Lurer bare på hva dette er...
Har fått opp noen filer på skrivebordet mitt, det var først ei fil, men nå i dag har det komt 4 nye (alle filene er notisblokk) :S navnet på filene er hs_err_pid7888, hs_err_pid5468, hs_err_pid6840, hs_err_pid5784 og hs_err_pid5576
Hva er dette, og hva skal jeg gjøre?
--------------------------------------------------Dette er innholdet til den førte filen jeg fikk:-------------------------------------------------------------
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6d8fd56c, pid=5576, tid=3132
# JRE version: 6.0_21-b07
# Java VM: Java HotSpot Client VM (17.0-b17 mixed mode, sharing windows-x86 )
# Problematic frame:
# V [jvm.dll+0xfd56c]
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
--------------- T H R E A D ---------------
Current thread (0x0680f800): JavaThread "Java2D Disposer" daemon [_thread_in_vm, id=3132, stack(0x06e20000,0x06e70000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x00000000
Registers:
EAX=0x0263f428, EBX=0x00000000, ECX=0x00000000, EDX=0x06e6f828
ESP=0x06e6f818, EBP=0x06e6f8f4, ESI=0x026800e8, EDI=0x0680f800
EIP=0x6d8fd56c, EFLAGS=0x00010203
Top of Stack: (sp=0x06e6f818)
0x06e6f818: 0680f800 0680f918 02630b08 2802efd8
0x06e6f828: 0263f428 06e6f848 6d808e5c 00000001
0x06e6f838: 2802efd8 6d808e64 0680f800 2802efd8
0x06e6f848: 06e6f86c 6d808ef5 0263f434 2802efd8
0x06e6f858: 00000016 00000025 0680f800 00000016
0x06e6f868: 0263f434 06e6f890 6d9ea6ad 06e6f888
0x06e6f878: 6d9b6040 00000019 000014dd 0000002b
0x06e6f888: 00ac86e8 6d8a01d2 000014dd 0263f424
Instructions: (pc=0x6d8fd56c)
0x6d8fd55c: 01 8b 4d b0 8b 55 a4 8b 45 f4 89 04 8a ff 45 b0
0x6d8fd56c: 8b 03 8b 48 08 0f b7 51 2a 8b 40 0c 8b 4c 90 24
Stack: [0x06e20000,0x06e70000], sp=0x06e6f818, free space=13e06e6f34ck
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
V [jvm.dll+0xfd56c]
V [jvm.dll+0x1003c7]
C [awt.dll+0x6c71c]
j java.awt.Cursor.finalizeImpl(J)V+0
j java.awt.Cursor.access$000(J)V+1
j java.awt.Cursor$CursorDisposer.dispose()V+13
j sun.java2d.Disposer.run()V+26
j java.lang.Thread.run()V+11
v ~StubRoutines::call_stub
V [jvm.dll+0xf3abc]
V [jvm.dll+0x1865b1]
V [jvm.dll+0xf3c87]
V [jvm.dll+0xf3cfd]
V [jvm.dll+0x11dac0]
V [jvm.dll+0x1e6fb4]
V [jvm.dll+0x185f5c]
C [msvcr71.dll+0x9565]
C [kernel32.dll+0x4d0e9]
C [ntdll.dll+0x416c3]
C [ntdll.dll+0x41696]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x06839400 JavaThread "Thread-3" daemon [_thread_blocked, id=6660, stack(0x078a0000,0x078f0000)]
0x0683a800 JavaThread "AWT-Shutdown" [_thread_blocked, id=4836, stack(0x07060000,0x070b0000)]
0x06837000 JavaThread "Timer-2" [_thread_blocked, id=2076, stack(0x06580000,0x065d0000)]
0x06836c00 JavaThread "Browser Side Object Cleanup Thread" [_thread_blocked, id=2928, stack(0x07850000,0x078a0000)]
0x06836000 JavaThread "Windows Tray Icon Thread" [_thread_in_native, id=2308, stack(0x07150000,0x071a0000)]
0x06835800 JavaThread "CacheCleanUpThread" daemon [_thread_blocked, id=4144, stack(0x07100000,0x07150000)]
