Ustabilt trådløst ved aktivitet
I Ubuntu kan jeg se på Connection Information og Speed står på 54 Mb/s, men når jeg laster ned eller kjører en speedometer så dropper den til 5 Mb/s eller lavere.
Dette har ikke alltid vært tilfelle.
Det er Lyse 25Mbit, AirLink 89300 ruter, med D-link DWA-140 USB.
PING 192.168.0.1 (192.168.0.1) 56(84) bytes of data.
64 bytes from 192.168.0.1: icmp_req=1 ttl=64 time=1583 ms
64 bytes from 192.168.0.1: icmp_req=2 ttl=64 time=1864 ms
64 bytes from 192.168.0.1: icmp_req=3 ttl=64 time=2089 ms
64 bytes from 192.168.0.1: icmp_req=4 ttl=64 time=1730 ms
64 bytes from 192.168.0.1: icmp_req=5 ttl=64 time=1272 ms
64 bytes from 192.168.0.1: icmp_req=6 ttl=64 time=1129 ms
64 bytes from 192.168.0.1: icmp_req=7 ttl=64 time=1311 ms
64 bytes from 192.168.0.1: icmp_req=8 ttl=64 time=1537 ms
64 bytes from 192.168.0.1: icmp_req=9 ttl=64 time=1627 ms
64 bytes from 192.168.0.1: icmp_req=10 ttl=64 time=1719 ms
64 bytes from 192.168.0.1: icmp_req=11 ttl=64 time=1751 ms
^C
--- 192.168.0.1 ping statistics ---
13 packets transmitted, 11 received, 15% packet loss, time 12008ms
rtt min/avg/max/mdev = 1129.784/1601.656/2089.482/266.274 ms, pipe 3
Mens jeg lastet ned da, om det ikke har noe å si. Hvis det har så prøver jeg igjen i morgen.
64 bytes from 192.168.0.1: icmp_req=1 ttl=64 time=1.07 ms
64 bytes from 192.168.0.1: icmp_req=2 ttl=64 time=1.47 ms
64 bytes from 192.168.0.1: icmp_req=3 ttl=64 time=1.47 ms
64 bytes from 192.168.0.1: icmp_req=4 ttl=64 time=1.13 ms
64 bytes from 192.168.0.1: icmp_req=5 ttl=64 time=1.68 ms
64 bytes from 192.168.0.1: icmp_req=6 ttl=64 time=0.981 ms
64 bytes from 192.168.0.1: icmp_req=7 ttl=64 time=2.29 ms
64 bytes from 192.168.0.1: icmp_req=8 ttl=64 time=1.31 ms
64 bytes from 192.168.0.1: icmp_req=9 ttl=64 time=1.66 ms
64 bytes from 192.168.0.1: icmp_req=10 ttl=64 time=1.02 ms
64 bytes from 192.168.0.1: icmp_req=12 ttl=64 time=1.39 ms
64 bytes from 192.168.0.1: icmp_req=13 ttl=64 time=1.31 ms
^C
13 packets transmitted, 13 received, 0% packet loss, time 12016ms
rtt min/avg/max/mdev = 0.981/1.385/2.291/0.343 ms
Jeg fikk vite at kjellere er generelt ikke en bra plass for trådløst. Det fikk jeg testet med en laptop samt en mobil-telefon.
Er det mulig å forsterke signaler utenom kabel? Strømnett er uaktuelt da kjelleren er en leilighet.
Trådløsforbindelsen ser ut til å være veldig god. Prøv traceroute www.uio.no og se hva du får der.
Hvis første hopp til routeren er lavt, og responsen mot UIO er treg så indikerer det at internettlinjen trolig er problemet.
Det kan være noen på nettverket som kjører annen trafikk, som gjør at du får dårlig resultat selv.
Er det slik hele tiden, så kan det være noen som laster bittorrent eller lignende.
TraceRoute to 129.240.8.200 [www.uio.no]
Hop (ms) (ms) (ms) IP Address Host name
1 17 0 0 8.9.232.73 xe-5-3-0.edge3.dallas1.level3.net
2 1 1 1 4.69.145.133 ae-33-80.car3.dallas1.level3.net
3 1 1 1 4.68.63.194 -
4 47 40 40 213.155.130.66 nyk-bb2-link.telia.net
5 138 138 138 213.155.130.154 kbn-bb2-link.telia.net
6 146 146 146 213.155.130.50 s-bb2-link.telia.net
7 149 149 149 213.248.66.14 s-b2-link.telia.net
8 146 146 146 213.248.97.94 nordunet-113054-s-b4.c.telia.net
9 154 154 154 109.105.102.22 oslo-gw.uninett.no
10 157 159 157 128.39.65.18 uio-gw8.uio.no
11 154 155 154 129.240.25.18 mrom-gw2.uio.no
12 157 157 157 129.240.8.200 www.uio.no
Trace complete
Nå prøver jeg wireless repeater med to Jensen AirLink 89300 rutere, men guiden jeg lastet ned er mangefull for nybegynnere, f.eks. sette felles passord/nøkkel, samt det er problematisk å få kontakt med rutere noen ganger.
Endret av Zxy
