CurSe Skrevet 2. august 2003 Del Skrevet 2. august 2003 Jeg har mistet min q3 cd, men jeg vil gjerne ha cd-keyen min. q3 er installert på denne pc'n, men jeg får ikke startet det. Jeg får dette opp når jeg skal starte q3(jeg skjønner ikke noe utav det) Q3 1.11 win-x86 Nov 24 1999 ----- FS_Startup ----- Current search path: C:ProgramfilerQuake III Arenabaseq3pak0.pk3 (3539 files) C:ProgramfilerQuake III Arena/baseq3 ---------------------- execing default.cfg execing q3config.cfg couldn't exec autoexec.cfg ...detecting CPU, found x86 (P5/Pentium2, MMX) ------- Input Initialization ------- Initializing DirectInput... Couldn't set DI coop level Falling back to Win32 mouse support... Joystick is not active. ------------------------------------ ----- Client Initialization ----- ----- Initializing Renderer ---- ------------------------------- ----- Client Initialization Complete ----- --- Common Initialization Complete --- Winsock Initialized Opening IP socket: localhost:27960 Hostname: default IP: 193.216.121.158 Working directory: C:ProgramfilerQuake III Arena ----- R_Init ----- Initializing OpenGL subsystem ...initializing QGL ...calling LoadLibrary( 'C:WINDOWSSYSTEMopengl32.dll' ): succeeded ...setting mode 3: 640 480 FS ...using desktop display depth of 32 ...calling CDS: ok ...registered window class ...created window@0,0 (640x480) Initializing OpenGL driver ...getting DC: succeeded ...GLW_ChoosePFD( 32, 24, 8 ) ...24 PFDs found ...GLW_ChoosePFD failed ...GLW_ChoosePFD( 32, 24, 0 ) ...24 PFDs found ...GLW_ChoosePFD failed ...failed to find an appropriate PIXELFORMAT ...restoring display settings ...WARNING: could not set the given mode (3) ...setting mode 3: 640 480 FS ...using colorsbits of 16 ...calling CDS: ok ...created window@0,0 (640x480) Initializing OpenGL driver ...getting DC: succeeded ...GLW_ChoosePFD( 16, 16, 0 ) ...24 PFDs found ...GLW_ChoosePFD failed ...GLW_ChoosePFD( 16, 16, 0 ) ...24 PFDs found ...GLW_ChoosePFD failed ...failed to find an appropriate PIXELFORMAT ...restoring display settings ...WARNING: could not set the given mode (3) ...shutting down QGL ...unloading OpenGL DLL ...assuming '3dfxvgl' is a standalone driver ...initializing QGL ...WARNING: missing Glide installation, assuming no 3Dfx available ...shutting down QGL ----- CL_Shutdown ----- RE_Shutdown( 1 ) ----------------------- GLW_StartOpenGL() - could not load OpenGL subsystem Hadde vært fint hvis noen av dere kunne hjelpe meg med å finne min cd-key Lenke til kommentar
DaChronix Skrevet 2. august 2003 Del Skrevet 2. august 2003 eneten på bruksanvisningen eller så ligger den garanetrt i registry et sted....skal lete litt rundt å se om jeg finner hvor den har plassert min hen =) /daChronix Lenke til kommentar
Gunnar B Skrevet 3. august 2003 Del Skrevet 3. august 2003 Cd-keyen ligger i baseq3 mappa/q3key og åpnes i notepad. Lenke til kommentar
CurSe Skrevet 4. august 2003 Forfatter Del Skrevet 4. august 2003 Cd-keyen ligger i baseq3 mappa/q3key og åpnes i notepad. Jeg har 3 filer som ligger i baseq3 mappa(Games,Pak0 og q3config). Games mappa er forferdelig lang, men er det der cdkeyen min ligger? Lenke til kommentar
Gunnar B Skrevet 4. august 2003 Del Skrevet 4. august 2003 Ja i rota på baseq3, sammen med games.log, pak filer og q3cfg. Lenke til kommentar
Gunnar B Skrevet 4. august 2003 Del Skrevet 4. august 2003 Men når jeg leser det som står i oppstart boksen, så tror jeg det trengs en reinnstallering av spillet + openGL drivere (ligger på cd). At spillet ikke vil starte har ingenting med cdkeyen å gjøre. Lenke til kommentar
Kalle_^ Skrevet 5. august 2003 Del Skrevet 5. august 2003 Men når jeg leser det som står i oppstart boksen, så tror jegdet trengs en reinnstallering av spillet + openGL drivere (ligger på cd). At spillet ikke vil starte har ingenting med cdkeyen å gjøre. Han må jo ha cd-keyen før han slette spille... hvis ikke så kan han jo ikke reinnstalere spille.... Lenke til kommentar
Gunnar B Skrevet 5. august 2003 Del Skrevet 5. august 2003 Kalle88 skrev:Han må jo ha cd-keyen før han slette spille... hvis ikke så kan han jo ikke reinnstalere spille.... Sånn jeg ser det så har han to problemer. 1. Ett spill som ikke virker. 2. Mangler cdkey. Det er jo ikke noe problem å innstallere uten cdkey, det må han jo uansett ser det ut til. Det kan det jo hende han har funnet den for alt vi vet Lenke til kommentar
