ludder Skrevet 5. februar 2002 Del Skrevet 5. februar 2002 Jeg har en Yamaha 2100E som ifølge http://www.disc4you.com/news/99min.html skulle kunne brenne disse. Men når jeg skal brenne oppgir nero at availible size er 10 minutter (96mb). Hva er galt?! Har prøvd med overburn men det funket ikke(ja brenneren støtter overburn). Lenke til kommentar
Ronnyb Skrevet 5. februar 2002 Del Skrevet 5. februar 2002 Ikke akkurat svar dette da men hvor fikk du tak i disse cdene. Lenke til kommentar
thomasolsen Skrevet 5. februar 2002 Del Skrevet 5. februar 2002 Recording programs get their information about the blank from the ATIP of the media. If the ATIP specifies a maximum time of 80 minutes then the only way to use any space beyond that is the method of so-called 'Overburning' which was until now used in cases where one wanted to sqeeze a little more information onto a 74 minute blank. That means that you need the right software which enables you to 'overburn' blanks. The program will normally display a warning message in these cases. Under certain circumstances the program will not be able to process the blank at all. It will at least display the 'wrong' maximum recording space of the blank because the specified time is 80 minutes. Otherwise all recorders would reject the media. Conclusions Working with both CD-Rs of more than 650 MB and the 'overburning' method requires a compatible recorder as well as the right recording software. In terms of software we recommend CDRWIN from Golden Hawk, DiscJuggler or cdrecord from Jörg Schilling. Should you want to use recording software from other manufacturers, we recommend that you contact themdirectly. A list of compatible drives can be found here: Lenke til kommentar
ludder Skrevet 5. februar 2002 Forfatter Del Skrevet 5. februar 2002 Jeg kjøpte de på itbutikken.no. 500 kr rett i dass, får ikke brent 100mb engang på de :/ Lenke til kommentar