0x06835400 JavaThread "CacheMemoryCleanUpThread" daemon [_thread_blocked, id=3372, stack(0x070b0000,0x07100000)]
0x06813c00 JavaThread "Java Plug-In Heartbeat Thread" [_thread_blocked, id=3488, stack(0x07010000,0x07060000)]
0x06810400 JavaThread "AWT-Windows" daemon [_thread_blocked, id=1160, stack(0x02400000,0x02500000)]
=>0x0680f800 JavaThread "Java2D Disposer" daemon [_thread_in_vm, id=3132, stack(0x06e20000,0x06e70000)]
0x06808000 JavaThread "Java Plug-In Pipe Worker Thread (Client-Side)" daemon [_thread_in_native, id=8084, stack(0x069d0000,0x06a20000)]
0x0268d000 JavaThread "Timer-0" [_thread_blocked, id=4120, stack(0x06530000,0x06580000)]
0x0266d800 JavaThread "traceMsgQueueThread" daemon [_thread_blocked, id=5140, stack(0x04de0000,0x04e30000)]
0x0263a800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=8152, stack(0x049f0000,0x04a40000)]
0x02631000 JavaThread "CompilerThread0" daemon [_thread_blocked, id=5204, stack(0x02860000,0x028b0000)]
0x0262d800 JavaThread "Attach Listener" daemon [_thread_blocked, id=6876, stack(0x027f0000,0x02840000)]
0x0262a800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=668, stack(0x02550000,0x025a0000)]
0x02624000 JavaThread "Finalizer" daemon [_thread_blocked, id=7264, stack(0x02500000,0x02550000)]
0x02622800 JavaThread "Reference Handler" daemon [_thread_blocked, id=5592, stack(0x01d90000,0x01de0000)]
0x00acb000 JavaThread "main" [_thread_blocked, id=4816, stack(0x00990000,0x009e0000)]
Other Threads:
0x02621400 VMThread [stack: 0x00ad0000,0x00b20000] [id=5428]
0x0263c400 WatcherThread [stack: 0x04a40000,0x04a90000] [id=7876]
VM state:synchronizing (normal execution)
VM Mutex/Monitor currently owned by a thread: ([mutex/lock_event])
[0x00ac8b60] Threads_lock - owner thread: 0x02621400
Heap
def new generation total 4928K, used 598K [0x28020000, 0x28570000, 0x2d570000)
eden space 4416K, 2% used [0x28020000, 0x2803a408, 0x28470000)
from space 512K, 96% used [0x28470000, 0x284eb668, 0x284f0000)
to space 512K, 0% used [0x284f0000, 0x284f0000, 0x28570000)
tenured generation total 10944K, used 2938K [0x2d570000, 0x2e020000, 0x38020000)
the space 10944K, 26% used [0x2d570000, 0x2d84ea30, 0x2d84ec00, 0x2e020000)
compacting perm gen total 12288K, used 4327K [0x38020000, 0x38c20000, 0x3c020000)
the space 12288K, 35% used [0x38020000, 0x38459cd8, 0x38459e00, 0x38c20000)
ro space 10240K, 51% used [0x3c020000, 0x3c54b700, 0x3c54b800, 0x3ca20000)
rw space 12288K, 54% used [0x3ca20000, 0x3d0b76c0, 0x3d0b7800, 0x3d620000)
Dynamic libraries:
0x00400000 - 0x00424000 C:\Program Files\Java\jre6\bin\java.exe
0x77500000 - 0x77628000 C:\Windows\system32\ntdll.dll
0x768e0000 - 0x769bc000 C:\Windows\system32\kernel32.dll
0x771e0000 - 0x772a6000 C:\Windows\system32\ADVAPI32.dll
0x77110000 - 0x771d3000 C:\Windows\system32\RPCRT4.dll
0x733b0000 - 0x733ce000 C:\Windows\system32\ShimEng.dll
0x759c0000 - 0x759ec000 C:\Windows\system32\apphelp.dll
0x69d20000 - 0x69da8000 C:\Windows\AppPatch\AcLayers.DLL
0x76ef0000 - 0x76f8d000 C:\Windows\system32\USER32.dll
