Dine PHP koder
Men, generere et fargekart:
<table align="center" width="1000">
<?php
$r = 0;
while($r <= 15) {
echo '<tr>';
$g = 0;
while($g <= 15) {
	echo '<tr>';
	$b = 0;
	while($b <= 15) {
		$background = dechex($r) . dechex($r) . dechex($g) .dechex($g) . dechex($b) . dechex ($b);
		echo '<td style="background-color:#' . $background . ';" width="5%"> </td><td>#' . $background . '</td>';
		$b = $b + 1;
	$g = $g + 1;
$r = $r + 1;
</table>
<?php
$r = 0;
while($r <= 15) {
echo '<tr>';
$g = 0;
while($g <= 15) {
	echo '<tr>';
	$b = 0;
	while($b <= 15) {
		$b = $b + 1;
	$g = $g + 1;
$r = $r + 1;
</table>
Kult. Kansje modde så fargene blir litt mer større? ikke så smått?
<?php
  * Get a key from a secret.
  * What we do is create two different hashes from the secret, combine them
  * and pick out the number of characters we need.
  * We used the raw binary output of the hash function for maximum
  * bit strength (we have 255 chars to choose from, instead of 16).
  * @param string $secret
  *   The secret to generate a key from.
  * @param integer $ks
  *   The key size.
  * @return binary
  *   Key created from secret.
 function getKey($secret, $ks) {
   /* Split the secret into two parts. */
   $secretSplit = floor(strlen($secret)/2);
   $secret1 = substr($secret, 0, $secretSplit);
   $secret2 = substr($secret, $secretSplit);
   /* Hash the two parts seperatly and return the result in raw format. */
   $key1 = hash('sha256', $secret1, true);
   $key2 = hash('sha256', $secret2, true);
   /* Return the part of the key we need. */
   return substr($key2.$key1, 0, $ks);
Til feks. kryptering.
Endret av xqus
<?php
$r = 0;
while($r <= 15) {
echo '<tr>';
$g = 0;
while($g <= 15) {
	echo '<tr>';
	$b = 0;
	while($b <= 15) {
		$b = $b + 1;
	$g = $g + 1;
$r = $r + 1;
</table>
Der du leser $nbsp;, er hvor bred den skal være, legg til flere $nbsp; der får å gjøre den bredere.
<?php
$r = 0;
while($r <= 15) {
       echo '<tr>';
       $g = 0;
       while($g <= 15) {
               echo '<tr>';
               $b = 0;
               while($b <= 15) {
                       echo '<td style="background-color:#' . $background . ';" width="50%">   </td><td>#' . $background . '</td>';
                       $b = $b + 1;
               $g = $g + 1;
       $r = $r + 1;
</table>
Der er den litt bredere, har ikke gidda å gå dypere inn om hvordan jeg kan få ferre rader, men alle kodene.
Random Quote;
<?php
$quotes [ ] = "<p>This is a quote </p>";
$quotes [ ] = "<p>This is a quote 2</p>";
       $quotes [ ] = "<p>This is a quote 3</p>";
$quotes [ ] = "<p>This is a quote 4</p>";
$quotes [ ] = "<p>This is a quote 5</p>";
       $quotes [ ] = "<p>This is a quote 6</p>";
$quotes [ ] = "<p>This is a quote 7</p>";
$quotes [ ] = "<p>This is a quote 8</p>";
       $quotes [ ] = "<p>This is a quote 9</p>";
srand ((double) microtime () * 1000000);
$randomquote = rand (0, count ($quotes)-1);
Og for å få fram den randome setning, må du bruke;
<?php
include ('random_quote.php');
echo "<p>" . $quotes [$randomquote] . "</p>" ?>
Jobber med en liten side hvor jeg samler opp di fleste kodene her, send gjærne en kopi til [email protected] for å gjøre det lettere for meg :thumbup:
Tenkte at dere skal bruke en mal hvis dere sender den til meg:
<blockquote><!-- [snippet navn] #START here -->
       <h3>[snippet Navn] </h3>
       <code>
                 din kode her<br />
                 og hver linje må slutte med <br />
       </code>
</blockquote> <!-- [snippet navn] #END here -->
Subject burde være, SNIPPET
Endret av stjernegut
hmm.
hva skulle du lage? Jeg skjønte ikke helt.
<code>
din kode her<br />
</code>
</blockquote> <!-- [snippet navn] #END here -->[/code
Er bare en mal hvordan du kan sende inn snippets til meg.
Eg jobber meg en side hvor jeg samler opp mange snippets, som skal være tilgjengelig for alle.
Siden mange forumer har sin egen php tråd, der man legger ut sine små kode "snutter".
Men nesten ingen sider som samler dem opp, det er det som jeg prøver og gjør...
Skjønner?
