overklokking :D
Er det noen som har overklokket en AMD duron 600 mer en 900Mhz?? Uten vannavkjøling eller flytene nitrogen eller noe annet fancye greier som er dyrt eller umulig å få tak i! :grin:
her er resultater fra cpu databasen til overclokers.com
CPU Databases - AMD
Duron 600 Results....
Total Entries in Database for Duron 600 - 741
Average overclocked speed - 947 Mhz
Speed Volts Code Motherboard Notes ID
1700 2.20 Used an abit kt7a raid 170*10 6592
1600 1.85 Sucess at 133.3x12 10577
1500 2.70 Abit KT7 (only 67°C) 11462
1432 1.85 8667
1400 2.20 AKBA0035FBGW Compressor cooling 11095
1400 2.40 AKBA0035FBGW Compressor cooling , cpu -8c full load 11096
1400 2.40 AKBA0035FBGW Compressor cooling , cpu -8c full load 11097
1300 2.45 liquid nitrogen 11572
1300 2.50 75W Peltier, Perfect under win98 and win2k. 13141
1268 2.75 AKBAR0035GPMW (8,5X149,2) Watercooled, Rock Solid, PiFast OK 13601
1260 2.22 AKBA0029DPAW http://koti.mbnet.fi/~tejo/pics/Testit/1260mhz/ 13252
1227 2.03 AKBA 0031 Epox 8KHA+ Swiftec MC462 5599
1217 2.45 BPLW by Tenka Indonesia 6954
1215 1.85 Vantec Cooler in InWin Q500 on a ABIT KT7A 6191
1200 1.85 0027BPEW http://www.overclockzone.com Thailand by bbenz3344 10243
1200 1.75 12723
1174 2.05 watercooling+75w peltier http://amdoc.supereva.it 11350
1161 1.90 Homemade watercooling + car fridge peltier. 12188
1155 1.85 ABIT KT7 running as 110MHZx10.5 using Alpha 6035 1425
1150 2.16 Modified A7V. WATERCOOLED CPU/PLL/VIA. 10.0 X 115 12694
1150 1.85 D600AST1B A7V MOD to 2.17V WaterCooled CPU/VIA/PLL 12721
1133 2.20 Week 33, Water Cooler 11451
1133 1.95 Water cooled can do 1166, but Win2k dies 12543
1130 2.11 D600AST1B ASUS A7V MOD 2.11v. WaterCooled. Lapped CoreandVIA 9381
1130 1.85 133*8.5 FOP 32 LAPPED hs 49/52C + four case fans 11387
1125 1.65 rock solid 11144
1111 2.05 AKBA31sett.2000 KANIE+DELTA+A7V133 6689
1111 1.85 AKBA0032 A7V +taisol @ 11*101 12502
1111 2.25 Got an Asus A7V motherboard with HP arctic cooler 13284
1109 2.14 Week 21 Modified A7V, peltier+glycol+compressor cooled 13160
1104 2.04 KT7-Raid FOP32-1 Moselvitelic Cas 2-2-2 Nvidia Qua 8557
1104 2.12 http://www.pognogit.net 9512
1102 2.11 FOP 38, Voltage Hack to A7V, Very stable 6625
1102 1.93 Week24 A7V, 10.5x105, Alpha PEP66 (48 idle), stable 8546
1100 1.85 AKBA0029DPAW 3063
1100 1.89 week 31 Rock stable. ABIT KT7. Alpha Pal6035 5172
1100 1.90 akba0032... hand made water cooling + peltier 6023
1100 2.01 Duron 600 @ 1100 Rockstable @ 2.01 V 6557
1100 2.15 disipador de cobre y dos ventiladores de 8x8 a 17v 8059
1100 2.11 A7V ROCK SOLID WATER COOLED 9382
1100 1.85 AKBA 0027 ABIT KT7 RAID ALPHA PEP66 10676
1100 1.85 AAKBA0027TPDW 1100..Duron Week27 KT7-Raid Ran Prime95AlphaPEP66! 12257
1100 2.11 AKBA0037RPBW A7V (modified) Watercooling 12756
1100 2.33 mod A7V, copper water w/o peltier, Prime95 stable 13305
1095 2.14 BPLW Alpha 6035 + Delta 7200RPM KT7A (146 x 7.5) 11388
1090 1.85 asus a7v-titan m5a cooler+fan 4" rock stable 48cel 3366
1090 1.85 A7V,M5AB+ external,10*109 8000
1090 1.85 "Reddish-Blue" Core 13185
1082 1.85 vk29 Modified Titan Majesty 5201
1081 1.85 Asus A7V 103FSB with Alpha PEP66 (feet cut off) 12194
1072 1.99 AKBA0025MPMW Modded KT7 107*10, big sink cpumax49C, rockstable! 1709
1072 1.80 Chrome Orb, Asus A7V 8299
1071 1.80 ABIT KT7, 10.5X103, FOP-38, idle 38, load at 43 9474
1070 1.85 Week 27 Asus-A7V , 107MHz FSB and 10.0x Multiply 4504
1070 1.85 Week 27 Asus A7V ,107MHz FSB 10.0x Multiply 4505
1070 1.85 Not completely stable, but it is at 1Ghz 4809
1070 1.85 memory pc100 5959
1070 1.89 week 25 Titan Majesty m5ab(golden orb) cooler. 10*107MHz 7896
1070 1.85 WK 29 KT7,Taisol fan, Arctic Silver 9036
1066 1.78 abit kt7a (kt133a) Super Orb gets really hot. Super orb is loud. 662
1066 1.83 blue, week 35, lead A7V, GOrb 462. 10.5x100, POST reports 1066. Stabil 4531
1066 1.95 Week 24 A7V+(Chrome Orb+add'l fan)+2 case fans 9405
1066 1.70 8x133, ABIT KT7A-RAID, GlobWin FOP32, 40 deg. max 10535
1066 1.85 stable and good cooled 11695
1065 1.85 Abit KT7A, 142x7.5 6104
1064 2.10 kt7r 9.5 * 112fsb....Vantec CCK-6035D 11863
1061 1.89 Week 31 CoolerMaster DP5-6H51 HS/Fan 5969
1061 2.11 Abit KT7 modded mobo - Rock stable - 101 FSB 12849
1060 1.85 AKBA0026DPBW A7V 10.5 x 101MHz VOS32 Core 50C Stable 4515
1060 1.85 Not good enough 5100
1060 1.85 10,5*101 roxx... A7v+FOP32. Rock stable! 6042
1060 1.85 AKBA 0036APEW KT7-Raid, GW-FOP 38. Perfectly stable! Smoookin 10697
1060 1.80 by Tenka Bandung Indonesia 12248
1055 1.75 KT7+Fop38 at 7V (12V too noisy) Temp above 48C 4620
1052 2.01 AKBA0029DPDW Modified A7V,Water cooled,rock solid,temp=45C . 12190
1050 1.85 KT7 - Chrome Orb 601
1050 1.85 Does 950 at 1.6v, 1020 at 1.7v. Won't do 1100. 1253
1050 1.87 akba0031fpcw asus a7v silver orb 1930
1050 1.80 A7V+FOP32, pencil@L1: http://www.hardwaresweden.com/duron 2230
1050 1.80 Stable on KT7-RAID @ 1.80v and SPIREorb 3443
1050 1.85 week 29 A7V using FOP32 and a 120mm fan 3472
