Hvor stor TV skal du ha?
@CasterAnd: 2,5, ikke 3.
Wiki - Optimum HDTV viewing distance
1080P does matter
HDTV Setup
"One of the more popular recommendations on the proper HDTV viewing distance is multiply the diagonal measurement of the display screen by 2.5."
Utregning: 50" * 2.5 = 125 inch ~ 10.4166667 feet = 3.16992 meters (Perfekt størrelse hjemme) :D
"For consumer application of their recommendations, THX recommends dividing the diagonal screen measurement by .84 to calculate the optimum viewing distance, for a 1080p resolution." Dette er basert på en max synsvinkel av 40 grader.
If your HDTV is going in a living room with limited space, THX recommends the following:
35 inch class TV = 3.5-5 feet away
40 inch class TV = 4-6 feet away (Nøyaktig 40" / 0.84 = 47,61 inch = 3,9675 feet = 1,209294 meter.)
50 inch class TV = 5-7.5 feet away (Nøyaktig 50" / 0.84 = 59.5 inches = 4.95833333 feet = 1.5113 meter.)
60 inch class TV = 6-9 feet way (Nøyatkgi 60" / 0.84 = 71.42 inches = 5.95166667 feet = 1.814068 meters.)
*Viktig*
It might seem that THX is recommending a very large screen size for your room. But, it’s important to note two things: 1) THX screen size recommendations are based on recreating an immersive cinematic experience, and 2) the biggest complaint among TV buyers is that they wish they had bought a bigger set. ;)
*snip*
Men ikke glem:
For de aller fleste, med 'normal' avstand til TV'en i stua, og som ikke er altfor opptatt av at alt skal være størst og dyrest, vil en 32 tommer gjøre jobben helt utmerket.
Måtte sjekke dato på dette innlegget - trodde det var skrevet før år 2000.
