Maskinen får Bluescreen
jeg har en gammel pc som jeg kjøpte i 2005. Plutselig på søndag sist uke fikk den en oppdatering av en skjermdriver. Jeg installerte den selvsagt og etter installasjonen var ferdig fikk den rett og slett bluescreen. Skjerm driveren heter Nvidia GeForce 7800 GT. Her er en liste av bluescreen jeg har fått i denne perioden:
computer name: HJEMME
windows version: Windows XP Service Pack 3, 5.1, build: 2600
windows dir: C:\WINDOWS
CPU: AuthenticAMD AMD Athlon 64 Processor 3500+ AMD586, level: 15
1 logical processors, active mask: 1
RAM: 1073201152 total
VM: 2147352576, free: 2046914560
Crash Dump Analysis
Crash dump directory: C:\WINDOWS\Minidump
Crash dumps are enabled on your computer.
On Thu 26.05.2011 19:21:20 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\Mini052611-01.dmp
This was probably caused by the following module: nvatabus.sys (nvatabus+0x12809)
Bugcheck code: 0x100000D1 (0xEC0000, 0x2, 0x1, 0xFFFFFFFFF7461809)
Error: CUSTOM_ERROR
file path: C:\WINDOWS\system32\drivers\nvatabus.sys
product: NVIDIA nForce IDE Driver
company: NVIDIA Corporation
description: NVIDIA® nForce IDE Performance Driver
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nvatabus.sys (NVIDIA® nForce IDE Performance Driver, NVIDIA Corporation).
Google query: nvatabus.sys NVIDIA Corporation CUSTOM_ERROR
On Wed 04.05.2011 16:18:01 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\Mini050411-01.dmp
Bugcheck code: 0x100000D1 (0xDE0000, 0x2, 0x1, 0xFFFFFFFFF7461809)
Error: CUSTOM_ERROR
On Thu 21.04.2011 17:06:03 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\Mini042111-01.dmp
This was probably caused by the following module: win32k.sys (win32k+0x2EE0B)
Bugcheck code: 0x10000050 (0xFFFFFFFFE144401C, 0x0, 0xFFFFFFFFBF82EE0B, 0x1)
Error: CUSTOM_ERROR
file path: C:\WINDOWS\system32\win32k.sys
product: Operativsystemet Microsoft® Windows®
company: Microsoft Corporation
description: Win32-driver for flere brukere
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
Noen som vet hva jeg kan gjøre? Har aldri fått bluescreen på denne maskinen før.
Noen tips? Kanskje en ny driver visst det finnes?
Du oppdaterte driveren og problemene begynte - bruk rollback hvis du kan.
Eller bare installér forrige versjon av driveren igjen.
Jeg ser ikke noe selvfølge med å oppdatere til nyeste driver før jeg har tatt meg en surferunde for å sjekke respons fra andre. Ny er ikke nødvendigvis bedre for deg.
Beste tipset til dette er å ta en clean format og installere XP på nytt. Gå på nettet og få tak i ALLE driverne på nytt og installer de :)
Han vet når feilen oppstod, og hva han gjorde for at den skulle oppstå - litt overkill å formatere da.
Greit nok, du har et poeng. Men regner med at PCen heller ikke har blitt formatert på en stund og da er det ganske greit å få en clean install.
Skal jeg ta xp på nytt igjen? fordi at når jeg prøvde å få den gamle driveren tilbake så trykket jeg på et spill. Så kom det opp at du må installere ny driver og det var sånn det begynte...
Å finne nye drivere på nett, hvorfor skal jeg det? jeg har jo alle de driver "diskene" som fulgte med pcen.
Hva mener dere jeg burde gjøre?
Når jeg ser nøyere etter er det ikke skjermkortdriveren som kræsjer, men IDE driverne.
Legg til/Fjern programmer - nvidia..
Enten kan du kun fjerne alt, eller så kan du velge hvilke drivere du vil fjerne.
Velg ide - kjør ferdig veiviseren og restart.
Virker ikke dette, kan du prøve å hente nye ide-drivere fra nvidia.
Og når du refererer en feilmelding er det greit at du skriver den ned så nøyaktig som mulig slik at det blir lettere å feilsøke.