1050 1.80 Very stabile 3693
1050 1.75 A7V, 22$ fan, pencil: @52C Rock solid! 4640
1050 1.85 Alpha H/S &Fan. This chip can go higher. $59 WOW 4806
1050 1.85 D600AST1B - Abit KT7+Fop32 (bought it in Hungary) 5156
1050 1.75 week 27 with KT7, FOP32, 10x105MHz 5170
1050 1.85 A7V with chrom orb + artic silver 5205
1050 2.00 family6,model3 step0 a7v Super-orb,moded case,crucial 5888
1050 1.70 Week 34 KT7-RAID, Titan M5, rock solid 10.5x100. 5981
1050 1.81 KT7 92mm fan blowing on generic HS&Fan rock solid 5986
1050 1.80 Abit kt7 Fop32-1 and some silverpaste. RockStable! 6565
1050 1.85 Rock stable with alpha pep66 6568
1050 1.75 abit kt7-raid, water cooled, 43C 6875
1050 1.95 AKBA0028BPCW FOP32, ArticSilver 134F at load. Prime95 Stable 7095
1050 1.85 140*7.5, Alpha 6035+Delta, 55°C load, noisy&fast 7585
1050 1.72 AKBA0031GPBW A7V, instabil, stabil bei 1000Mhz, 900Mhz mit 1,6V 7768
1050 1.80 Abit kt7 Fop32-1 and some silverpaste. RockStable! 10106
1050 1.85 Rock stable with alpha pep66 10109
1050 1.85 KT-7, cooler-SuperOrb 10342
1050 1.87 Abit KT7, Globalwin FOP32. I'm lucky! :wink:) 12189
1050 1.80 original fan and heatsink 12213
1050 1.85 week 32 (10x105) + FOP38 12273
1050 1.80 Epox 8kta+ w/ FOP32 IDLE 32 FULL LOAD 40 12687
1050 1.85 10.5x100, Global Win FOP38. Hits 1ghz w/ 1.75v 12697
1050 1.85 FOP38, KT7-RAID, 48c. 12698
1050 1.85 week 36 12740
1050 1.85 AKBA 0031WPEW VIO needs to be 3.5v,A7V,Alpha, Absolutely Stable 12760
1050 1.85 week 26 kt7-raid+fop38 rock stable at 10.5x10, 10x105 13100
1050 1.75 A7V, Pencil, coolermaster: 20$, 51C stressed 13179
1046 1.85 CopperCooler,Week32,ExtraFans,100%Stable,9.5x110 9364
1045 1.85 Abit KT7-RAID 950x110 3945
1045 1.85 AKBA0037GPAV D600 with purple core+Corb-very stable 5106
1045 2.01 AKBA 0029CPDW http://www.geocities.com/pcdevizeth/ MSI K7T +DP5- 5131
1045 1.75 d600AUT1B 9.5*110 Fast As My PIII 1GHZ, Air cooled 51 Load 10066
1044 1.85 Abit KT7, lapped FOP38, artic silver, copper shim 10824
1040 1.80 Post @ 1074, PAL6035-AlOxide TC 8300
1040 1.85 Abit KT-7 (non raid) with a swiftech mc462 11351
1040 1.91 akba0029fpbw StkFan,NStb.Stb@:1G/1.75v.95/1.65v.9/1.53v.8/1.4v 13149
1040 1.85 D600AST1B / AKBA0029 Max Temp : 51°C ; boot@1070 but freeze on Windows 13272
1035 1.85 Week 27 G-W fop-38 , A7V, Arctic Sil. 109bus*9.5 multipler 6605
1035 1.85 Week 27 G-W fop-38 , A7V, Arctic Sil. 109bus*9.5 multipler 10117
1030 1.85 Running @ 60C 140F 13617
1030 1.90 AUT A7V; Alpha PEP, 2nd case-cooler 2172
1030 1.85 AKBAR0036APMW Had to adjust voltage manually through L7 3744
1030 1.85 week 31 multi=10x103 KT7,Pal6035,artic silv,stable 4658
1030 1.75 AKBA0031VPAM 10x103 on a Asus A7v (with the multiswitches) 5137
1030 1.80 AKBA0031WPEW A7V motherboard, Alpha pep 66 heatsink runs at 45c 7102
1030 1.75 KT7. Still testing. Win works. 10794
1030 1.85 ABIT KT7RAID @ 10x 103 MHz, Normal Cooling 12717
1030 1.80 12841
1030 1.85 d600aut1b 13151
1030 1.85 d600aut1b 35 weeks 13152
1028 1.85 Week 34 Msi k7t pro 2a 107*9.5 2376
1028 1.91 Liquid Cooled, 29c idle, 34c load. 1104 not stable 12352
1026 1.81 AKBA0026DPAW ABIT KT7 108FSB x 9.5 ~Factory Unlocked~ 9399
1026 1.80 week 31 (108 x 9.5) KT7 & FOP-32 w/ artic silver. 9873
1022 1.75 145x7. ocz monster2. 44C load 3516
1022 1.85 week 29 146*7, ABIT KT7A+GW FOP32 12104
1020 1.85 AKBA0023MPMW A7V /s HEAT-KILLER-U & chip-coolers 1739
1020 1.85 10.0 * 102fsb (A7V) - POST but WIN is unstable 4592
1020 1.85 8468
1020 1.75 AKBA0036GPAW Rock solid with ELAN VITAL COPPER heatsink+fan 9126
1020 1.85 week22 9864
1020 1.85 No Problems 12346
1020 1.85 AKBA0031VPAM 10x102Mhz, A7v w. dips 12724
1020 1.88 Week 31 (102mhz*10) on Abit KT7 w/ voltage mod 12742
1020 1.75 AKBA0036GPAW Rock solid with ELAN VITAL COPPER heatsink+fan 13319
1017 1.89 Asustek A7V-133 49° max with WBK38 5505
1017 1.78 unknown 42C under load-MSI K7T Pro2A-air cooled 10760
1017 1.85 modded GW FDP ....should go higher 11314
1016 1.85 Week 32 Boot's at 1066 buts fails to load Win98. It rulezz 4664
1016 1.85 Abit KT7 RAID + FOP32 9339
1016 1.85 AKBA0027APDW Taisol CEK733092 + Blowholes 10721
1015 1.80 Heatpipe , Epox 8KTA3 (145x7) 6107
1014 1.63 KT7&Fop32w/ThermPad(106.5x9.5)52oC fullload&summer 5276
1013 1.89 AKBA0029DPDW 5 deg C water cooled, chip at 39 deg C, stable as. 8749
1012 1.72 0wned, alpha pal6035 8738
1010 1.90 Cooled with GlobalWin FOP32, 45C 1945
1010 1.85 Abit KT7 5716
1010 1.85 6 3 0 OA A7V (penciled in cpu) Alpha 6035 9342
1010 1.85 A7V w Thermaltake Gorb & Radio Shack HS Grease 9813
1010 1.85 AKBA 0031WPEW A7V PC133@152 (pencilled Duron) 12783
1009 1.81 A7V rev 1.02. Watercooling. Idle/Load : 44C/48C 12192
1008 1.85 week 27 with m5ab 5255
1008 1.85 Using a Super Orb 9030
1008 1.85 KT7, OCZ Monster II HSF, stable w/ case open 9572
1008 1.72 31W AKBA0031FPBW A7V with Alpha P126 Heatsink 9803
1008 1.85 AKBA0037RPAW ABIT KT7RAID, 112FSB*9, Alpha PEP66T Cooler, 10124
1008 1.85 5 case fans, fop38, abit kt7a,42C.rock stable 11101
