64-bit desktop systemer på vei
"Mac OS X 10.2.7, codenamed 'Smeagol', is a 32-bit OS, but certain libraries and other elements have been recoded to allow it to make use of the 64-bit addressing provided by the G5's 64-bit IBM PowerPC 970 processor. "
"Joswiak himself says: "The important thing for us [is] we didn't want to create a separate OS that is 64 bits. What is essential is that this OS and this hardware will run 32-bit applications with no recompiling - it will just run them."
"this approach allows Apple and its developers to start leveraging its new 64-bit processor as soon as possible, without having to recompile operating system and applications. "
"It's a smart move that allows the platform to take advantage of the key aspects of 64-bit computing without forcing a migration from the 32-bit world. "
For dem som vil lese mer:
http://www.theregister.co.uk/content/39/31995.html
Vel, det er jo litt kjekt å ha 8 GB ram da... :D
"64-bit processors enable the Power Mac G5 to break through the 4GB barrier and support up to 8GB of 400MHz, 128-bit DDR SDRAM — four times more than a typical PC."
"More main memory and fast 6.4 GBps throughput means you can write large projects to memory 40x faster than to a hard disk."
"The Power Mac G5’s ultra-high bandwidth system architecture features a 1GHz frontside bus — one on each processor — for maximum throughput."
Mer kan leses her for den som tåler det:
http://www.apple.com/powermac/
ER nok bare og vente og se hva som komer av app og games
Plz ApeacE du har spammet over alle artiklene her.. :evil:
Ro deg ned..!
Han vil nok være med i HWs sommerkonkurranse.
*vil også være med*
Ontopic: Hvis noen har noen gode artikler som gir en ide om ytelsen til 64bits programmer og prosessorer i forhold til 32bits, så kom gjerne med dem.
