Traces
[main] INFO 01:11:15.260 Starting PS3 Media Server 1.30.1
[main] INFO 01:11:15.277 by shagrath / 2008-2011
[main] INFO 01:11:15.278 http://ps3mediaserver.org
[main] INFO 01:11:15.278 http://code.google.com/p/ps3mediaserver
[main] INFO 01:11:15.278 http://ps3mediaserver.blogspot.com
[main] INFO 01:11:15.279
[main] INFO 01:11:15.280 Java: 1.6.0_26-Sun Microsystems Inc.
[main] INFO 01:11:15.281 OS: Windows 7 x86 6.1
[main] INFO 01:11:15.281 Encoding: UTF-8
[main] INFO 01:11:15.282 Working directory: C:\Program Files (x86)\PS3 Media Server
[main] INFO 01:11:15.338 Temp folder: C:\Users\ilch0801\AppData\Local\Temp\ps3mediaserver
[main] INFO 01:11:15.341 Logging config file: C:\Program Files (x86)\PS3 Media Server\logback.xml
[main] INFO 01:11:15.342 debug.log: C:\Program Files (x86)\PS3 Media Server\debug.log
[main] INFO 01:11:15.346
[main] INFO 01:11:15.347 Profile directory: C:\ProgramData\PMS
[main] INFO 01:11:15.347 Profile path: C:\ProgramData\PMS\PMS.conf
[main] INFO 01:11:15.349 Profile status: no such file
[main] INFO 01:11:15.350 Profile name: PD1006386
[main] INFO 01:11:15.411 Loading MediaInfo library
[main] INFO 01:11:15.960 Loaded MediaInfoLib - v0.7.44
[main] INFO 01:11:16.016 Loading renderer configurations from C:\Program Files (x86)\PS3 Media Server\renderers
[main] INFO 01:11:16.017 Loading configuration file: Android.conf
[main] INFO 01:11:16.083 Loading configuration file: Bravia4500.conf
[main] INFO 01:11:16.101 Loading configuration file: Bravia5500.conf
[main] INFO 01:11:16.117 Loading configuration file: BraviaEX.conf
[main] INFO 01:11:16.191 Loading configuration file: FreeboxHD.conf
[main] INFO 01:11:16.207 Loading configuration file: FreecomMusicPal.conf
[main] INFO 01:11:16.216 Loading configuration file: Kuro.conf
[main] INFO 01:11:16.220 Loading configuration file: N900.conf
[main] INFO 01:11:16.230 Loading configuration file: Panasonic.conf
[main] INFO 01:11:16.244 Loading configuration file: Philips.conf
[main] INFO 01:11:16.254 Loading configuration file: PopcornHour.conf
[main] INFO 01:11:16.257 Loading configuration file: PS3.conf
[main] INFO 01:11:16.266 Loading configuration file: Realtek.conf
[main] INFO 01:11:16.278 Loading configuration file: Samsung.conf
[main] INFO 01:11:16.281 Loading configuration file: Streamium.conf
[main] INFO 01:11:16.286 Loading configuration file: WDTVLive.conf
[main] INFO 01:11:16.297 Loading configuration file: WMP.conf
[main] INFO 01:11:16.308 Loading configuration file: XBMC.conf
[main] INFO 01:11:16.312 Loading configuration file: XBOX360.conf
[main] INFO 01:11:16.324 Checking MPlayer font cache. It can take a minute or so.
[main] INFO 01:11:18.424 Done!
[main] INFO 01:11:18.424 Found VideoLAN version 1.1.9 at: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
[main] INFO 01:11:18.531 Loading plugins from C:\Program Files (x86)\PS3 Media Server\plugins
[main] INFO 01:11:18.546 No plugins found
[main] INFO 01:11:18.563 Transcoder profile AviSynth/FFmpeg will not be used because AviSynth was not found
[main] INFO 01:11:18.566 Registering transcoding engine: FFmpeg Audio
[main] INFO 01:11:18.638 Registering transcoding engine: MEncoder
[main] INFO 01:11:18.640 Transcoder profile Avisynth/MEncoder will not be used because AviSynth was not found
[main] INFO 01:11:18.642 Registering transcoding engine: MPlayer Audio
[main] INFO 01:11:18.643 Registering transcoding engine: MEncoder Web
[main] INFO 01:11:18.644 Registering transcoding engine: MPlayer Video Dump
[main] INFO 01:11:18.644 Registering transcoding engine: MPlayer Web
[main] INFO 01:11:18.657 Registering transcoding engine: TsMuxer
[main] INFO 01:11:18.658 Registering transcoding engine: Audio High Fidelity
[main] INFO 01:11:18.723 Registering transcoding engine: VLC Audio Streaming
[main] INFO 01:11:18.725 Registering transcoding engine: VLC Video Streaming
[main] INFO 01:11:18.726 Registering transcoding engine: FFmpeg DVR-MS Remux
[main] INFO 01:11:18.727 Registering transcoding engine: Raws Thumbnailer
[main] INFO 01:11:18.728 AviSynth is not installed. You cannot use avsmencoder as a transcoding engine.
[main] INFO 01:11:20.354 Scanning network interface lo / Software Loopback Interface 1
[main] INFO 01:11:20.360 Scanning network interface net0 / WAN Miniport (SSTP)
[main] INFO 01:11:20.366 Scanning network interface net1 / WAN Miniport (IKEv2)
[main] INFO 01:11:20.371 Scanning network interface net2 / WAN Miniport (L2TP)
[main] INFO 01:11:20.380 Scanning network interface net3 / WAN Miniport (PPTP)
[main] INFO 01:11:20.385 Scanning network interface ppp0 / WAN Miniport (PPPOE)
[main] INFO 01:11:20.392 Scanning network interface eth0 / WAN Miniport (IPv6)
[main] INFO 01:11:20.397 Scanning network interface eth1 / WAN Miniport (Network Monitor)
[main] INFO 01:11:20.403 Scanning network interface eth2 / WAN Miniport (IP)
[main] INFO 01:11:20.409 Scanning network interface ppp1 / RAS Async Adapter
[main] INFO 01:11:20.420 Scanning network interface eth3 / Realtek PCIe GBE Family Controller
[main] INFO 01:11:20.426 Scanning network interface net4 / DW1520 Wireless-N halvt Mini-kort
[main] INFO 01:11:20.434 Using address /192.168.2.9 found on network interface: name:net4 (DW1520 Wireless-N halvt Mini-kort)
[main] INFO 01:11:20.435 Created socket: /192.168.2.9:5001
[main] INFO 01:11:23.434 Unable to retrieve MAC address for UUID creation: using a random one...
[main] INFO 01:11:23.491 Using the following UUID: 805c1fe6-8127-307e-9fc3-bb0b1bb2a033
[main] INFO 01:11:27.263 The server should now appear on your renderer