1007 1.89 ABIT KT7-Raid Big Alpha Heatsink 4867
1007 1.85 Big heatsink and fan runs stable if i keep it cool 8106
1006 1.75 10052
1002 1.85 AKBA - 9 abit kt7e 154*6.5 ... never thougt the kt7e would take this! 538
1002 1.85 AKBA0033FPAW Taysol CGK-74092 10072
1001 1.85 AKCA0045MPM SOLTEK SL-75KAV(Q9 Bios) VOLCANO2.143FSB.RAM-NCP. http://www.pcpervertz.org 5577
1000 1.80 Abit KT7 751
1000 1.85 Bought it from http://ocz.safeshopper.com/ 1882
1000 1.80 Week36 Asus A7V+Alpha (Cool!!) 2148
1000 1.70 AKBA0029TPBW KT7RAID, stable. Chrome orb. 2165
1000 2.30 AKAA Ecs (Elitegroup) K7s5a 2471
1000 1.80 AST!B AKBA 0029 TPFW very stable 57C 3446
1000 1.85 Malaysia Gorb KT7 gonna mod volts go higher 3470
1000 1.85 Using OCHideout watercooling. Avg 23c 3473
1000 1.93 AKBA0037BPCW K7T Pro2A, lapped FOP32 + 2 x 80mm fans, STABLE 3648
1000 1.70 34C & rock solid! A7V, FOP38, Arctic Silver 3686
1000 1.90 AKBA0033EPBW Runs at 1.8V. 1.9V is to pass Prime95 w/o errors. 3953
1000 1.75 KT-7 RAID, Alpha 6035, 38C 4181
1000 1.85 AKBA0031WPEW Asus A7V, Fop38 (have two) 4189
1000 1.85 A7V, Alpha PEP66 /w Delta Fan, 10 x 100, STABLE!!! 4530
1000 1.80 Malay A7V with Chrome Orb 4542
1000 1.85 A7V w/256 MB infineon 4580
1000 1.85 A7V 256 MB infineon pc133 cas2 GWFOP38 & case mods 4581
1000 1.85 week31,Pencil trick Very easy OC. Pal306,Abit KT7,Artic Silver 4607
1000 1.85 AKBA0031WPEW KT7-RAID, Alpha PAL6035 4609
1000 1.80 Week 31 Abit KT7, Alpha HS/F, oh yeah! 4629
1000 1.85 on EP8KTA with Global Win FEP32 4639
1000 1.80 AKBA0029FPAW w/ AMD Retail HEATSINK 4671
1000 1.85 windows boot, but need more voltage to benchmark 4823
1000 1.85 AKBA 0027BPEW KT7; PAL6035; 36c w/SETI&P95; ducted air-cooled 4832
1000 1.85 Malay fop32 + power fun, max 42 celsius 4838
1000 1.85 Cooooooool 5095
1000 1.77 63 step 0 Abit KT-7R mb, 1.775v, 3.4v I/O, air cooled STABLE 5203
1000 1.77 63 step 0 Abit KT-7R mb, 1.775v, 3.4v I/O, air cooled STABLE 5204
1000 1.75 Week 31 With FOP32-1 runs at 44C under load. 5248
1000 1.89 FAST!!! 5253
1000 1.89 Water cooling, 10X mult,A7V,133 mem,GTS - FAST!!!! 5254
1000 1.85 Week 31 Use pensil to unlock. & Alpha Cooler 5263
1000 1.88 week34 f0p32 w/radio shack paste. 44c idle, 47c stressed 5280
1000 1.85 AKBA0031WPAW KT7RAID (sys. says 1.97V), FOP38, Stable 5374
1000 1.70 akba0036apew asus A7V rev 1.02 it will post at [email protected] but is rock solid at 1g 5445
1000 1.85 Using Global Win FOP 32-1 on Abit KT7 5717
1000 1.80 AKBA0031WPEW Abit KT7, GlobalWin32, Defogger Fluid 5816
1000 1.80 D600AUT1B Abit KT7, unlocked cpu, Alpha PAL6035. 37c/43c. 5955
1000 1.85 AKBA0031WPEW Haven't tested it fully. Think it will go higher. 5970
1000 1.85 unlock cpu 10*100 @58c Fan SN02 ,A7V 6052
1000 1.85 Water EK case (www.ek.nu) + ABIT KT7; máx. 35ºC 6158
1000 1.91 D600 AUT1B AKBA 0035 Alpha w/ Sanyo-Denki, posts@1050 but unstable 6223
1000 1.80 abit kt7a-raid 6282
1000 1.70 Abit KT7-RAID, Stock fan 39-42C, 4 mos. operation 6521
1000 1.85 I just a fine Pencil, Abit KT7 mobo, Coolmaster 6552
1000 1.85 KT7+fop32 + power fun, max 42 celsius 7074
1000 1.70 ABIT KT7 7079
1000 1.75 KT7 & Chrome Orb, 47°C at full load 7109
1000 1.85 air cooled 7158
1000 1.80 7167
1000 1.85 akba********* AMAZING! A7V, Stable 7998
1000 1.82 Work's stabil with the Abit Board and a big Cooler 8305
1000 1.95 Week24 10x100 on MSI K7TPro2A, SuperOrb (49Idle), Stable 8547
1000 1.70 Using Asus A7V and FOP38 cooler with artic silver 8565
1000 1.70 Week 31 Abit KT7 + FOP32 8790
1000 1.90 Week 32 Post's at 1050mhz but not stable, I run it @ 110*9 8819
1000 1.90 Week 32 Globalwin FOP38 max temp 34 celcius under p95 :smile: 8820
1000 1.85 Week 24 ASUS A7V+Chrome Orb+2 Case Fans 9118
1000 1.85 Unstable. 900 MHz rock solid, Gigabyte 7ZM, Alpha 9245
1000 1.80 Used Globalwin FOP32!! modified fan 9318
1000 1.85 ABIT KT7 POWER 9335
1000 1.80 FOP32 nothing else 9357
1000 1.85 FOP-32 Rock solid (43 degrees) 9362
1000 1.80 QDI KinetiZ 7T 9453
1000 1.80 Abit KT7 + standard cooler :smile: 9567
1000 1.80 AKAA0019MPMW Rock solid! Amazing chip! 9768
1000 1.70 stabil 12 Std. Dauerltest MSI kt7pro,Golden Orb 9771
1000 1.85 alpha pal6035 w/artic silver 9879
1000 1.50 Msi k7tpro 2 + Chrome Orb 10013
1000 1.85 I just a fine Pencil, Abit KT7 mobo, Coolmaster 10099
1000 1.70 orb fan, rock solid so far! 10281
1000 1.65 AKBA0031GPBW A7V, G.orb, 3DMARK for 2-days stable. 10290
1000 1.85 FOP32 + Full Tower Case 10364
1000 1.85 33 week 10467
1000 1.80 KT7 w/ Copper heatsink - stable! 10479
1000 1.80 10595
1000 1.80 ABIT KT7A 7 FANS, PEP66 COOLER 38 DEG.CEL RUNN 10608
1000 1.80 akba0034apdw Just Fantastic! 10610
1000 1.80 Just Fantastic! 10611
1000 1.77 AKBA0031 Abit kt7-Raid using Fop38-1 gforce mx det 6.35 10679
1000 1.80 Generic HSF, 10693
1000 1.80 Generic HSF, 10694
1000 1.85 runs benches fine - roxx 10712
1000 1.85 akba0026tpaw $66 chip@1000!!!!! 10724
1000 1.85 Maylasia KT7 cheap cooler from show used pencil to unlock 10726
