Blåskjerm KERRNEL_DATA_INPAGE_ERROR
AS-SSD Benchmark
AS-SSD is a benchmark is specifically built for testing out SSDs and it what OCZ used to get their secondary set of numbers. This makes it an important test and the same setup of an Intel Z68 chipset with i5-2500k CPU and 8GB of memory on a SATA III port were used for the following results:
Sequential: 166.74 MB/s Read, 72.43 MB/s Write
4k: 15.85 MB/s Read (4057 iops), 48.21 MB/s Write (12341 iops)
4K-64Thread: 50.81 MB/s Read (13007 iops), 70.35 MB/s Write (18010 iops)
Access Time: .157ms Read, .317ms Write
http://compreviews.about.com/od/storage/gr/OCZ-Agility-3-60GB.htm
Er omtrent likt ditt resultat på lesing. På skriving ligger du litt bak dette resultatet.
