[Løst] Gnome vil ikke starte etter Nvidia driver inst Arch Linux
Har installert Arch Linux. Når jeg kjører startx får jeg en svart skjerm med text. Altså ingen ting starter.Det kommer opp en error main.c: Daemon startup failed
Har installert pulseaudio, alsa-plugins.
X seerver
pacman -S xorg-server xorg-xinit xorg-utils xorg-server-utils
Nvidia driver
pacman -S nvidia
Gnome
pacman -S gnome gnome-extra gnome-system-tools.
Har Asus P67 HK og Nvidia GTX 580.
Her er Xorg logen:
[    54.238]
X.Org X Server 1.10.2
Release Date: 2011-05-28
[    54.238] X Protocol Version 11, Revision 0
[    54.238] Build Operating System: Linux 2.6.38-ARCH x86_64
[    54.238] Current Operating System: Linux ArchLinux 2.6.39-ARCH #1 SMP PREEMPT Mon Jun 6 22:37:55 CEST 2011 x86_64
[    54.239] Kernel command line: root=/dev/disk/by-uuid/e26e4344-a0b4-4f57-a713-5f515f1f673a ro
[    54.239] Build Date: 30 May 2011  08:18:15AM
[    54.239]
[    54.239] Current version of pixman: 0.22.0
[    54.239]     Before reporting problems, check http://wiki.x.org
   to make sure that you have the latest version.
[    54.240] Markers: (--) probed, (**) from config file, (==) default setting,
   (++) from command line, (!!) notice, (II) informational,
   (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    54.241] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Jun 12 20:13:40 2011
[    54.282] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    54.300] (==) No Layout section.  Using the first Screen section.
[    54.300] (==) No screen section available. Using defaults.
[    54.300] (**) |-->Screen "Default Screen Section" (0)
[    54.300] (**) |   |-->Monitor "<default monitor>"
[    54.300] (==) No device specified for screen "Default Screen Section".
   Using the first device section listed.
[    54.300] (**) |   |-->Device "Default nvidia Device"
[    54.300] (==) No monitor specified for screen "Default Screen Section".
   Using a default monitor configuration.
[    54.301] (==) Automatically adding devices
[    54.301] (==) Automatically enabling devices
[    54.320] (WW) The directory "/usr/share/fonts/OTF/" does not exist.
[    54.320]     Entry deleted from font path.
[    54.335] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
[    54.335]     Entry deleted from font path.
[    54.335]     (Run 'mkfontdir' on "/usr/share/fonts/100dpi/").
[    54.336] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
[    54.336]     Entry deleted from font path.
[    54.336]     (Run 'mkfontdir' on "/usr/share/fonts/75dpi/").
[    54.336] (==) FontPath set to:
   /usr/share/fonts/misc/,
   /usr/share/fonts/TTF/,
   /usr/share/fonts/Type1/
[    54.336] (==) ModulePath set to "/usr/lib/xorg/modules"
[    54.336] (II) The server relies on udev to provide the list of input devices.
   If no devices become available, reconfigure udev or disable AutoAddDevices.