0x76840000 - 0x7688b000 C:\Windows\system32\GDI32.dll
0x75ba0000 - 0x766b1000 C:\Windows\system32\SHELL32.dll
0x76a30000 - 0x76ada000 C:\Windows\system32\msvcrt.dll
0x769d0000 - 0x76a29000 C:\Windows\system32\SHLWAPI.dll
0x766f0000 - 0x76835000 C:\Windows\system32\ole32.dll
0x76c70000 - 0x76cfd000 C:\Windows\system32\OLEAUT32.dll
0x75a50000 - 0x75a6e000 C:\Windows\system32\USERENV.dll
0x75a30000 - 0x75a44000 C:\Windows\system32\Secur32.dll
0x73130000 - 0x73172000 C:\Windows\system32\WINSPOOL.DRV
0x75380000 - 0x75394000 C:\Windows\system32\MPR.dll
0x77640000 - 0x7765e000 C:\Windows\system32\IMM32.DLL
0x76f90000 - 0x77058000 C:\Windows\system32\MSCTF.dll
0x769c0000 - 0x769c9000 C:\Windows\system32\LPK.DLL
0x77090000 - 0x7710d000 C:\Windows\system32\USP10.dll
0x10000000 - 0x10015000 C:\Windows\system32\APSHook.dll
0x75a20000 - 0x75a28000 C:\Windows\system32\VERSION.dll
0x75b00000 - 0x75b07000 C:\Windows\system32\PSAPI.DLL
0x6c1b0000 - 0x6c1b5000 C:\Windows\system32\avgrsstx.dll
0x75620000 - 0x757be000 C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6002.18305_none_5cb72f2a088b0ed3\comctl32.dll
0x7c340000 - 0x7c396000 C:\Program Files\Java\jre6\bin\msvcr71.dll
0x6d800000 - 0x6daa7000 C:\Program Files\Java\jre6\bin\client\jvm.dll
0x74c40000 - 0x74c72000 C:\Windows\system32\WINMM.dll
0x74c00000 - 0x74c3d000 C:\Windows\system32\OLEACC.dll
0x6d7b0000 - 0x6d7bc000 C:\Program Files\Java\jre6\bin\verify.dll
0x6d330000 - 0x6d34f000 C:\Program Files\Java\jre6\bin\java.dll
0x6d000000 - 0x6d14a000 C:\Program Files\Java\jre6\bin\awt.dll
0x6d290000 - 0x6d298000 C:\Program Files\Java\jre6\bin\hpi.dll
0x74780000 - 0x747bf000 C:\Windows\system32\uxtheme.dll
0x6d7f0000 - 0x6d7ff000 C:\Program Files\Java\jre6\bin\zip.dll
0x71540000 - 0x7154c000 C:\Windows\system32\dwmapi.dll
0x009e0000 - 0x009f8000 c:\Program Files\Bioscrypt\VeriSoft\Bin\ItClient.dll
0x6d430000 - 0x6d436000 C:\Program Files\Java\jre6\bin\jp2native.dll
0x6d1d0000 - 0x6d1e3000 C:\Program Files\Java\jre6\bin\deploy.dll
0x75280000 - 0x75372000 C:\Windows\system32\CRYPT32.dll
0x753f0000 - 0x75402000 C:\Windows\system32\MSASN1.dll
0x77670000 - 0x77756000 C:\Windows\system32\WININET.dll
0x77660000 - 0x77663000 C:\Windows\system32\Normaliz.dll
0x773c0000 - 0x774f3000 C:\Windows\system32\urlmon.dll
0x76d00000 - 0x76ee9000 C:\Windows\system32\iertutil.dll
0x6d6b0000 - 0x6d6f6000 C:\Program Files\Java\jre6\bin\regutils.dll
0x6d610000 - 0x6d623000 C:\Program Files\Java\jre6\bin\net.dll
0x77060000 - 0x7708d000 C:\Windows\system32\WS2_32.dll
0x77630000 - 0x77636000 C:\Windows\system32\NSI.dll
0x74f70000 - 0x74fab000 C:\Windows\system32\mswsock.dll
0x74fd0000 - 0x74fd5000 C:\Windows\System32\wship6.dll
0x6d630000 - 0x6d639000 C:\Program Files\Java\jre6\bin\nio.dll
0x6d230000 - 0x6d284000 C:\Program Files\Java\jre6\bin\fontmanager.dll
0x74bc0000 - 0x74bc5000 C:\Windows\System32\wshtcpip.dll
0x74100000 - 0x7410f000 C:\Windows\system32\NLAapi.dll
0x751e0000 - 0x751f9000 C:\Windows\system32\IPHLPAPI.DLL
