høyenhall Skrevet 8. juli 2011 Del Skrevet 8. juli 2011 Hei Driver å setter opp en LAMP server under Ubuntu 11.04, og har noen problemer med rettighetene i /var/www. Slenger med en dump av /etc/apache2/error.log [Fri Jul 08 10:55:57 2011] [notice] caught SIGTERM, shutting down [Fri Jul 08 10:56:18 2011] [notice] Apache/2.2.17 (Ubuntu) PHP/5.3.5-1ubuntu7.2 with Suhosin-Patch configured -- resuming normal operations [Fri Jul 08 10:56:36 2011] [error] [client 10.144.37.196] PHP Warning: require_once(Connections/sql.php): failed to open stream: Permission denied in /var/w$ [Fri Jul 08 10:56:36 2011] [error] [client 10.144.37.196] PHP Fatal error: require_once(): Failed opening required 'Connections/sql.php' (include_path='.:/u$ [Fri Jul 08 10:58:39 2011] [error] [client 10.144.37.196] PHP Warning: require_once(Connections/sql.php): failed to open stream: Permission denied in /var/w$ [Fri Jul 08 10:58:39 2011] [error] [client 10.144.37.196] PHP Fatal error: require_once(): Failed opening required 'Connections/sql.php' (include_path='.:/u$ [Fri Jul 08 10:58:40 2011] [error] [client 10.144.37.196] PHP Warning: require_once(Connections/sql.php): failed to open stream: Permission denied in /var/w$ [Fri Jul 08 10:58:40 2011] [error] [client 10.144.37.196] PHP Fatal error: require_once(): Failed opening required 'Connections/sql.php' (include_path='.:/u$ [Fri Jul 08 10:59:58 2011] [error] [client 10.144.37.196] (13)Permission denied: access to /css/tekst.css denied, referer: http://10.144.32.5/login.php?acces$ [Fri Jul 08 10:59:58 2011] [error] [client 10.144.37.196] (13)Permission denied: access to /css/meny.css denied, referer: http://10.144.32.5/login.php?access$ [Fri Jul 08 10:59:58 2011] [error] [client 10.144.37.196] (13)Permission denied: access to /img/img_top.jpg denied, referer: http://10.144.32.5/login.php?acc$ [Fri Jul 08 10:59:58 2011] [error] [client 10.144.37.196] (13)Permission denied: access to /SpryAssets/SpryValidationPassword.js denied, referer: http://10.1$ [Fri Jul 08 10:59:58 2011] [error] [client 10.144.37.196] (13)Permission denied: access to /SpryAssets/SpryValidationTextField.js denied, referer: http://10.$ [Fri Jul 08 10:59:58 2011] [error] [client 10.144.37.196] (13)Permission denied: access to /SpryAssets/SpryValidationPassword.css denied, referer: http://10.$ [Fri Jul 08 10:59:58 2011] [error] [client 10.144.37.196] (13)Permission denied: access to /SpryAssets/SpryValidationTextField.js denied, referer: http://10.$ [Fri Jul 08 10:59:58 2011] [error] [client 10.144.37.196] (13)Permission denied: access to /img/img_top.jpg denied, referer: http://10.144.32.5/login.php?acc$ [Fri Jul 08 10:59:58 2011] [error] [client 10.144.37.196] (13)Permission denied: access to /SpryAssets/SpryValidationPassword.css denied, referer: http://10.$ [Fri Jul 08 10:59:59 2011] [error] [client 10.144.37.196] (13)Permission denied: access to /SpryAssets/SpryValidationTextField.css denied, referer: http://10$ [Fri Jul 08 11:00:24 2011] [error] [client 10.144.37.196] (13)Permission denied: access to /img/img_top.jpg denied, referer: http://10.144.32.5/login.php?acc$ [Fri Jul 08 11:00:24 2011] [error] [client 10.144.37.196] (13)Permission denied: access to /img/img_top.jpg denied, referer: http://10.144.32.5/login.php?acc$ [Fri Jul 08 11:03:54 