[    54.336] (II) Loader magic: 0x7d3440
[    54.336] (II) Module ABI versions:
[    54.336]     X.Org ANSI C Emulation: 0.4
[    54.336]     X.Org Video Driver: 10.0
[    54.336]     X.Org XInput driver : 12.2
[    54.336]     X.Org Server Extension : 5.0
[    54.336] (--) PCI:*(0:1:0:0) 10de:1080:3842:1583 rev 161, Mem @ 0xfa000000/16777216, 0xf0000000/134217728, 0xf8000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[    54.336] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    54.336] (II) LoadModule: "extmod"
[    54.337] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[    54.344] (II) Module extmod: vendor="X.Org Foundation"
[    54.344]     compiled for 1.10.2, module version = 1.0.0
[    54.344]     Module class: X.Org Server Extension
[    54.344]     ABI class: X.Org Server Extension, version 5.0
[    54.344] (II) Loading extension MIT-SCREEN-SAVER
[    54.344] (II) Loading extension XFree86-VidModeExtension
[    54.344] (II) Loading extension XFree86-DGA
[    54.344] (II) Loading extension DPMS
[    54.344] (II) Loading extension XVideo
[    54.344] (II) Loading extension XVideo-MotionCompensation
[    54.344] (II) Loading extension X-Resource
[    54.344] (II) LoadModule: "dbe"
[    54.344] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[    54.344] (II) Module dbe: vendor="X.Org Foundation"
[    54.344] (II) Loading extension DOUBLE-BUFFER
[    54.344] (II) LoadModule: "glx"
[    54.344] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    55.197] (II) Module glx: vendor="NVIDIA Corporation"
[    55.206]     compiled for 4.0.2, module version = 1.0.0
[    55.206]     Module class: X.Org Server Extension
[    55.206] (II) NVIDIA GLX Module  270.41.19  Mon May 16 23:48:30 PDT 2011
[    55.206] (II) Loading extension GLX
[    55.206] (II) LoadModule: "record"
[    55.206] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[    55.212] (II) Module record: vendor="X.Org Foundation"
[    55.212]     compiled for 1.10.2, module version = 1.13.0
[    55.212]     Module class: X.Org Server Extension
[    55.212]     ABI class: X.Org Server Extension, version 5.0
[    55.212] (II) Loading extension RECORD
[    55.212] (II) LoadModule: "dri"
[    55.212] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[    55.220] (II) Module dri: vendor="X.Org Foundation"
[    55.220]     compiled for 1.10.2, module version = 1.0.0
[    55.220]     ABI class: X.Org Server Extension, version 5.0
[    55.220] (II) Loading extension XFree86-DRI
[    55.220] (II) LoadModule: "dri2"
[    55.220] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[    55.221] (II) Module dri2: vendor="X.Org Foundation"
[    55.221]     compiled for 1.10.2, module version = 1.2.0
[    55.221]     ABI class: X.Org Server Extension, version 5.0
[    55.221] (II) Loading extension DRI2
[    55.221] (II) LoadModule: "nvidia"
[    55.228] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    55.287] (II) Module nvidia: vendor="NVIDIA Corporation"
[    55.289]     compiled for 4.0.2, module version = 1.0.0
[    55.289]     Module class: X.Org Video Driver
[    55.305] (II) NVIDIA dlloader X Driver  270.41.19  Mon May 16 23:33:35 PDT 2011
[    55.305] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    55.307] (--) using VT number 7
[    55.320] (II) Loading sub module "fb"
[    55.320] (II) LoadModule: "fb"
[    55.320] (II) Loading /usr/lib/xorg/modules/libfb.so
[    55.330] (II) Module fb: vendor="X.Org Foundation"
[    55.330]     compiled for 1.10.2, module version = 1.0.0
[    55.330]     ABI class: X.Org ANSI C Emulation, version 0.4
[    55.330] (II) Loading sub module "wfb"
[    55.330] (II) LoadModule: "wfb"
[    55.330] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    55.334] (II) Module wfb: vendor="X.Org Foundation"
[    55.334]     compiled for 1.10.2, module version = 1.0.0
[    55.334]     ABI class: X.Org ANSI C Emulation, version 0.4
[    55.334] (II) Loading sub module "ramdac"
[    55.334] (II) LoadModule: "ramdac"
[    55.334] (II) Module "ramdac" already built-in
[    55.336] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    55.336] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    55.336] (II) Loading /usr/lib/xorg/modules/libfb.so
[    55.356] (II) NVIDIA(0): Creating default Display subsection in Screen section
   "Default Screen Section" for depth/fbbpp 24/32
[    55.356] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[    55.356] (==) NVIDIA(0): RGB weight 888
[    55.356] (==) NVIDIA(0): Default visual is TrueColor
[    55.356] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    55.356] (**) NVIDIA(0): Option "NoLogo" "True"
[    56.065] (II) NVIDIA(GPU-0): Display (BenQ E2200HD (DFP-1)) does not support NVIDIA 3D
[    56.065] (II) NVIDIA(GPU-0):     Vision stereo.