0x751a0000 - 0x751d5000 C:\Windows\system32\dhcpcsvc.DLL
0x75430000 - 0x7545c000 C:\Windows\system32\DNSAPI.dll
0x75190000 - 0x75197000 C:\Windows\system32\WINNSI.DLL
0x75160000 - 0x75182000 C:\Windows\system32\dhcpcsvc6.DLL
0x71760000 - 0x7176f000 C:\Windows\system32\napinsp.dll
0x712e0000 - 0x712f2000 C:\Windows\system32\pnrpnsp.dll
0x16080000 - 0x160a5000 C:\Program Files\Bonjour\mdnsNSP.dll
0x716a0000 - 0x716ac000 C:\Windows\system32\wshbth.dll
0x76ae0000 - 0x76c6a000 C:\Windows\system32\SETUPAPI.dll
0x71560000 - 0x71568000 C:\Windows\System32\winrnr.dll
0x76890000 - 0x768d9000 C:\Windows\system32\WLDAP32.dll
0x71770000 - 0x71776000 C:\Windows\system32\rasadhlp.dll
0x6d790000 - 0x6d798000 C:\Program Files\Java\jre6\bin\sunmscapi.dll
0x74cf0000 - 0x74d2b000 C:\Windows\system32\rsaenh.dll
0x74bd0000 - 0x74bf1000 C:\Windows\system32\NTMARTA.DLL
0x75410000 - 0x75421000 C:\Windows\system32\SAMLIB.dll
0x6d1a0000 - 0x6d1c3000 C:\Program Files\Java\jre6\bin\dcpr.dll
0x772b0000 - 0x77334000 C:\Windows\system32\CLBCatQ.DLL
0x6d300000 - 0x6d306000 C:\Program Files\Java\jre6\bin\j2pcsc.dll
0x74210000 - 0x7422f000 C:\Windows\system32\WinSCard.dll
0x74710000 - 0x7471a000 C:\Windows\system32\WTSAPI32.dll
0x74ff0000 - 0x75015000 C:\Windows\system32\WINSTA.dll
VM Arguments:
jvm_args: -D__jvm_launched=187588649031 -Xbootclasspath/a:C:\\PROGRA~1\\Java\\jre6\\lib\\deploy.jar;C:\\PROGRA~1\\Java\\jre6\\lib\\javaws.jar;C:\\PROGRA~1\\Java\\jre6\\lib\\plugin.jar -Dsun.awt.warmup=true -Dsun.plugin2.jvm.args=-D__jvm_launched=187588649031 "-Xbootclasspath/a:C:\\\\PROGRA~1\\\\Java\\\\jre6\\\\lib\\\\deploy.jar;C:\\\\PROGRA~1\\\\Java\\\\jre6\\\\lib\\\\javaws.jar;C:\\\\PROGRA~1\\\\Java\\\\jre6\\\\lib\\\\plugin.jar" "-Djava.class.path=C:\\\\PROGRA~1\\\\Java\\\\jre6\\\\classes" -Dsun.awt.warmup=true --- --
java_command: sun.plugin2.main.client.PluginMain write_pipe_name=jpi2_pid6388_pipe3,read_pipe_name=jpi2_pid6388_pipe2
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\Program Files\Internet Explorer;;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files\PC Connectivity Solution\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Program Files\Common Files\Roxio Shared\DLLShared\;C:\Program Files\Common Files\Roxio Shared\DLLShared\;C:\Program Files\Common Files\Roxio Shared\9.0\DLLShared\;c:\Program Files\Bioscrypt\VeriSoft\bin;C:\Program Files\QuickTime\QTSystem\;C:\Program Files\Windows Live\Shared;C:\Windows\System32\WindowsPowerShell\v1.0\
USERNAME=Henrik
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 6 Model 15 Stepping 10, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows Vista Build 6002 Service Pack 2
CPU:total 2 (2 cores per cpu, 1 threads per core) family 6 model 15 stepping 10, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3
Memory: 4k page, physical 2094780k(614616k free), swap 4440448k(1911780k free)
vm_info: Java HotSpot Client VM (17.0-b17) for windows-x86 JRE (1.6.0_21-b07), built on Jul 17 2010 01:10:15 by "java_re" with MS VC++ 7.1 (VS2003)
