Liste med forskjellige farger annenhver gang
txt-dokument med informasjon:
bnm1||tff
bnm2||turr
bnm3||turi
bnm4||turd
$fil = file('info/ordliste.php');
foreach($fil as $e => $p){
list($ord,$forklaring) = explode("||", $p);
echo "<tr><td [b]bgcolor=ffffff[/b]><b><a name="$ord"><li> 8$ord</b></a><br>$forklaring</td></tr>";
Ønsker at scripet skal gjøre annenhver bgcolor til en annen farge. slik at bnm1 og bnm3 blir med f.eks. #129855
Sikker på at dette er mulig ;-)
quoter litt fra et annet forum:
I've seen some people ask this before, so I thought I'd write a short tutorial. How do you alternate row colors using PHP?
It's simple really, wherever you data is, whether it's in an array, database, or file, just loop through it and print this line:
<tr bgcolor="<?=($i%2)?"#ffffff":"#c0c0c0";?>">
<td>YOUR DATA GOES HERE</td>
</tr>
The % is just the remainder if the top number (numerator) was divded by the bottom number (denominator).
To further explain this.... it may be easier to read through examples... :)
Example 1: Data in an array
<table>
    $myarray = array('apples', 'oranges', 'banana');
    $i = 0;
    foreach($myarray as $value)
<tr bgcolor="<?=($i%2)?"#ffffff":"#c0c0c0";?>"><td><?= $value ?></td></tr>
        $i++;
</table>
This should look like this:
Example 2: Data in a Database
$sql = "SELECT * FROM fruit";
$results = mysql_query($sql);
$i = 0;
while($the_fruits = mysql_fetch_row($results))
<tr bgcolor="<?=($i%2)?"#ffffff":"#c0c0c0";?>"><td><?= $the_fruits["fruit"] ?></td></tr>
    $i++;
Example 3: Data in a file
Say myfile.txt contains:
1,apple
2,orange
3,banana
The code would look like this:
$filename = 'myfile.txt';
// Read file contents
$fileptr = @fopen($filename, 'r');
while (!feof($fileptr))
 $temp .= fread($fileptr, 4096);
$source = explode("n", $temp);
$i = 0;
foreach($source as $data)
 list($rownum,$fruit) = explode(",",$data);
 if($i%2)
    $rowcolor = '#ffffff';
 else
    $rowcolor = '#c0c0c0';
 echo '<tr bgcolor="'. $rowcolor.'"><td align="right" width="100">'. $rownum .'</td><td width="100">'. $fruit .'</td></tr>';
 $i++;
echo '</table>';
is the shorthand 'if' conditional statement.
It means the same thing as:
if($i%2)
   echo "#ffffff";
else
   echo "#c0c0c0";
you can also use $i & 1, which does a binary check on the number. if the last bit is 1, then it's odd. if not, it's even :)
example (decimal to binary):
1 => 1
2 => 10
3 => 11
4 => 100
5 => 101
etc ;) I think it's a little faster too.
<table>
   $i = 0;
<tr bgcolor="<?=($i&1)?"#ffffff":"#c0c0c0";?>"><td><?= $value ?></td></tr>
       $i++;
</table>
and yet another way:
<?php
echo("<table>");
$num = 10;
for($i = 0; $i < $num; $i++) {
  if(round($i/2) == $i/2) {
     echo "<tr bgcolor="#cccccc">";
  else { echo "<tr bgcolor="#eeeeee">"; }
  echo "<td>$i</td></tr>";
echo("</table>");
det skulle være en god del forskjellige måter å gjøre dette på...