[    56.067] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 580 (GF110) at PCI:1:0:0 (GPU-0)
[    56.067] (--) NVIDIA(0): Memory: 1572864 kBytes
[    56.067] (--) NVIDIA(0): VideoBIOS: 70.10.17.00.82
[    56.067] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[    56.067] (--) NVIDIA(0): Interlaced video modes are supported on this GPU
[    56.067] (--) NVIDIA(0): Connected display device(s) on GeForce GTX 580 at PCI:1:0:0
[    56.067] (--) NVIDIA(0):     BenQ E2200HD (DFP-1)
[    56.067] (--) NVIDIA(0): BenQ E2200HD (DFP-1): 165.0 MHz maximum pixel clock
[    56.067] (--) NVIDIA(0): BenQ E2200HD (DFP-1): Internal Single Link TMDS
[    56.074] (WW) NVIDIA(0): The EDID for BenQ E2200HD (DFP-1) contradicts itself: mode
[    56.074] (WW) NVIDIA(0):     "720x480" is specified in the EDID; however, the EDID's
[    56.074] (WW) NVIDIA(0):     valid HorizSync range (30.000-94.000 kHz) would exclude
[    56.074] (WW) NVIDIA(0):     this mode's HorizSync (15.7 kHz); ignoring HorizSync check
[    56.074] (WW) NVIDIA(0):     for mode "720x480".
[    56.075] (WW) NVIDIA(0): The EDID for BenQ E2200HD (DFP-1) contradicts itself: mode
[    56.075] (WW) NVIDIA(0):     "720x576" is specified in the EDID; however, the EDID's
[    56.075] (WW) NVIDIA(0):     valid HorizSync range (30.000-94.000 kHz) would exclude
[    56.075] (WW) NVIDIA(0):     this mode's HorizSync (15.6 kHz); ignoring HorizSync check
[    56.075] (WW) NVIDIA(0):     for mode "720x576".
[    56.075] (WW) NVIDIA(0):     "1920x1080" is specified in the EDID; however, the EDID's
[    56.075] (WW) NVIDIA(0):     this mode's HorizSync (28.1 kHz); ignoring HorizSync check
[    56.075] (WW) NVIDIA(0):     for mode "1920x1080".
[    56.076] (WW) NVIDIA(0): The EDID for BenQ E2200HD (DFP-1) contradicts itself: mode
[    56.076] (WW) NVIDIA(0):     "720x480" is specified in the EDID; however, the EDID's
[    56.076] (WW) NVIDIA(0):     valid HorizSync range (30.000-94.000 kHz) would exclude
[    56.076] (WW) NVIDIA(0):     this mode's HorizSync (15.7 kHz); ignoring HorizSync check
[    56.076] (WW) NVIDIA(0):     for mode "720x480".
[    56.076] (WW) NVIDIA(0):     "720x576" is specified in the EDID; however, the EDID's
[    56.076] (WW) NVIDIA(0):     this mode's HorizSync (15.6 kHz); ignoring HorizSync check
[    56.076] (WW) NVIDIA(0):     for mode "720x576".
[    56.077] (WW) NVIDIA(0): The EDID for BenQ E2200HD (DFP-1) contradicts itself: mode
[    56.077] (WW) NVIDIA(0):     "1920x1080" is specified in the EDID; however, the EDID's
[    56.077] (WW) NVIDIA(0):     valid HorizSync range (30.000-94.000 kHz) would exclude
[    56.077] (WW) NVIDIA(0):     this mode's HorizSync (28.1 kHz); ignoring HorizSync check
[    56.077] (WW) NVIDIA(0):     for mode "1920x1080".
[    56.095] (II) NVIDIA(0): Assigned Display Device: DFP-1
[    56.095] (==) NVIDIA(0):
[    56.095] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[    56.095] (==) NVIDIA(0):     will be used as the requested mode.
[    56.095] (II) NVIDIA(0): Validated modes:
[    56.095] (II) NVIDIA(0):     "nvidia-auto-select"
[    56.095] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[    56.127] (--) NVIDIA(0): DPI set to (103, 105); computed from "UseEdidDpi" X config
[    56.127] (--) NVIDIA(0):     option
[    56.127] (--) Depth 24 pixmap format is 32 bpp
[    56.127] (II) NVIDIA: Using 3072.00 MB of virtual memory for indirect memory
[    56.127] (II) NVIDIA:     access.
[    56.131] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[    56.131] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[    56.131] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[    56.131] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[    56.131] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[    56.131] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[    56.131] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[    56.131] (II) NVIDIA(0):     Config Options in the README.