time: Fri Jun 03 22:09:29 2011
elapsed time: 75 seconds
-------------------------------------------------------------Og ett eksempel på en annen jeg fikk i dag:-------------------------------------------------------------
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x69aade63, pid=5468, tid=4724
# JRE version: 6.0_26-b03
# Java VM: Java HotSpot Client VM (20.1-b02 mixed mode windows-x86 )
# C [nvoglv32.dll+0x5ade63]
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
Current thread (0x04ba8400): JavaThread "Minecraft main thread" daemon [_thread_in_native, id=4724, stack(0x08680000,0x086d0000)]
siginfo: ExceptionCode=0xc0000005, writing address 0x0cc3e000
Registers:
EAX=0x0cc3e000, EBX=0x0cc3e000, ECX=0x0961135c, EDX=0x41800000
ESP=0x086cf140, EBP=0x086cf14c, ESI=0x095e0000, EDI=0x09611508
EIP=0x69aade63, EFLAGS=0x00010293
Top of Stack: (sp=0x086cf140)
0x086cf140: 00000000 00000000 00004003 086cf160
0x086cf150: 69aaf114 095f95dc 095e0000 095e0000
0x086cf160: 086cf168 6963d6ac 086cf178 695e856c
0x086cf170: 0bbe1000 095f9378 086cf1a4 6992fdbd
0x086cf180: 0bbe1000 00001050 00000000 095e0000
0x086cf190: 095e0000 00000000 00000008 00000000
0x086cf1a0: 00000109 086cf1b8 698fc17f 04ba8400
0x086cf1b0: 086cf1f4 00000000 086cf208 086d8923
Instructions: (pc=0x69aade63)
0x69aade43: 8d 04 83 77 41 ff 24 95 3c df aa 69 8b 11 89 10
0x69aade53: eb 34 8b 11 89 10 8b 51 04 89 50 04 eb 28 8b 11
0x69aade63: 89 10 8b 51 04 89 50 04 8b 51 08 89 50 08 eb 16
0x69aade73: 8b 11 89 10 8b 51 04 89 50 04 8b 51 08 89 50 08
Register to memory mapping:
EAX=0x0cc3e000 is an unknown value
EBX=0x0cc3e000 is an unknown value
ECX=0x0961135c is an unknown value
EDX=0x41800000 is an unallocated location in the heap
ESP=0x086cf140 is pointing into the stack for thread: 0x04ba8400
EBP=0x086cf14c is pointing into the stack for thread: 0x04ba8400
ESI=0x095e0000 is an unknown value
EDI=0x09611508 is an unknown value
Stack: [0x08680000,0x086d0000], sp=0x086cf140, free space=316k
C [nvoglv32.dll+0x5af114]
C [nvoglv32.dll+0x13d6ac]
C [nvoglv32.dll+0xe856c]
C [nvoglv32.dll+0x42fdbd]
C [nvoglv32.dll+0x3fc17f]
C [lwjgl.dll+0x8923]
J nw.a()V
V [jvm.dll+0xfae4b]
V [jvm.dll+0x18c531]
V [jvm.dll+0xfaff1]
V [jvm.dll+0xfb04b]
V [jvm.dll+0xb56b9]
V [jvm.dll+0x1190d4]
V [jvm.dll+0x1411ac]
C [kernel32.dll+0x4d309]
J org.lwjgl.opengl.GL11.nglDrawArrays(IIIJ)V
J nw.a()V
J dk.a()V
J n.a(Lls;Z)Z
J px.a(FJ)V
J px.b(F)V
J net.minecraft.client.Minecraft.run()V
0x07c4bc00 JavaThread "Thread-14" daemon [_thread_blocked, id=3916, stack(0x0c6f0000,0x0c740000)]
0x07c4b400 JavaThread "Thread-13" daemon [_thread_blocked, id=3832, stack(0x0c660000,0x0c6b0000)]
0x07c46c00 JavaThread "Thread-12" daemon [_thread_in_native, id=7320, stack(0x0c610000,0x0c660000)]
=>0x04ba8400 JavaThread "Minecraft main thread" daemon [_thread_in_native, id=4724, stack(0x08680000,0x086d0000)]
0x04ba8000 JavaThread "Timer hack thread" daemon [_thread_blocked, id=752, stack(0x05320000,0x05370000)]
