Bra gaming pc til 14K?
Kom fram til:
Hard Disk: http://www.netshop.no/Avdelinger/Datautstyr/Harddisk/SSD/OCZ/OCZ-120-GB-SSD-2,5-Vertex-2-SATA-II,-Max-Read-Write-285-275MB-sec-43015.aspx
Hoved Kort: http://www.netshop.no/Avdelinger/Datautstyr/Hovedkort/Intel-Socket-1155/ASUS/ASUS-P8Z68-V-PRO,-Socket-1155-ATX,-Z68,-DDR3,-3xPCIe20x16,-CFX-and-SLI-48112.aspx
Kabinett: http://www.netshop.no/Avdelinger/Datautstyr/Kabinetter/Midi-tower/NZXT/NZXT-Trinity-Sort-gaming-kabinett,-uten-str%C3%B8mforsyning-18605.aspx
Minne: http://www.netshop.no/Avdelinger/Datautstyr/Minne/DDR3-1600Mhz/Corsair/Corsair-Vengeance-DDR3-1600MHz-8GB-CL8-Kit-w-2x-4GB-XMS3-modules,-CL8-8-8-24-46103.aspx
CPU: http://www.netshop.no/Avdelinger/Datautstyr/Prosessor/CPU/Intel-Socket-1155/Intel/Intel-Core-i5-2500K-Quad-Prosessor-33GHz,-6MB,-BOXED-Sandybridge-45538.aspx
Skjerm Kort: http://www.netshop.no/Avdelinger/Datautstyr/Skjermkort/PCI-Express/ASUS/ASUS-GeForce-GTX-580-1536MB-PhysX-2xDVI,-native-HDMI,-HDCP,-Displayport-47014.aspx
Kjøling: http://www.netshop.no/Avdelinger/Datautstyr/Kj%C3%B8ling/Kj%C3%B8ling,-luft/CPU/Noctua-NH-D14-CPU-Kj%C3%B8ler-140mm120mm-Fan,-1300RPM,-19,8-dBA-40732.aspx
Programvare: http://www.netshop.no/Avdelinger/Datautstyr/Programvare/Operativssytem/Microsoft/Microsoft-Windows-7-Home-Premium-Norsk,-OEM,64bit-DVD-m-SP1-46979.aspx
Strømforsyning: http://www.netshop.no/Avdelinger/Datautstyr/Str%C3%B8mforsyninger/ATX/500W-699W/Corsair-TX650M--Enthusiast-Series-PSU-140mm-vifte,-modul%C3%A6re-kabler-49162.aspx
CD/DVD Rom: http://www.netshop.no/Avdelinger/Datautstyr/CD/DVD/Blu-ray/Blu-Ray-/-HD-DVD/Lite-On/LiteOn-Blu-ray-brenner-SATA-Bulk-8xBDROM-16xDVD-ROM-48xCDROM-43760.aspx
Lydkort: http://www.netshop.no/Avdelinger/Datautstyr/Lydkort/PCI/Creative/Creative-SoundBlaster-X-FI-Titanium-PCIE-24-bit-36060.aspx
Bluetooth: http://www.netshop.no/Avdelinger/Datautstyr/Nettverk/Bluetooth/Edimax/Edimax-Bluetooth-adapter-USB-v21-class-1,-opp-til-100-meter-47128.aspx
Må si jeg syntes det var en svært treg ssd.
Hva med: http://www.komplett.no/k/ki.aspx?sku=630675#reviews veldig lite feil med denne.
Akurat kommet ny firmware.
Datan kommer til og bli svindyr om jeg legger til i7. Skjerm Kortet var svindyrt for og si det sånn :p men det va sinnsykt bra! skal beholde det! men da står det mellom i7 og i5. Hva er vitsen i å betale 1K ekstra for et nyere produkt, når du kan spare 1K på et litt gamlere et når de er ca like bra?
Noen ting jeg bare vil nevne for deg fordi det virker som du ikke kan NOE om data.
-i7 og i5 er like gamle. i7 er bare "storebroren" til i5
- Hvorfor trenger du en så hefti pc når du ikke vet hvordan du bruker den?
- Hvor gammel er du?
Not sure if trolling...
Har navnet ditt tilfeldigvis noe å gjøre med din egen alder?