1000 1.80 D600AST1B stable (tested Seti @W2K) 10729
1000 1.98 akba0034aplw Taisol CGK742092 koler and arctic silver 10792
1000 1.89 Stable, $9 Fan and heatsink 10958
1000 1.85 105*9.5 11132
1000 2.20 A7V volt modded, watercooled - had to have the gig 11168
1000 1.80 AKBA0029XPEW 7.5x133 on Abit KT7, ordinary cooler AVC-Megacool 11412
1000 1.80 Unlocked with pencil. 100% stable in 9x and 2k. 11498
1000 1.85 stable and good cooled 11691
1000 1.85 vio:3.5v L2:Dis. 10x100 water cooled 12051
1000 1.76 week 36 one giga no prob only needs more voltage..haven't 12193
1000 1.70 Abit KT7 raid, locked CPU with pencil trick on L1 12198
1000 3.00 12208
1000 1.75 MSI K7T Pro 6330 12222
1000 1.80 AKBA0035IPEW ABIT KT7 12239
1000 1.85 stable @ temp: 50 Fan: super orb 12314
1000 1.85 Abit KT7-RAID, TT Chrome Orb @ 107F 12670
1000 1.82 AKBA0027GPDW @1050 only post, a7v, globalwin fop32 12708
1000 1.85 week 37 12741
1000 1.85 KT7-RAID, FOP32, 48C, stable 12766
1000 1.60 Runs 1ghz @40 C (10x, unl.) OCZ monster II fan 12784
1000 1.85 AKBA0035BPGW Rock Stable, big noname cooler, havnt tried higher 12935
1000 1.85 0027APDW Stable but very hot h/sink:43C- idle,49C at stress 13143
1000 1.75 Blue Core Blue Core :smile:) @33 *C 13173
1000 1.65 Week 31 GW FOP32-1 fan 13186
1000 1.85 46C with load, FOP32 w/ 80mm fan on it 13286
1000 1.85 AKBA Stable, A7V, load: 48c, WBK 38+3 Case Fans 13407
1000 1.85 D600AUT1B Soltek 75KAV 7,5X133.3 Watercooling only 31°C 13516
1000 1.70 Epox 8KTA3 Aircooled, 41C load, 133 X 7. 13536
999 1.85 7.5*133 Abit kt7a 41c idle 747
999 1.89 AKBA0029CPDW MSI K7T 111 FSB 9X setting Normal air cool with c 5247
999 1.70 9x111 on A7V, almost a GIG! 13167
999 1.85 AKBA0033EPAW 9.0x111=999. Abit KT7, FOP38-1, 38C max 13177
998 1.85 Big-ass air-cooling 10885
997 1.90 week 26 Set at 1.85 on mb but at 1.90 in PcProbe (105x9.5) 7821
997 1.85 105x9.5 maybe limited by pc100 ram i'm using. Gorb 9857
997 1.80 runs at 45c under load....Big HSF. 10313
997 1.80 air cooled; max 46C 12651
996 1.92 epox8k7a will allmost make 1.09G-- running 6x166 5679
996 1.80 Week 27 KT7-RAID w/Hedgehog 238M HSF. Rock solid [H]ard 12751
993 1.89 week 32 A7V with Gorb, lock up when stressed at 1003 MHz 8726
990 1.85 9 X 110, 130W Tec w/ watercooling, not done yet... 7766
990 1.85 Aircooled, 110 fps on Abit K7T-Raid 12170
988 1.85 AKBA0036APEW KT7, Fop38 1322
988 1.85 On modded AZ-11. Early unlocked cpu. 5193
988 1.85 WEEK 31 I used Epox 8KTA+, 104*9.5 , STABLE W/ PRIME 95 6037
981 1.85 Global Win Fnp50, 9@109Mhz 5423
981 1.90 9*109 A7V and FOP-32 9323
980 1.85 KT7 raid 3451
980 1.85 Week 29 105 X 9.5, Abit KT7, 128 Mb PC133, Alphapal 6035 4547
980 1.85 103 x 9.5 with a Global Win FOP38 6563
980 1.85 ABIT KT7 Raid 9326
980 1.90 ABIT KT7 Raid 9327
980 1.85 103 x 9.5 with a Global Win FOP38 10104
980 1.85 Abit KT7-raid, FOP-32, ArticSilver 10788
979 1.80 AKBA0027BPDW A7V/PEP66mod'd/256MushkinPC133/GForce2MX/will go + 6152
979 1.83 Abit KT7 + 2*12cm cooling ROCK STABLE. post@1000 7083
979 1.85 AKCA0045MPM Soltek SL-75KAV Volcano II+320MB-NCP+Infineon+2Case fans@(140x7) 11947
978 1.92 103*9.5, water+compessor cooled, CPU temp-4C..+7C 1718
978 1.85 Fop32, 14 hours with Stabtest, 103*9.5 ca50C 2157
978 1.80 D600 AUT A7V 103*9,5; modified Alpha PEP66; 49 °C 4612
978 1.85 Unlocked. Running at 9x115 on a KT7-Raid. 100% load = 44C. 12251
978 1.82 abit KT7 with FOP32 - Rock Stabil NP! 12773
978 1.60 AKBA0034APKW 103x9.5 Titan M5AB cooler. 13117
975 1.60 Hedgehog with 85watt TEC - 60 degrees F :smile: 3698
975 1.85 A7V and Modified Alpha PAL35T FCPGA Cooler 10224
975 1.92 FSB139x7.0 - KT7A-RAID MB, peltier/air cooled. 10511
972 1.75 AKBA0031FPAW 9x108 (972Mhz) stable in Windows, 1050 Max 3476
970 1.85 Abit kT7 PC100 Memory. Cooler Master Fan. 5264
970 1.85 pcnut super duron win 32 9439
970 1.70 Abit KT7-Raid 9.5 x 101Mhz bus 13543
969 1.92 AKBA0032PCW preparing hire voltage modify... want pass 1 GHz!! 1367
969 1.80 Asus A7V, 9.5x102 12913
966 1.84 AKCA0045MPM 138x7 MB SOLTEK SL75KAV Infineon@138CL2 t45Cmax 8334
965 1.85 CaseMod, CoolerMaster CF5-5G11, ABit KT7, 45°Cmax 4830
965 1.80 week 33 53 Celsius-standard cooler 5987
964 1.85 Abit KT7 : 9.5x multiplier, 101FSB 12780
963 1.91 AKBA Biostar M7vkb 9x107 512
963 1.75 Not quite stable. 9*107 and Titan Majesty m5ab. 8818
963 1.77 AKBA0031WPEW Chrome orb, 42c 10686
963 1.80 week 27 107 x 9.0x better than 100 9.5x 12219
963 1.95 Week 32 AKBA 9x107 Chrome Orb w 11,000RPM!!! fan on an Asus A7V 12685
963 1.82 AKBA0027CPAW 92003230624, ABit KT7 107x9 1.825v only 13145
963 1.82 AKBA0027CPAW 92003230624, ABit KT7 107x9 1.825v 13146
962 1.92 AKBA0032TPCW max 962,stable at 950 > ABIT KT7,need more voltage 9337
960 1.80 Week 31 9.5x101, 1G boots, but Prime95 has errors at 969+ 4521
960 1.85 A7V@113*8.5,mem@150c3. Rock solid! 59C max 8984
960 1.85 week32 K7T Pro, Titan D2TB 9129
960 1.85 AKBA KT7A raid perfectly stable, taisol copperbased cooler 12425
