Malwarebytes, antivirus-logg, trenger hjelp
Jeg scannet PCen og fant en regkey, og fjernet den.
Jeg vet også at csrss.exe ligger på PCen.
Hva skal jeg gjøre?
takker for all hjelp! :)
DET ER csrss.exe JEG ER UTE ETTER OG TA
LOGG:
Malwarebytes' Anti-Malware 1.51.0.1200
www.malwarebytes.org
Databaseversjon: 6959
Windows 6.1.7600
Internet Explorer 8.0.7600.16385
27.06.2011 14:42:07
mbam-log-2011-06-27 (14-42-07).txt
Skanntype: Hurtigsøk
Objekter skannet: 168509
Tid tilbakelagt: 6 minutt(er), 6 sekund(er)
Minneprosesser infisert: 0
Minnemoduler infisert: 0
Registernøkler infisert: 0
Registerverdier infisert: 0
Registerfiler infisert: 1
Mapper infisert: 0
Filer infisert 0
(Ingen skadelige objekter funnet)
HKEY_CLASSES_ROOT\regfile\shell\open\command\(default) (Broken.OpenCommand) -> Bad: ("regedit.exe" "%1") Good: (regedit.exe "%1") -> Quarantined and deleted successfully.
Mapper infisert:
Filer infisert
Endret av Coaxke
PCen går veldig trengt, og jeg har problemer med firewallen
Lag meg et OTL Log og post dette:
http://www.smokey-services.eu/forums/index.php/topic,68251.0.html
  • Download OTL to your desktop.
  • Double click on the icon to run it. Make sure all other windows are closed to let it run uninterrupted.
  • When the window appears, underneath Output at the top change it to Minimal Output.
  • Under the Standard Registry box change it to All.
  • Check the boxes beside LOP Check and Purity Check.
  • Click the Run Scan button. Do not change any settings unless otherwise told to do so. The scan wont take long.
  • When the scan completes, it will open two notepad windows. OTL.Txt and Extras.Txt. These are saved in the same location as OTL.
  • Please copy (Edit->Select All, Edit->Copy) the contents of these files, one at a time, and post it with your next reply.
