[Løst] C++ Console spørreprogram
Når denne koden kjører så spør den ikke alle spørsmåla som den skal spørre, og eg aner ikke hva eg gjør galt :S Ver så god å kjøre den selv.
#include <string>
#include <limits>
using namespace std;
int main()
   int number;
   string name;
   string gname;
   int variable;
   char yesno[10];
   char girlorboy[10];
   cout << "This is a test program \nIt tests User Input and Output\n\n";
   cout << "Please enter your age: ";
   cin >> number;
   cin.ignore(numeric_limits<streamsize>::max(), '\n');
   cout << "Please enter your name: ";
   getline(cin, name);
   cout << endl;
   cout << "Please enter your sex, either female or male: ";
   cin >> girlorboy;
   if (!strcmp (girlorboy, "male")){
       cout << "Your full name is " << name << ", and your age is " << number << endl;
       cout << "\n" << name;
       cout << " are allowed to date girls with the age: ";
       cout << number / 2 + 7 << " and upwards!\n\n";
       cout << "Now, " << name << ", please enter the name of a girl within the age limit: ";
       getline(cin, gname);
       cout << "\nSince i am an all-knowing computer, i foresee that you, " << name << ", fits perfectly";
       cout << " with " << gname << "!\n";
       cout << "is this true? Yes or no. You don`t have to answer.. ";
       cin >> yesno;
       if (!strcmp(yesno, "yes")) {
               cout << "See im still all knowing! Bow to the almighty computer! " << endl;
               cout << "It knows the asnwer to everything";
       else if (!strcmp(yesno, "no")){
            cout << "Don't lie to yourself, I know I am right! ";
       cout << "good dat...we are no longer bros..";
       else if (!strcmp(girlorboy, "female")){
            cout << "girls don`t count...";
       system("pause");
       cin.get();
       return 0;
Edit: la den inn litt mer oversiktelig ;)
Endret av Gabbe
Det skader ikke å google litt selv. Problemet ditt står forklart her. Er det noen grunn til at du bruker cin i noen tilfeller og getline i andre?
Tusen takk Jaffe! En slik lenke var akkurat det eg trengte, tror eg. Eg prøvde å google, men eg googlet sikkert etter feil da eg googla etter "if" og "if else". Grunnen til at eg bruker cin i n oen tilfeller og getline i andre er enkelt og greit at eg har sett begge bli brukt i tutorials, men ikke blitt forklart forskjellen, så da bruker eg disse om en annen for å se og lere hvilke som fungerer hvor.
EDIT: Ok nå virker den og er fiksa, takk for lenken ;)
Endret av Gabbe