959 1.81 9.5 * 101 5334
958 1.55 3DMark2k OK, but PiFast fails... Temperature 45C. 6072
954 1.85 KT7 Modified-GORB STABLE 4627
954 2.00 Runs stable, at 40 degrees C at 2.0 volts on KT7 8304
954 1.75 rock solid, kt7, vantec hs/f, 36C idle/44C load 10303
952 1.77 AKBA MSI K7T Pro 2A 8.5*112 6232
952 1.93 Soltek SL75KAV 7 X 136 KM PC150 37C 9915
952 1.80 AKBA 0029XPAW 112*8.5, mem+33, Stock HSF, KT7 10472
952 1.83 Week 26 of Y2000 Stable on Abit KT7, FKP32 + 1 fan, core temp 45 C 13161
950 1.75 Epox 8kta+ 40* with orig. HSF and High Performance therm. pst 508
950 1.70 Week36 Alpha PAL6035, 42 on load 634
950 1.75 1588
950 1.85 akba00032uph? aircooled with Corb@118f 1960
950 1.75 abit kt7a w/Alpha pal6035+delta38 1988
950 1.70 AKBA 0035 CPNW 48* mobo temp 29*, StackedFan HS,5300rpm+5100rpm 3715
950 1.75 kt7 raid, 128mb cas3 PC133, FOP32 4184
950 1.85 Malaysia Wk 29 4537
950 1.65 week 29 pretty stable, running at 105 idle - retail coolin 4541
950 1.85 Stable 59 deg though with Platinum Orb, A7V 4666
950 1.85 Golden Orb, Prime95 stable 4824
950 1.85 Stable watercooled w/o TEC's; 9.5. post 1010 w/TEC 5083
950 1.85 Retail CPU + Retail HS/fan; Solid like a rock 5130
950 1.85 Abit KT7 with Majesty, at 1000 win2k doesn't start 5152
950 1.85 abit kt7, fop32-1, extra fan 3" @ rear, 41degrees 5392
950 1.70 AKBA0033BPAW Rock Solid. Majesty M5Cooler, KT7. Easiest OC ever 5424
950 1.75 Rock-solid with standard Coolermaster 45-48 cels. 5707
950 1.90 stable 100% 5971
950 1.80 Abit K7T + G Orb, 57oC, boot at 1G but unstable 5997
950 1.80 Solid 9.5x100. POST@1GHz, but no Win. Will try FSB 6021
950 1.75 too lazy to check KT7-RAID - Modified FEP32 heatsink 6048
950 1.82 Globalwin FOP32, 44C at idle, 47C after quake3 6051
950 1.85 978 99% stable (3d mark quits but no freezes) 6088
950 1.80 Abit KT7 + Standard cooler.Not one crash in 2weeks 7057
950 1.80 AKBA0032PMBW KT7 RAID, FOP32 used, FOP38 made no diff to oc 7106
950 1.87 i used the diamond cutting method for overclocking 7305
950 1.62 7682
950 1.85 8114
950 1.75 AKAA0027UPAW A7V + Duron 8306
950 1.65 Stable as. 9.5 multi, 100mhz FSB 8524
950 1.70 Abit KT7 & FOP32 8710
950 2.90 SweeeeeT Stable! 9233
950 1.72 Fam.6, Mod.3, Step 0 [email protected], IO voltage @3.40, Abit KT-7 RAID mobo 9371
950 1.85 freon + 52w peltier 9750
950 1.85 Crashes MadOnion at 1 Ghz. Alpha heatsink used. 10318
950 1.70 A7V + pencil, week31 std cooling absolutely stable 10798
950 1.60 just multiplicator and chrome orb, stable at 51°C 10919
950 1.75 week 33 Watercooled 11661
950 1.75 Globalwin FOP-38. 12168
950 1.85 Stop in CMOS environment in 1000HMz 12199
950 1.70 Mobo Asus A7V, Globalwin FOP32. CPU temp. 44C. 12249
950 1.75 KY7-RAID, FOP38 35c, 37c 12252
950 1.91 Cooled with FOP38 on Abit KT7(non-RAID) 12300
950 1.85 63C at full load, super orb, A7V, posts @1ghz 12495
950 1.75 AKBA 0036RPDW A7V,FOP38,chassis closed, 114F degree 12623
950 1.85 12704
950 1.80 Rockstabil a 51c Max 12761
950 1.70 Rock Stable 13022
950 1.70 stable. now done seti@home 24h.. a7v + majesty 13166
950 1.85 week 33 Titan Majesty M5AB, temperature stays under 50 c 13187
946 1.85 @44c 4812
945 1.65 A7V, Chrome Orb, 2 120mm panaflos, 2 92mm panaflos 4513
945 1.82 Pencil-unlocked, on Asus A7V at 105 x 9.0 w/ 1.82v 5237
945 1.75 AKBA0033BPBW ABIT KT7 105 FSB * 9.0 temp 36+°C 5979
945 1.60 AKBA 0034 APKW MB A7V needs better cooling for 1G 5984
945 1.85 AKBA0029TPBW 9 x 100, FSB+5, FKP32 @ 56c 7893
945 1.85 92046330027 Asus A7V, 9x105, Alpha PAL6035+Delta 38CFM 8700
945 1.75 Asus A7V,9x ,105fsb,Rock Solid 8810
945 1.70 KT7 & Golden Orb 10155
945 1.75 T´t SuperOrb (50ºC)-105 - VIO-3,56V - Asus A7V 12089
944 1.85 118 FSB x 8.0 Multiplier, kt7a, justcooler 1515
944 1.85 Stable in closed Case, Orb cooling 13255
943 1.88 Home made water cooler :smile: 12928
941 1.89 8.5x110.7, Chrome orb, temp=ambient+17C 100% load 12253
940 1.80 AKBA0027GPCW This CPU kicks ass !!! 1407
936 1.75 epox 8kta3 - air cooling 6139
936 1.75 akba 9x104@46C ! sl75jv KICKS ASS 6856
935 1.80 Asus a7v + Global Win - L2 disable = 977 mhz 1,8v 3444
935 1.50 week 35 with TaiSol cooler ,tested seti@home,very stable 3942
935 1.60 D600AUT Week 31 110*8.5 (Taisol cooled)Runs Prime95 whole day 4556
935 1.82 AKAA0022BPCW A7V 8.5X 110 MHz FSB 9629
935 1.80 Clock Locked OEM 8.5 X 110 on ASUS A7V Running WinMe 9738
935 1.85 A7V (w/ jumpers) WinMe 9758
935 1.79 Week 32 935/110bus. 42C w/standard EKL fan 10701
935 1.82 Week 32 stable 950 (9.5x100) 45C w/standard EKL fan 11631
933 1.80 MSI KT266A 847
933 1.70 AMCA0050MPM KK266,FOP32 w/40cfm fan 50C load 1439
933 1.80 Week 23 gets damn hot 11099
931 1.70 amca0050mpm 1438
929 1.75 v33 KT7 9x103 + GlobalWin POP32, posted in 1001 not st 1966
929 1.80 week 31 FOP32-1 @ 48 - 51c. Perfectly stable. 9354
927 1.85 Home grown water cooler, 32c-45c 4518
927 1.80 week 27 A7v, PAL6035w/delta fans on top of heatsink 5225
927 1.80 week 27 A7v, PAL6035w/delta 3 fans on top of heatsink 5226
