JetzBullet Skrevet 27. august 2011 Del Skrevet 27. august 2011 Slik jeg har skjønt det er de passive displayport adapter kun ratet opp til 1920x1200/1080 i oppløsning på skjerm(er). Skal du over det i oppløsning på skjerm(er),må du ha en aktiv displayport adapter. Lenke til kommentar https://www.diskusjon.no/topic/1366421-l%C3%B8st-f%C3%A5r-ikke-3-monitorer-aktivert-med-hd-6970/page/2/#findComment-18228703
N o r e n g Skrevet 27. august 2011 Del Skrevet 27. august 2011 Slik jeg har skjønt det er de passive displayport adapter kun ratet opp til 1920x1200/1080 i oppløsning på skjerm(er). Skal du over det i oppløsning på skjerm(er),må du ha en aktiv displayport adapter. passive adaptere krever et klokkesignal, HD 69xx har kun to klokkesignaler. Lenke til kommentar https://www.diskusjon.no/topic/1366421-l%C3%B8st-f%C3%A5r-ikke-3-monitorer-aktivert-med-hd-6970/page/2/#findComment-18228779
JetzBullet Skrevet 28. august 2011 Del Skrevet 28. august 2011 (endret) Så sant så sant arni90. My bad! Hentet dette fra AMD.com: Why do you need DisplayPort? AMD Eyefinity technology leverages DisplayPort and its ability to easily scale to drive multiple displays from a single clock source. What's the difference between active DisplayPort dongles and passive DisplayPort dongles? Passive dongles use the DisplayPort connection to receive non-DP signaling from the connector and they 'passively' adjust the signals to be compliant with the connected monitor. Passive dongles are considered legacy connections, not DisplayPort connections, therefore they do not fulfill the DisplayPort connection requirement mentioned previously and cannot be used to enable 3 or more displays. They do, however, offer an affordable solution to adapt legacy displays to DisplayPort connections. Active dongles use true DisplayPort signaling to 'actively' translate and re-transmit the signals as the required outputs. Because they use the true DisplayPort signaling, they are considered a DisplayPort connection and meet the requirements to enable 3 or more displays. DisplayPort to DL-DVI dongles require an external power supply which is usually through a separate USB connection (the USB connection must meet the USB 'high power' specification). Endret 28. august 2011 av jetzbullet Lenke til kommentar https://www.diskusjon.no/topic/1366421-l%C3%B8st-f%C3%A5r-ikke-3-monitorer-aktivert-med-hd-6970/page/2/#findComment-18230988