0x07bfe800 JavaThread "D3D Screen Updater" daemon [_thread_blocked, id=4244, stack(0x05110000,0x05160000)]
0x01ad9800 JavaThread "DestroyJavaVM" [_thread_blocked, id=5664, stack(0x01a70000,0x01ac0000)]
0x04b26400 JavaThread "TimerQueue" daemon [_thread_blocked, id=8040, stack(0x07b40000,0x07b90000)]
0x04aae000 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=5940, stack(0x07600000,0x07650000)]
0x04aadc00 JavaThread "AWT-Shutdown" [_thread_blocked, id=5320, stack(0x075b0000,0x07600000)]
0x04a6b400 JavaThread "AWT-Windows" daemon [_thread_in_native, id=8100, stack(0x04ec0000,0x04f10000)]
0x04a68400 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=5832, stack(0x04cd0000,0x04d20000)]
0x024ca800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=6824, stack(0x04930000,0x04980000)]
0x024bd400 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=4520, stack(0x048e0000,0x04930000)]
0x024ba400 JavaThread "Attach Listener" daemon [_thread_blocked, id=4712, stack(0x04890000,0x048e0000)]
0x024b9400 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=4256, stack(0x01db0000,0x01e00000)]
0x0248f400 JavaThread "Finalizer" daemon [_thread_blocked, id=7880, stack(0x01d60000,0x01db0000)]
0x0248a800 JavaThread "Reference Handler" daemon [_thread_blocked, id=7856, stack(0x01d10000,0x01d60000)]
Other Threads:
0x02486800 VMThread [stack: 0x01bb0000,0x01c00000] [id=7076]
0x024cbc00 WatcherThread [stack: 0x04980000,0x049d0000] [id=4368]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 157376K, used 16446K [0x10020000, 0x1aae0000, 0x25570000)
eden space 139904K, 10% used [0x10020000, 0x10de04a0, 0x188c0000)
from space 17472K, 13% used [0x188c0000, 0x18b0f570, 0x199d0000)
to space 17472K, 0% used [0x199d0000, 0x199d0000, 0x1aae0000)
tenured generation total 349568K, used 264883K [0x25570000, 0x3aad0000, 0x50020000)
the space 349568K, 75% used [0x25570000, 0x3581cfd8, 0x3581d000, 0x3aad0000)
compacting perm gen total 16896K, used 16819K [0x50020000, 0x510a0000, 0x54020000)
the space 16896K, 99% used [0x50020000, 0x5108ccb8, 0x5108ce00, 0x510a0000)
No shared spaces configured.
Code Cache [0x02500000, 0x02b00000, 0x04500000)
total_blobs=3017 nmethods=2687 adapters=264 free_code_cache=27288832 largest_free_block=192
Dynamic libraries:
0x00400000 - 0x00424000 C:\Program Files\Java\jre6\bin\javaw.exe
0x776c0000 - 0x777e8000 C:\Windows\system32\ntdll.dll
0x76de0000 - 0x76ebc000 C:\Windows\system32\kernel32.dll
0x70200000 - 0x7022b000 C:\Program Files\PC Tools Security\smum32.dll
0x774f0000 - 0x7757d000 C:\Windows\system32\oleaut32.dll
0x77020000 - 0x77165000 C:\Windows\system32\ole32.dll
0x76ec0000 - 0x76f6a000 C:\Windows\system32\msvcrt.dll
0x75e70000 - 0x75ebb000 C:\Windows\system32\GDI32.dll
0x76f70000 - 0x7700d000 C:\Windows\system32\USER32.dll
0x76bd0000 - 0x76c96000 C:\Windows\system32\ADVAPI32.dll
0x75f10000 - 0x75fd3000 C:\Windows\system32\RPCRT4.dll
0x75fe0000 - 0x75ffe000 C:\Windows\system32\IMM32.DLL
0x76d10000 - 0x76dd8000 C:\Windows\system32\MSCTF.dll
0x77820000 - 0x77829000 C:\Windows\system32\LPK.DLL