927 1.80 week 27 A7v, PAL6035w/delta 3 fans on top of heatsink 5227
927 1.85 too lazy to check Made in malaysia 8285
927 1.85 too lazy to check multiplier 9 x 103fsb (stock fan) 8286
927 1.70 Week 32 Chrome Orb on KT7 13130
920 1.80 8x115 @ 48C - rock solid 4839
920 1.80 X8.5 107/33 Abit KT7, chrome orb 48 °C, work fine 5102
920 1.61 115 x 8 on ABit KT7 Raid, rock solid, 37-40 deg C. 8007
918 1.73 AKBA0033APAW 102x9 on a Jetway 663AS, modification on chip 3522
918 1.85 week 28 Taisol CGK42092; A7V 3533
918 1.85 10014
918 1.78 gets hot, sometimes unstable at full load 11468
918 1.70 This baby rocks!!! 11720
915 1.70 rock stable 5256
914 1.89 8.5 x 107.5 Abit KT7 Raid 40C Idle-45C Full 12754
914 1.80 Week 32 AUT1B Abit KT7 Raid 12772
910 1.62 140x6*5 3850
910 1.70 5120
910 1.85 AKAA Watercooled...bad chip 8074
910 1.85 AKAA Rock Solid, using a cheap heatsink/fan. 12653
910 1.85 week 21 (unlocked) A7V (8.5x107) 13133
910 1.75 Stable 50C to 54C NO PROBS. 8.5x107 asus a7v 13298
909 1.55 Standart Cooling, about 130°F, 107FSB, 8.5x 4841
909 1.80 A7V, 8.5x107, Air Cooler, Stable Max/Idle Tem50/31 5998
909 1.63 WEEK 35 PBW cOULD GO HIGHER? 12695
909 1.75 AKAA0022MPMW 13140
908 1.75 On a asus A7V, with a GlobalWin FKP32 3948
908 1.92 unlocked duron 600 with A7V r.1.01 watercooled 9683
904 1.65 week 23 a7v +pencil hack 8 x 113mhz GlbWin FDP32 9794
901 1.80 105+1x8.5, KT7-RAID 4623
901 1.65 Yes its true.. my system is stabile with 1.65 core 5223
900 1.65 13619
900 1.80 AKBA 0034APLW A7V133 9*100 62C 1149
900 1.60 rock stable 1744
900 1.60 A7V normal fan. 57C. Rocksolid!!! had to close L1 1747
900 1.82 akba0028gpaw mod. ga-7zx fep32 backwards 54c post at 1000 2136
900 1.91 perfectly stable, I will try 950/1000 with fop38 2175
900 1.75 Week 30 2185
900 1.79 45C - 53C 2217
900 1.85 Week 21 Asus A7V, Alpha PAL6035 2270
900 1.75 Just Original Fan/Heatsink using ABIT KT7-RAID 3235
900 1.85 3243
900 1.75 Week 27 3372
900 1.75 Week 27 3373
900 1.75 Week 27 Using Chrome Orb (lapped) w/ Arctic Silver. 3374
900 1.80 Week 33 Abit KT7-100 /w CoolerMaster HSF 3439
900 1.70 kt7,chromeorb max 53 c 3567
900 1.75 MSI K7266 Pro-R 4139
900 1.60 AKBA0036RPAW Asus A7S-VM, Matrix hsf, very stable 4455
900 1.77 Abit KT7,CoolMaster,Thermal Compound,45C max load 4595
900 1.80 week 29 Stable but runs very hot @ 118 * F 5090
900 1.75 Green Std HS- rock solid. Ran UT @945 for a while. 5105
900 1.65 Week 32 Sweet stable@900 - 1.625 V (KT7-Raid) 5166
900 1.70 week 29 Epox 8KTA+ 36 DegC CPU 5167
900 1.65 0028D Rock Solid 5190
900 1.70 week 32 alpha 6035 - 40c w/ load 5192
900 1.65 kt7 fop32 duron cost $45 5230
900 1.85 Abit KT7-RAID, Alpha PAL6035 5271
900 1.91 D600 AST1B AKBA 0027 SuperOrb, posts@950 but unstable 5363
900 1.60 Completly stable on an Abit KT7 Avg of 32c 5962
900 1.95 week 29 GIGABYTE:GA-7ZX - mod the tiny bridges 6009
900 1.45 KT7 - Raid and standard cooling*****WOW**** 6043
900 1.75 Rock Solid, Never crashed. A7V, Alpha HSF, 50 deg 6046
900 1.65 Malaysia Normal cooling (3dfxcool) can prob. go higher 6053
900 1.85 AKBA0028BPBW Very stable. Need better heatsink for a gig. 6058
900 1.80 FOP-32 KT7a RAID. runs 950 not stable in prime95. 6694
900 1.75 ASUS A7V, Chrom Orb 6945
900 1.85 rock solid after two weeks of compressing DivX vid 7005
900 1.80 AKBA0030SPBW KT7, PAL 6035, boots 1G but fails Prime 95 @1.85 7087
900 1.85 KT7 w/ UL, week 29, Majesty M5AB 7088
900 1.80 Lapped FOP38 HSF slower fan though 7098
900 1.63 Standard heatsink & fan, 48 degrees celcius. 7243
900 1.80 Air cooled; Cheap HSF 7923
900 1.75 KT7 RAID, pencil, plug, power 8302
900 1.65 asus av7 8636
900 1.70 AKBA 0029TPBW ABIT K7T-RAID 8708
900 1.70 AKBA 0029TPBW Pencil on L1, Thermaltake 462, Room=31C, CPU=44C 8709
900 1.85 Stable, using A7V + titan majesty 8723
900 1.50 Week 29, Malaysia Aircooled, on Asus A7V 8745
900 1.65 Week 29 ABIT KT7-RAID Copper Heatsink + Fan 8793
900 1.85 Golden Orb stable w/ prime95 8807
900 1.70 golden orb 8838
900 1.70 Multipler:9 I did it like Tomshardware 9227
900 1.70 Week 29 XPAW KT7, FOP32-1, 37C-43C, Rock Solid 9551
900 1.80 ASUS A7V, reads 1.85V, 52C under load,modif. G.Orb 9612
900 1.75 Tripple Fan 9748
900 1.70 GloablWin FOP32 45-47'C on A7V, rock solid 9798
900 1.70 akaa0026bpmw 9814
900 1.60 akba0030rpaw alpha pal6035 cooler temp 43c idle 49c under load 9845
900 2.10 9897
900 1.70 Standard Cooling 10482
900 1.75 bridged L1 with led pencil 10643
900 1.85 week 22 462 Gorb, 52 cel. 10649
900 1.85 stable at 850, flaky at 900... generic air-cooled 10671
900 1.80 10699
900 1.80 10700
900 1.75 alpha pep(mod) still figuring out, old bios... 10710
900 1.80 AKAA0021BPGW A7V + majesty m5ab. 10732
900 1.65 akba0036apaw_aut1b sl75jv-950 workin to but on 1,775, 900-1,65@50C 10866
900 1.80 using ALPHA 6035 wYS Tech fan 11686
900 1.78 KT7-133, M5AB, 44-52°C 12206
900 1.65 9x100, ASUS A7V, corb 12211
