medlem-193513 Skrevet 14. juli 2011 Del Skrevet 14. juli 2011 (endret) Hei, Har ett lite problem med HLStatsX: CE installasjonen min (ranking for Source-baserte spill). Den bruker en MySQL database for å lagre spillerdata, rank, kills osv.. Tingen er at det går så inn i helvette treigt. Går 5 sekunder fra spilleren får killet til det vises i chatten. Jeg er bombesikker på at det er den det er noe galt med. Så, jeg trenger litt hjelp til å få minsket memory-usage på den men samtidig få mye bedre ytelse av den. Så hvis noen hadde giddet å hjulpet meg med det (redigere konfig) så hadde det hjulpet VELDIG mye. Poster config under; # # The MySQL database server configuration file. # # You can copy this to one of: # - "/etc/mysql/my.cnf" to set global options, # - "~/.my.cnf" to set user-specific options. # # One can use all long options that the program supports. # Run program with --help to get a list of available options and with # --print-defaults to see which it would actually understand and use. # # For explanations see # http://dev.mysql.com/doc/mysql/en/server-system-variables.html # This will be passed to all mysql clients # It has been reported that passwords should be enclosed with ticks/quotes # escpecially if they contain "#" chars... # Remember to edit /etc/mysql/debian.cnf when changing the socket location. [client] port = 3306 socket = /var/run/mysqld/mysqld.sock # Here is entries for some specific programs # The following values assume you have at least 32M ram # This was formally known as [safe_mysqld]. Both versions are currently parsed. [mysqld_safe] socket = /var/run/mysqld/mysqld.sock nice = 0 [mysqld] # # * Basic Settings # # # * IMPORTANT # If you make changes to these settings and your system uses apparmor, you may # also need to also adjust /etc/apparmor.d/usr.sbin.mysqld. # user = mysql socket = /var/run/mysqld/mysqld.sock port = 3306 basedir = /usr datadir = /var/lib/mysql tmpdir = /tmp skip-external-locking # # Instead of skip-networking the default is now to listen only on # localhost which is more compatible and is not less secure. bind-address = 127.0.0.1 # # * Fine Tuning # key_buffer = 16M max_allowed_packet = 16M thread_stack = 192K thread_cache_size = 8 # This replaces the startup script and checks MyISAM tables if needed # the first time they are touched myisam-recover = BACKUP #max_connections = 100 #table_cache = 64 #thread_concurrency = 10 # # * Query Cache Configuration # query_cache_limit = 1M query_cache_size = 16M # # * Logging and Replication # # Both location gets rotated by the cronjob. # Be aware that this log type is a performance killer. # As of 5.1 you can enable the log at runtime! #general_log_file = /var/log/mysql/mysql.log #general_log = 1 log_error = /var/log/mysql/error.log # Here you can see queries with especially long duration #log_slow_queries = /var/log/mysql/mysql-slow.log #long_query_time = 2 #log-queries-not-using-indexes # # The following can be used as easy to replay backup logs or for replication. # note: if you are setting up a replication slave, see README.Debian about # other settings you may need to change. #server-id = 1 #log_bin = /var/log/mysql/mysql-bin.log expire_logs_days = 10 max_binlog_size = 100M #binlog_do_db = include_database_name #binlog_ignore_db = include_database_name # # * InnoDB # # InnoDB is enabled by default with a 10MB datafile in /var/lib/mysql/. # Read the manual for more InnoDB related options. There are many! # # * Security Features # # Read the manual, too, if you want chroot! # chroot = /var/lib/mysql/ # # For generating SSL certificates I recommend the OpenSSL GUI "tinyca". # # ssl-ca=/etc/mysql/cacert.pem # ssl-cert=/etc/mysql/server-cert.pem # ssl-key=/etc/mysql/server-key.pem [mysqldump] quick quote-names max_allowed_packet = 16M [mysql] #no-auto-rehash # faster start of mysql but no tab completition [isamchk] key_buffer = 16M # # * IMPORTANT: Additional settings that can override those from this file! # The files must end with '.cnf', otherwise they'll be ignored. # !includedir /etc/mysql/conf.d/ Vil helst at den skal bruke under 200 MB men samtidig at den skal få meget bra hastighet på queries osv. Takk for all hjelp! Endret 6. september 2011 av cyclo Emnetittel forbedret Lenke til kommentar
tingo Skrevet 14. juli 2011 Del Skrevet 14. juli 2011 MySQL tuning: http://forums.mysql.com/read.php?24,92131,92131 Lenke til kommentar
medlem-193513 Skrevet 15. juli 2011 Forfatter Del Skrevet 15. juli 2011 Fant ett fint perlscript som het "MySQL Tuner" viser hva som må forandres i forhold til systemet osv. Lenke til kommentar
kpolberg Skrevet 15. juli 2011 Del Skrevet 15. juli 2011 Hvorfor i alle dager skal du ha mysql til å bruke mindre minne? I så å si alle tilfeller vil du at databasen skal ha _alt_ i minne. Lenke til kommentar
medlem-193513 Skrevet 15. juli 2011 Forfatter Del Skrevet 15. juli 2011 Fordi det er en VPS med 500 mb ram antar jeg? Er ikke noe stor database, og ingenting er indeksa. Lenke til kommentar