0x75d60000 - 0x75ddd000 C:\Windows\system32\USP10.dll
0x76cb0000 - 0x76d09000 C:\Windows\system32\SHLWAPI.dll
0x75be0000 - 0x75be8000 C:\Windows\system32\VERSION.dll
0x75cc0000 - 0x75cc7000 C:\Windows\system32\PSAPI.DLL
0x013b0000 - 0x013f8000 C:\Windows\system32\guard32.dll
0x757e0000 - 0x7597e000 C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6002.18305_none_5cb72f2a088b0ed3\comctl32.dll
0x75bd0000 - 0x75bd7000 C:\Windows\system32\fltlib.dll
0x6d7f0000 - 0x6da9f000 C:\Program Files\Java\jre6\bin\client\jvm.dll
0x74eb0000 - 0x74ee2000 C:\Windows\system32\WINMM.dll
0x74e70000 - 0x74ead000 C:\Windows\system32\OLEACC.dll
0x75ba0000 - 0x75bcc000 C:\Windows\system32\apphelp.dll
0x6d7a0000 - 0x6d7ac000 C:\Program Files\Java\jre6\bin\verify.dll
0x6d320000 - 0x6d33f000 C:\Program Files\Java\jre6\bin\java.dll
0x6d7e0000 - 0x6d7ef000 C:\Program Files\Java\jre6\bin\zip.dll
0x6d000000 - 0x6d14b000 C:\Program Files\Java\jre6\bin\awt.dll
0x74520000 - 0x74562000 C:\Windows\system32\WINSPOOL.DRV
0x741f0000 - 0x74275000 C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_5.82.6002.18305_none_88f3a38569c2c436\comctl32.dll
0x6ea00000 - 0x6ea0c000 C:\Windows\system32\DWMAPI.DLL
0x74a90000 - 0x74acf000 C:\Windows\system32\uxtheme.dll
0x04c90000 - 0x04ca8000 c:\Program Files\Bioscrypt\VeriSoft\Bin\ItClient.dll
0x76080000 - 0x76b91000 C:\Windows\system32\shell32.dll
0x6d230000 - 0x6d27f000 C:\Program Files\Java\jre6\bin\fontmanager.dll
0x6ea20000 - 0x6ebda000 C:\Windows\system32\d3d9.dll
0x6ea10000 - 0x6ea16000 C:\Windows\system32\d3d8thk.dll
0x6c670000 - 0x6cde9000 C:\Windows\system32\nvd3dum.dll
0x74de0000 - 0x74dfa000 C:\Windows\system32\powrprof.dll
0x6d600000 - 0x6d613000 C:\Program Files\Java\jre6\bin\net.dll
0x76ba0000 - 0x76bcd000 C:\Windows\system32\WS2_32.dll
0x76ca0000 - 0x76ca6000 C:\Windows\system32\NSI.dll
0x751e0000 - 0x7521b000 C:\Windows\system32\mswsock.dll
0x75250000 - 0x75255000 C:\Windows\System32\wship6.dll
0x6d620000 - 0x6d629000 C:\Program Files\Java\jre6\bin\nio.dll
0x75260000 - 0x75265000 C:\Windows\System32\wshtcpip.dll
0x73da0000 - 0x73daf000 C:\Windows\system32\NLAapi.dll
0x75430000 - 0x75449000 C:\Windows\system32\IPHLPAPI.DLL
0x75390000 - 0x753c5000 C:\Windows\system32\dhcpcsvc.DLL
0x75670000 - 0x7569c000 C:\Windows\system32\DNSAPI.dll
0x75bf0000 - 0x75c04000 C:\Windows\system32\Secur32.dll
0x75420000 - 0x75427000 C:\Windows\system32\WINNSI.DLL
0x753f0000 - 0x75412000 C:\Windows\system32\dhcpcsvc6.DLL
0x72310000 - 0x7231f000 C:\Windows\system32\napinsp.dll
0x722f0000 - 0x72302000 C:\Windows\system32\pnrpnsp.dll
0x07540000 - 0x07565000 C:\Program Files\Bonjour\mdnsNSP.dll
0x722d0000 - 0x722d8000 C:\Windows\System32\winrnr.dll
0x75ec0000 - 0x75f09000 C:\Windows\system32\WLDAP32.dll
0x722c0000 - 0x722cc000 C:\Windows\system32\wshbth.dll
0x77360000 - 0x774ea000 C:\Windows\system32\SETUPAPI.dll
0x72260000 - 0x72266000 C:\Windows\system32\rasadhlp.dll
0x74f20000 - 0x74f5b000 C:\Windows\system32\rsaenh.dll