2011] [error] [client 10.144.37.196] (13)Permission denied: access to /img/img_top.jpg denied, referer: http://10.144.32.5/login.php?acc$ [Fri Jul 08 11:03:54 2011] [error] [client 10.144.37.196] (13)Permission denied: access to /img/img_top.jpg denied, referer: http://10.144.32.5/login.php?acc$ [Fri Jul 08 11:05:09 2011] [error] [client 10.144.37.196] (13)Permission denied: access to /img/img_top.jpg denied, referer: http://10.144.32.5/login.php?acc$ [Fri Jul 08 11:05:09 2011] [error] [client 10.144.37.196] (13)Permission denied: access to /img/img_top.jpg denied, referer: http://10.144.32.5/login.php?acc$ [Fri Jul 08 11:06:21 2011] [error] [client 10.144.37.196] (13)Permission denied: access to /css/tekst.css denied, referer: http://10.144.32.5/login.php [Fri Jul 08 11:06:21 2011] [error] [client 10.144.37.196] (13)Permission denied: access to /css/meny.css denied, referer: http://10.144.32.5/login.php [Fri Jul 08 11:06:21 2011] [error] [client 10.144.37.196] (13)Permission denied: access to /SpryAssets/SpryValidationPassword.js denied, referer: http://10.1$ [Fri Jul 08 11:06:21 2011] [error] [client 10.144.37.196] (13)Permission denied: access to /SpryAssets/SpryValidationTextField.js denied, referer: http://10.$ [Fri Jul 08 11:06:21 2011] [error] [client 10.144.37.196] (13)Permission denied: access to /SpryAssets/SpryValidationPassword.css denied, referer: http://10.$ [Fri Jul 08 11:06:21 2011] [error] [client 10.144.37.196] (13)Permission denied: access to /SpryAssets/SpryValidationTextField.css denied, referer: http://10$ [Fri Jul 08 11:06:21 2011] [error] [client 10.144.37.196] (13)Permission denied: access to /img/img_top.jpg denied, referer: http://10.144.32.5/login.php [Fri Jul 08 11:06:21 2011] [error] [client 10.144.37.196] (13)Permission denied: access to /SpryAssets/SpryValidationPassword.css denied, refere Fint om noen kan dirigere meg i riktig retning, takker på forhånd for alle svar :-) Lenke til kommentar
DCreator Skrevet 8. juli 2011 Del Skrevet 8. juli 2011 Hvem er eier og hva er rettighetene til filene i /var/www ? Du kan ta ls -la i den mappen for å finne det ut. Jeg er ikke sikker på hvilken bruker eller gruppe det skal være(det burde stå en plass i dokumentasjonen til apache eller andre plasser), men det ser ihvertfall ut som om det kan være noe slikt som er problemet ut ifra feilmeldingene å dømme. Lenke til kommentar
Gjest Skrevet 8. juli 2011 Del Skrevet 8. juli 2011 Muligens eier og gruppe skal være www-data Lenke til kommentar
høyenhall Skrevet 8. juli 2011 Forfatter Del Skrevet 8. juli 2011 (endret) Edit Saken er løst Endret 8. juli 2011 av garyoak Lenke til kommentar
DCreator Skrevet 8. juli 2011 Del Skrevet 8. juli 2011 Kan se at img mappa kun har rettighet drwx------, som medfører at root, og bare root kan åpne den mappa. Da er det ikke så rart at permission denied kommer opp: [Fri Jul 08 10:59:58 2011] [error] [client 10.144.37.196] (13)Permission denied: access to /img/img_top.jpg denied, referer: Du burde vell sikkert hatt drwxr-xr-x som rettighet der? Jeg er ikke sikker på hva som er vanlig på apache webservere. Men i det minste, så er det grunnen til noen av feilmeldingene dine tror jeg. Ikke glem at alle filene i alle mapper(som skal være tilgjengelige) også må være tilgjengelige for alle. Lenke til kommentar
