Harddisk og klikkelyder, Seagate Barracuda.
EG-s
Har en usb disk (fujitsu storagebird usb) seagate ST31500341AS 1.5Tb disk. Denne ble svært varm, og mistet ofte kontakten med windows. Resultatet var å ta strømmen og plugge inn igjen.
Med ujevne mellomrom lager den mekaniske klikkelyder.
Sjekker med hd sentinel, og de siste månedene har programmet rapportert om flere feil.
Av alle disker er det bare denne som lager klikkelyder
Maximum Temperature (Ever Measured) : 48 °C, 06.07.2011 18:34:51
Minimum Temperature (Ever Measured) : 21 °C, 06.05.2011 19:24:38
Maximum Temperature (During Entire Lifespan) : 63 °C
Power On Time : 698 days, 1 hours
Estimated Remaining Lifetime : 162 days
Health :
38 % (Acceptable)
Performance :
100 % (Excellent)
There are 5 bad sectors on the disk surface. The contents of these sectors were moved to the spare area.
Problems occurred during the spin up of the disk 76 times. This can be caused by the disk itself or huge power load (weak power supply).
At this point, warranty replacement of the disk is not yet possible, only if the health drops further.
It is recommended to examine the log of the disk regularly. All new problems found will be logged there.
It is recommended to backup often to prevent data loss.