0x75c10000 - 0x75c2e000 C:\Windows\system32\USERENV.dll
0x75de0000 - 0x75e64000 C:\Windows\system32\CLBCatQ.DLL
0x6d780000 - 0x6d788000 C:\Program Files\Java\jre6\bin\sunmscapi.dll
0x754d0000 - 0x755c2000 C:\Windows\system32\CRYPT32.dll
0x75630000 - 0x75642000 C:\Windows\system32\MSASN1.dll
0x086d0000 - 0x0873b000 C:\Users\Henrik\AppData\Roaming\.minecraft\bin\natives\lwjgl.dll
0x6a200000 - 0x6a2cb000 C:\Windows\system32\OPENGL32.dll
0x6cfc0000 - 0x6cfe3000 C:\Windows\system32\GLU32.dll
0x6aa80000 - 0x6ab65000 C:\Windows\system32\DDRAW.dll
0x74470000 - 0x74476000 C:\Windows\system32\DCIMAN32.dll
0x6d350000 - 0x6d356000 C:\Program Files\Java\jre6\bin\jawt.dll
0x69500000 - 0x69f46000 C:\Windows\system32\nvoglv32.dll
0x07bb0000 - 0x07bc3000 C:\Users\Henrik\AppData\Roaming\.minecraft\bin\natives\jinput-dx8.dll
0x6ce20000 - 0x6ce53000 C:\Windows\system32\DINPUT8.dll
0x732a0000 - 0x732a9000 C:\Windows\system32\HID.DLL
0x747a0000 - 0x747cd000 C:\Windows\system32\WINTRUST.dll
0x777f0000 - 0x77819000 C:\Windows\system32\imagehlp.dll
0x0c5f0000 - 0x0c602000 C:\Users\Henrik\AppData\Roaming\.minecraft\bin\natives\jinput-raw.dll
0x68c20000 - 0x68d49000 C:\Users\Henrik\AppData\Roaming\.minecraft\bin\natives\OpenAL32.dll
0x6aca0000 - 0x6ad10000 C:\Windows\system32\dsound.dll
0x73e90000 - 0x73eb8000 C:\Windows\System32\MMDevApi.dll
0x73de0000 - 0x73e0f000 C:\Windows\system32\wdmaud.drv
0x73e20000 - 0x73e24000 C:\Windows\system32\ksuser.dll
0x741e0000 - 0x741e7000 C:\Windows\system32\AVRT.dll
0x73db0000 - 0x73dd1000 C:\Windows\system32\AUDIOSES.DLL
0x73be0000 - 0x73c46000 C:\Windows\system32\audioeng.dll
0x73d90000 - 0x73d99000 C:\Windows\system32\msacm32.drv
0x73bc0000 - 0x73bd4000 C:\Windows\system32\MSACM32.dll
0x73af0000 - 0x73af7000 C:\Windows\system32\midimap.dll
VM Arguments:
jvm_args: -Xms512m -Xmx1024m
java_command: C:\Users\Henrik\Desktop\Minecraft.exe
CLASSPATH=.;C:\Program Files\Java\jre1.6.0_07\lib\ext\QTJava.zip
PATH=C:\Program Files\PC Connectivity Solution\;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Program Files\Common Files\Roxio Shared\DLLShared\;C:\Program Files\Common Files\Roxio Shared\DLLShared\;C:\Program Files\Common Files\Roxio Shared\9.0\DLLShared\;c:\Program Files\Bioscrypt\VeriSoft\bin;C:\Program Files\QuickTime\QTSystem\;C:\Program Files\Windows Live\Shared;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Java\jre6\bin
USERNAME=Henrik
OS=Windows_NT
Memory: 4k page, physical 2094780k(234836k free), swap 4436344k(1164520k free)
vm_info: Java HotSpot Client VM (20.1-b02) for windows-x86 JRE (1.6.0_26-b03), built on May 4 2011 00:50:59 by "java_re" with MS VC++ 7.1 (VS2003)
time: Mon Aug 29 15:53:51 2011
elapsed time: 2356 seconds
Du har åpenbart prøvd å kjøre et java-program som har kræsja.
Eller mer sannsynlig: Du har lastet ned en programpakke (mer enn 1 kjørbar jar-fil) og så har du prøvd å kjørt en av de andre jar-filene (som dlll i windows, men java miljø istedet). Sånn er det iallefall med Geogebra, det er kun én fil som i realiteten er kjørbar.
