medisiner for å få i gang fødsel. hva vil det gjøre med en mann?
Gjest Slettet-T9cKWhDpN0
Hormonet som brukes er oxytocin, eller en syntetisk utgave av dette.Søk litt så finner du nok noe om det, dette var et av de første treffene jeg fant ang menn.
It turns out that oxytocin in men is important in sexual arousal. During sexual arousal, large amounts of oxytocin and dopamine (which I've written about before) are released. It is believed that oxytocin contributes to the perception of sexual arousal, while dopamine may be correlated with the positive feelings associated with sexual arousal. There are lots of receptors for oxytocin present in the penis, particularly in the corpus cavernosa, the long tubes that fill with blood during an erection.
And the sexual arousal induced by oxytocin is some potent stuff. Rats given oxytocin get both an erection and an increase in dopamine in an area of the brain called the nucleus accumbens, an area associated with the "motivational properties of stimuli". It's the area that gets hit hard when people (or rats) take cocaine, and the area that hits up whenever anything that feels really good goes on. And what feels better than sex? It appears that oxytocin feels very good indeed.
And oxytocin is not just big in sexual arousal, it is also very important in orgasm (this is true for both women and men, as you may have seen in previous posts). For male orgasm, oxytocin is very important in the muscle contractions that occur during orgasm, possibly contracting the epididymis (the tube connecting the testes to the vas deferens, and hence to the out-route). While oxytocin probably isn't the only thing in charge of male ejaculation, some case studies have found it to be effective in restoring problems with ejaculation (which Sci imagines must be a very frustrating problem indeed).
And oxytocin may have a third role to play. It is very possible that oxytocin plays a role in the aftermath of sex as well, in the role of "postorgasmic penile detumescence". The English translation of that is what we like to call a "soft-off" (I would link to Urban Dictionary there, except that their "examples" are always just...really immature. Even for Sci).
Now you might sit there and think "wait, hard-ons AND soft-offs?" How does THAT work? Well the current hypothesis is that estrogen (that's right, estrogen) plays a role in this, causing certain areas of the penis (like the corpus cavernosa and the arteries leading in) to be sensitive to the muscle-contracting effects of oxytocin during arousal, and other areas (like the veins leading out) to be more sensitive to the effects of oxytocin after the deed is done. That's some crazy awesome science right there.
Endret av Ekko