[    56.133] (II) NVIDIA(0): Setting mode "nvidia-auto-select"
[    56.190] (II) Loading extension NV-GLX
[    56.275] (==) NVIDIA(0): Disabling shared memory pixmaps
[    56.275] (==) NVIDIA(0): Backing store disabled
[    56.275] (==) NVIDIA(0): Silken mouse enabled
[    56.277] (==) NVIDIA(0): DPMS enabled
[    56.278] (II) Loading extension NV-CONTROL
[    56.278] (II) Loading extension XINERAMA
[    56.278] (II) Loading sub module "dri2"
[    56.278] (II) LoadModule: "dri2"
[    56.278] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[    56.278] (II) Module dri2: vendor="X.Org Foundation"
[    56.278]     compiled for 1.10.2, module version = 1.2.0
[    56.278]     ABI class: X.Org Server Extension, version 5.0
[    56.278] (II) NVIDIA(0): [DRI2] Setup complete
[    56.278] (==) RandR enabled
[    56.278] (II) Initializing built-in extension Generic Event Extension
[    56.278] (II) Initializing built-in extension SHAPE
[    56.278] (II) Initializing built-in extension MIT-SHM
[    56.278] (II) Initializing built-in extension XInputExtension
[    56.278] (II) Initializing built-in extension XTEST
[    56.278] (II) Initializing built-in extension BIG-REQUESTS
[    56.278] (II) Initializing built-in extension SYNC
[    56.278] (II) Initializing built-in extension XKEYBOARD
[    56.278] (II) Initializing built-in extension XC-MISC
[    56.278] (II) Initializing built-in extension SECURITY
[    56.278] (II) Initializing built-in extension XINERAMA
[    56.278] (II) Initializing built-in extension XFIXES
[    56.278] (II) Initializing built-in extension RENDER
[    56.278] (II) Initializing built-in extension RANDR
[    56.278] (II) Initializing built-in extension COMPOSITE
[    56.278] (II) Initializing built-in extension DAMAGE
[    56.279] (II) Initializing extension GLX
[    56.610] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[    56.610] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    56.610] (II) LoadModule: "evdev"
[    56.610] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    56.619] (II) Module evdev: vendor="X.Org Foundation"
[    56.619]     compiled for 1.10.0, module version = 2.6.0
[    56.619]     Module class: X.Org XInput Driver
[    56.619]     ABI class: X.Org XInput driver, version 12.2
[    56.619] (II) Using input driver 'evdev' for 'Power Button'
[    56.619] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    56.619] (**) Power Button: always reports core events
[    56.619] (**) Power Button: Device: "/dev/input/event1"
[    56.650] (--) Power Button: Found keys
[    56.650] (II) Power Button: Configuring as keyboard
[    56.650] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[    56.650] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
[    56.650] (**) Option "xkb_rules" "evdev"
[    56.650] (**) Option "xkb_model" "evdev"
[    56.650] (**) Option "xkb_layout" "us"
[    56.664] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[    56.664] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    56.664] (II) Using input driver 'evdev' for 'Power Button'
[    56.664] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    56.664] (**) Power Button: always reports core events
[    56.664] (**) Power Button: Device: "/dev/input/event0"
[    56.690] (--) Power Button: Found keys
[    56.690] (II) Power Button: Configuring as keyboard
[    56.690] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0/event0"
[    56.690] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
[    56.690] (**) Option "xkb_rules" "evdev"
[    56.690] (**) Option "xkb_model" "evdev"
[    56.690] (**) Option "xkb_layout" "us"
[    56.691] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event4)
[    56.691] (II) No input driver/identifier specified (ignoring)
[    56.693] (II) config/udev: Adding input device Chicony Saitek Eclipse Keyboard (/dev/input/event5)
[    56.693] (**) Chicony Saitek Eclipse Keyboard: Applying InputClass "evdev keyboard catchall"
[    56.693] (II) Using input driver 'evdev' for 'Chicony Saitek Eclipse Keyboard'