900 1.60 AKBA920035IPEW ALPHA 6035MUC YS TECH FANCOPPER SPACER FORSOCKETA 12234
900 1.65 Won't work with the multiplier set at anything but 12312
900 1.70 Week 30 KT7-RAID, Cooler Master DP5-5G11, 49C 12646
900 1.79 Stable so far 12652
900 1.80 AKBA0029xpdw 12678
900 1.70 stable a7v with stock fan 12680
900 1.75 9.0x100mhz GlobalWin FEB32 cooler 12757
900 1.65 12782
900 1.75 Rock solid will not go any faster 13047
900 1.60 week 32 abit kt7 & g-orb, temp 43-46C 13128
900 1.75 week 29---KT7 13132
900 1.85 ASUS A7V with Global Win FOP32 fan 13135
900 1.80 Week 33 Abit KT7 + Normal Heatsink (cm) 13159
900 1.60 13207
900 1.70 Damn it's rock solid on my A7V and Golden Orb 13211
896 1.70 AKBA 0029XPAW 112*8, MEM+33, Stock HSF, Abit KT7 10471
893 1.71 AKBA0029UPCW - w33 51 celcius at full load. Standard fan/hetasink! 3943
893 1.80 Week 31 Vantec Big Blue Cooler 6092
892 1.90 8.5x105 ; 900 boots but instable ; Asus A7V 3259
892 1.75 Super Orb - 3 fans in case 8141
888 1.60 proc hates voltage, 111MHz@8 on A7V 13688
888 1.85 Abit KT7, 8x 111fsb, 36°c/93°f Full load 3564
888 1.85 very hot 60C ++ 3937
884 1.65 without problems,... Asus A7V 13420
880 1.85 week 21 Modified MSI K7T, http://www.algonet.se/~cyrano/ 4301
880 1.70 Reached the limit, stable + high performance 4817
880 1.65 CPU Is Unlock CT-AJA7 8*110 11346
876 1.70 Week 21 ABit KT7, Global Win FOP32, 46C at full load 4821
876 1.70 Week 22 unlocked on a Soltek 75KV, homemade ocdevi 10235
876 1.69 wont boot any higher than this. Runs at 54C under 10916
875 1.80 8.5 X 103 on A7V 1.01 and Alpha PAL6035 at 50C 8747
875 1.85 AKBA0037CPAW 12777
872 1.89 109*8 on a A7V, golden orb rocksolid. BOW DOWN 1755
870 1.85 Week 22 MALAY A7V, Pencil, Nxt Stp Voltage Mod 13197
866 1.89 AKBA Week 29 Abit KG7 133x6.5, Taisol 742092 w/80mm Tt , 118F full load 13701
866 1.65 Soltek 75KAV Stable 133 x 6.5 890
866 1.65 MSI K7T Turbo, FOP 32, Full-load: 45 degrees :smile: 11050
866 1.63 MSI K7T Turbo, 133 x 6.5, FOP 38, load 37c . 12871
864 1.88 AKBA 0029XPAW Abit KG7 144x6. Taisol 742092 w/80mm Thermaltake on adapter 558
864 1.70 6.5*133 7369
858 1.80 Asus A7V, twincooler 1986
858 1.80 3657
858 1.85 Use Chrome Orb.. temp around 48Deg C. Freq 8.5X100 12245
858 1.53 LOCKED ASUS A7V 1100MHZ FSB 8.5 X STABLE AS HELL 13163
856 1.75 107x8Mhz in a MSI K7T. steady at 40C. FOP32 5179
856 1.85 FSB = 107 multiplier= 8,0 MB: ASUS A7V 9689
850 1.69 Screaming At 850!!! Will sell for $200 1091
850 1.65 work's stabil, but the temparautr 1752
850 1.65 Abit KT7-Raid 850MHz with Noname cooler 1753
850 1.72 KT7, GW FOP32, 38C Max. 1929
850 1.70 D600AST1B Abit KT7, GW FOP-32, 30C Max. 1949
850 1.85 Week 22 A7V 100x8.5 Aplha 6035 2135
850 1.75 akaa0026mpmw Died after 10 days ,alpha 6035 low 50's Dont know 3064
850 1.70 stable as hell never crashes 3477
850 1.85 Abit KT7 Taisol CGK742092 cooler 3915
850 1.65 892 MHz unstable A7V with dip's 4553
850 1.65 892 MHz unstable A7V with dip's 4554
850 1.80 WEEK 32 36C°, FOP 32, KT7-RAID 4615
850 1.75 Used standard thermal paste, chrome orb / kt7 4805
850 1.80 KT7, Chrome Orb, 44C. Posts@1G, WinME "runs" @950 4814
850 1.90 Week 22 Asus A7V, Apha PAL6035 30-40C 5219
850 1.80 Week 21 (8.5x100) Alpha PH6035 heatsink; Asus A7V 5992
850 1.65 Global Win FOP32, POST @950/1.60volt 6000
850 1.60 A7V normal fan. 53C. Rocksolid 6024
850 1.85 DAMM just only 850 100*8.5 with abit kt7 6056
850 1.75 KT7-RAID PELTIER+NORMAL HS&F, WILL GO FOR 950 WITH NEW FAN 6071
850 1.75 Week 33 Rock solid. Did not try 900 or 950 yet :smile: 6090
850 1.85 ABIT KT7 6091
850 1.85 FOP38-7k 35c idel 42c max, wont go any faster 7093
850 1.75 Steady as a rock!!! 7677
850 1.85 Stable & fast, runs 50'C+ all the time 7789
850 1.60 8.5x100 rockstable on Asus A7V 8683
850 1.85 D600AST1B AKAA 0021B A7V, Gorb, Unlocked, 8754
850 1.80 Week 22 ASUS A7V with jumpers 9232
850 1.80 early week 9441
850 1.60 Stable-Boxed Proc/KT7/Stock Heatsink&Fan 9454
850 1.70 ASUS A7V 9630
850 1.75 Week 27 Modded FIC AZ11 9649
850 1.84 9671
850 1.75 8.5x100, tried 8.5*105 but prime95 reports errors 9736
850 1.80 Pencil Unlocked on A7v 9800
850 1.65 Stable, water cooled 47C avg 9867
850 1.65 KT7-RAID,42 to 45C w/Gorb and heatsink compound 9868
850 1.60 nemtom ASUS A7V r1.02 just tryin' 900 10466
850 1.55 unlocked with pencil: boxed heatsink/fan 10704
850 1.85 very stable...but HOT!!! 11464
850 1.75 31 week KT7-RAID noname cooler, t=65..70 © 11995
850 1.80 12185
850 1.82 Running 850 no problems will try 900 later. ROCKS! 12254
850 1.60 Very STABIL 12682
850 1.85 week 36 from memory 100% stable, 52C, default hs/fan. going for 1GHz 12727
850 1.80 12736
850 1.65 A7V rev1.2, w/ChromeOrb max.55^C, rock stable! 12927
850 1.60 Asus A7V, chip unlocked. Like a rock. 13120
848 1.75 10725
840 1.65 AKAA0021F0021FPBW A7V 1.01 Bios 1.03, Coolermaster HSF,PC133 CL3 SDR 1716
840 1.75 a7v :smile: 4049
840 1.70 Very stable, Majesty M1AB, A7V, unlocked 5091
840 1.60 MBO - Microstar K7T 6016
