x = 0, y = 0;
         theY += y;
         theX += x;
         repaint();
   @Override
   @Override
   //drawing
      int X = 200 + theX;
      int Y = 200 + theY;
      me.add(hcx);
      me.show();
Oi, ser med en gang hva jeg gjorde feil der, var litt vanskelig å se det på editoren :p
Fungerer nå, tusen takk!
       frame.add(hcx);
    frame.addKeyListener(hcx);
   int theY;
   int theX;
   int i;
   String theMessage;
   @Override
      int x = 0, y = 0;
      if(e.getKeyCode() == KeyEvent.VK_UP) {y -= 1;}
      if(e.getKeyCode() == KeyEvent.VK_DOWN) {y += 1;}
      if(e.getKeyCode() == KeyEvent.VK_LEFT) {x -= 1;}
      if(e.getKeyCode() == KeyEvent.VK_RIGHT){ x += 1;}
         theY += y;
         theX += x;
         repaint();
   @Override
   @Override
   //drawing
      int X = 200 + theX;
      int Y = 200 + theY;
Endret av Leif.ross
