Den store Nintendokaféen
Publikum på pressekonferanser har blitt en farse uansett, de sitter og WOOOOOOOO'er uansett hva slags idiotisk drit folk lirer av seg på scenen. Som bevist på Xbox One reveal-greia.
"You can use the kinect to change channels on your TV! Xbox Tv FOX (en fyr i backstage endrer til FOX)." WOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
"YOu can have an image INSIDE another image! Look! Xbox surf google (google kommer opp i et lite vindu)" WOOOOOOOOOOOOOOHOOOOOOOOOOOOOOOOOOO
Det ble spekulert i om det satt en haug MS-ansatte bakerst og wooo'et til alt som ble sagt, for ingen av journalistene som var der sier de wooo'et selv eller så noen so woooo'et.
Tror det er litt som i Nord-Korea når presidenten dør. Griner du ikke så tårene spruter på TV er du garantert plass på neste buss til arbeidsleiren.
Endret av Bytex
Dr. Eggman’s plans for world dominance continue, seeing him look to harness the power of six tyrannical creatures known as the Deadly Six. However, Sonic must save the day and unite with his nemesis to combat the Deadly Six when they rise against their master.
At his disposal, Sonic has access to new parkour moves and improves Colour Powers, which are presumably plucked from Wii and Nintendo DS exclusive Sonic Colours. These can be controlled through manipulating the Wii U GamePad, tilting, touching, and aiming Sonic through dynamic terrain. Off-TV Play is also supported, alongside a two-player support mode.
http://www.nintendo-insider.com/2013/05/29/new-sonic-lost-world-details-race-in/
Shin’en developers Says
“The Wii U GPU is several generations ahead of the current gen. It allows many things that were not possible on consoles before.
If you develop for Wii U you have to take advantage of these possibilities, otherwise your performance is of course limited.
Also your engine layout needs to be different. You need to take advantage of the large shared memory of the Wii U, the huge and very fast EDRAM section and the big CPU caches in the cores.
Especially the workings of the CPU caches are very important to master. Otherwise you can lose a magnitude of power for cache relevant parts of your code.
In the end the Wii U specs fit perfectly together and make a very efficient console when used right.”
http://mynintendonew...of-current-gen/
Endret av PÃ¥inter