[    56.693] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    56.693] (**) Chicony Saitek Eclipse Keyboard: always reports core events
[    56.693] (**) Chicony Saitek Eclipse Keyboard: Device: "/dev/input/event5"
[    56.716] (--) Chicony Saitek Eclipse Keyboard: Found keys
[    56.716] (II) Chicony Saitek Eclipse Keyboard: Configuring as keyboard
[    56.716] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb6/6-1/6-1.3/6-1.3:1.0/input/input5/event5"
[    56.716] (II) XINPUT: Adding extended input device "Chicony Saitek Eclipse Keyboard" (type: KEYBOARD)
[    56.716] (**) Option "xkb_rules" "evdev"
[    56.716] (**) Option "xkb_model" "evdev"
[    56.716] (**) Option "xkb_layout" "us"
[    56.717] (II) config/udev: Adding input device Chicony Saitek Eclipse Keyboard (/dev/input/event6)
[    56.717] (**) Chicony Saitek Eclipse Keyboard: Applying InputClass "evdev keyboard catchall"
[    56.717] (II) Using input driver 'evdev' for 'Chicony Saitek Eclipse Keyboard'
[    56.717] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    56.717] (**) Chicony Saitek Eclipse Keyboard: always reports core events
[    56.717] (**) Chicony Saitek Eclipse Keyboard: Device: "/dev/input/event6"
[    56.743] (--) Chicony Saitek Eclipse Keyboard: Found keys
[    56.743] (II) Chicony Saitek Eclipse Keyboard: Configuring as keyboard
[    56.743] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb6/6-1/6-1.3/6-1.3:1.1/input/input6/event6"
[    56.743] (II) XINPUT: Adding extended input device "Chicony Saitek Eclipse Keyboard" (type: KEYBOARD)
[    56.743] (**) Option "xkb_rules" "evdev"
[    56.743] (**) Option "xkb_model" "evdev"
[    56.743] (**) Option "xkb_layout" "us"
[    56.744] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event3)
[    56.744] (**) Eee PC WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[    56.744] (II) Using input driver 'evdev' for 'Eee PC WMI hotkeys'
[    56.744] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    56.744] (**) Eee PC WMI hotkeys: always reports core events
[    56.744] (**) Eee PC WMI hotkeys: Device: "/dev/input/event3"
[    56.783] (--) Eee PC WMI hotkeys: Found keys
[    56.783] (II) Eee PC WMI hotkeys: Configuring as keyboard
[    56.783] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input3/event3"
[    56.783] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD)
[    56.783] (**) Option "xkb_rules" "evdev"
[    56.783] (**) Option "xkb_model" "evdev"
[    56.783] (**) Option "xkb_layout" "us"
[    56.783] (II) config/udev: Adding input device PC Speaker (/dev/input/event2)
[    56.783] (II) No input driver/identifier specified (ignoring)
[    58.250] (II) Power Button: Close
[    58.250] (II) UnloadModule: "evdev"
[    58.250] (II) Unloading evdev
[    58.303] (II) Power Button: Close
[    58.303] (II) UnloadModule: "evdev"
[    58.303] (II) Unloading evdev
[    58.360] (II) Chicony Saitek Eclipse Keyboard: Close
[    58.360] (II) UnloadModule: "evdev"
[    58.360] (II) Unloading evdev
[    58.410] (II) Chicony Saitek Eclipse Keyboard: Close
[    58.410] (II) UnloadModule: "evdev"
[    58.410] (II) Unloading evdev
[    58.463] (II) Eee PC WMI hotkeys: Close
[    58.463] (II) UnloadModule: "evdev"
[    58.463] (II) Unloading evdev
Hei. Du har lagt til gdm i rc.conf sant?
Har du laga en xorg.conf? Hvis du har det så prøver du få fjerne den.
Jeg har ikke laga noen xorg.conf på mine Arch installasjoner iallefall og de starter fint.
Hvis det ikke fungerer så kan du prøve å installere enten nouveau-dri eller xf86-video-nv
Siden at du har et nokså nytt Nvidia skjermkort, så skulle man tro at pacman -S nvidia skulle gå greit, men.
Lykke til.
Hilsen. wil.
Lykke til.
Hilsen. wil.
Jeg har ikke laget noen xorg.conf
Har ikke lagt til gdm i rc.conf siden jeg har prøvd det en gang før men gjør det nå.
Funker med nouveau driver men jeg vil ha ytelse på mitt GTX 580 kort. Trenger full ytelse.
EDIT: Prøvde og legge til GDM under daemons men ingen hjelp
Endret av MikalD