840 1.65 8*105MHz on MSI-6330 Did it like Tomshardware 7782
840 1.50 FOP 32, A7V, def. Vcore, 8*105 8698
840 1.65 watercooled but peltier isn't working! Rev.2 soon! 8704
840 1.85 OEM, Clock Unlocked A7V, 8.5, with 105 fsb. Air cooled. 8725
840 1.85 AKAA0023EPCW Abit KT7A 140*6 Vio=3.60 9955
840 1.85 using ASUS A7V w/multiplier control 11246
840 1.65 AKCA-Y Cool!!!! 13000
840 1.80 Manual L1close,can't boot OS, coolermaster@58C 13178
832 1.65 AKBA0033APAW 104x8 on a Jetway 663AS, modification on chip!!! 9934
825 1.50 110x7.5, A7v 1745
825 1.55 EPOX 8KTA, 200% stable, CPU-Temp: 43°C, 7,5x110 3469
825 1.70 (7.5x1.10) A7V+Socket A Golden Orb STABLE 5182
825 1.67 Used pencil trick. Abit KT7,Globalwin FOP32,128Mb 13127
824 1.85 AKA 0027GPA A7V 103x8 Aplha 6035 4194
824 1.75 Asus A7V, Gorb, 8.0x103FSB, stabil 5268
824 1.75 Asus A7V, Gorb, 8.0x103FSB, stabil 5269
824 1.75 Very, very, stable. 10295
824 1.75 Asus A7V, Gorb, 8.0 x 103FSB, stabil 10800
824 1.85 AKAA 0022BPMW A7V 1.05 8x 103 UNLCOKED WITH PENCIL ALPHA PEP66 12821
819 1.50 117*7,abit KT7,air cooled,48 to 52°C 12933
816 1.75 Pencil trick, golden orb, 102 bus speed. ASUS A7V 5141
808 1.80 Asus A7V 10716
807 1.80 Rock Solid on A7V 5176
800 1.67 Ecs K7VZA FSB = 133 mhz 763
800 1.85 rock solid. asus a7v. no multiplier lock 2272
800 1.85 With homemade OC-device 4294
800 1.70 Completely stable, Vantec fan+A7V 4637
800 1.50 L1 Bridge closed with pencil Stable 48-56°C 5111
800 1.50 Rock Solid, even at stock voltage. With GoldenOrb 5121
800 1.85 AKAA0021BPFW 9158316 A7V 1.01, Gorb, open case, 57C 5136
800 2.00 AMD Duron 600 ASUS A7-V & VIA KT133 5155
800 1.60 KT7-Raid, unlocked with pencil 5244
800 1.90 runs very hot with golden orb,65C 6005
800 1.55 6*133 on epox 7250
800 1.70 43C (27C amb.) on Abit KT7, does [email protected] 50C+ 7372
800 1.85 AKAA Bought from anonymous guy :sad: 7586
800 1.62 Abit KT7 + Titan M5AB Idle : 39°C / working : 42°C 8802
800 1.60 A7V, rockstable (connected L1-bridges) 8830
800 1.60 Rocks stable with A7v and Spire cooler 8930
800 1.60 stable 9298
800 1.65 retail retail heatsink 9330
800 1.68 Locked CPU, Stable, Orb fan, going further, C56-58 9352
800 1.85 Idle 45.5º/ Active 50+º Coppermine Heatsink + Fan 9734
800 1.62 AKBA 0028RPBW 100%,KT7-Raid,40`C,CromeOrb-more to come 10288
800 1.75 Using a small heatsink and fan CPU temp @ 40C 10663
800 1.80 won't go higher with multi, might with some fsb 10666
800 1.70 10672
800 1.70 KA266-R 133 x 6.0 8cm fan 11373
800 1.75 AKBA0028BPCW KT7-RAID, Alpha 6035w/Sunan Idle 40 Active 45C MAX 12224
800 1.70 12696
800 1.63 Abit KT7 100x8 (bios 1.55v) -52C Golden Orb Fan 12753
800 1.70 Week 21 12925
800 1.65 Week 32 CPU Great CPU&KT7-RAID, limited by 235W PSU, L1 cls 13204
780 1.70 104 * 7.5 12317
775 1.60 Unknown won't go higher than 6.5x but fsb is at 119 13142
772 1.65 A7V, 7.5x103, no boot@800 no matter voltage 8739
772 1.60 (1v665 according BIOS) 9746
750 1.60 NOt a single crash, need more voltage to go higher 2274
750 1.60 800 wont go, crappy fake golden orb 4614
750 1.60 Unocked,ABit KT7,53°C,CoolerMaster DP5-5G11P 5069
750 1.50 A7V, unlocked with a pencil, cant get 800 to stick 7101
750 1.76 Very Stable Temp 56'c ,Linked L1 with Conduct.Pen 8797
750 1.60 retail ASUS A7V Flash bios revision 1004c 9356
750 1.75 unlocked bridges from factory 9645
750 1.70 voltage unlocked Asus A7V + Globalwin Fop32 - burn in, it'll go + 9707
750 1.85 quite stable... running at 1.65 vcore. 10675
750 1.50 100% Stable, need better grease for higher speed 10702
748 1.70 Still within votage spec as not to void my warrant 13124
720 1.55 Asus A7V, CoolerMaster @ 6500 rpm, stable @ 45C 12172
715 1.50 0027 6.5x110 still to slow for me 1726
702 1.60 Using MSI MB, stable at 702 9240
700 1.50 HeatSink/Fan cooling only. 110F after gaming. A7V 5117
700 1.65 stable 8674
700 1.60 9316
700 1.60 ABit KT7+coller Global Win FHP08 9317
700 1.60 CPUmark99 - 60.8 9638
700 1.60 CPUmark99 - 60.8 FPUmark99 - 3820 mobo FIC AZ11 9640
700 1.60 KT7-RAID and OCZ Socket A Cooler - 107 Degrees Id 12660
690 1.60 Standard Fan,115 FSB, 100% Stable(2days), A7V m/b. 2222
688 1.60 aopen mk33 7059
682 1.85 akba0027vphw 105x6.5 post at 110x6.5 but crash in win98se. 5181
678 1.50 10228
677 15.0 O/Ced w/ changing only FSB 10211
666 1.60 MSI K7T-PRO 6.0x111Mhz 9772
666 1.60 unknown MSI 6330, very occasional lockups, maxed voltage 11181
660 1.65 3604
660 1.65 Runs fine, still testing to see if it;s stable... 4272
660 1.60 MK33, leaving case sides all open (loud! :smile: 4364
660 1.60 Standard volt, increased fsb 110mhz 6711
650 1.75 6.5 multiplier on KT7-RAID 12223
648 1.60 AZ-11,Gorbe, Super Stable 23C(73F)need Multiplier! 7881
642 1.50 107*6 MSI kt7 pro 4264
642 1.56 Retail Fan, wouldnt go any higher than this. 4266
642 1.50 9236
642 1.50 6x107 Locked Multiplier 9651
636 1.53 7205
630 1.60 GA-7ZM, 6x105, Stable, Posts 702 - still testing 9324
612 1.70 No problems 5210
600 1.52 7403
600 2.61 akba0033gpew 12830
