stelar7 Skrevet 7. mai 2011 Rapporter Del Skrevet 7. mai 2011 (endret) hallais! skal lage en plugin til bukkit, men den funker ikke! :S her er erroren: while scanning a simple key in "<reader>", line 3, column 1: version:1 ^ could not found expected ':' in "<reader>", line 4, column 1: author:stelar7 ^ at org.yaml.snakeyaml.scanner.ScannerImpl.stalePossibleSimpleKeys(Scanne rImpl.java:400) at org.yaml.snakeyaml.scanner.ScannerImpl.needMoreTokens(ScannerImpl.jav a:231) at org.yaml.snakeyaml.scanner.ScannerImpl.checkToken(ScannerImpl.java:18 2) at org.yaml.snakeyaml.parser.ParserImpl$ParseBlockMappingKey.produce(Par serImpl.java:564) at org.yaml.snakeyaml.parser.ParserImpl.peekEvent(ParserImpl.java:163) at org.yaml.snakeyaml.parser.ParserImpl.checkEvent(ParserImpl.java:148) at org.yaml.snakeyaml.composer.Composer.composeMappingNode(Composer.java :228) at org.yaml.snakeyaml.composer.Composer.composeNode(Composer.java:160) at org.yaml.snakeyaml.composer.Composer.composeDocument(Composer.java:12 2) at org.yaml.snakeyaml.composer.Composer.getSingleNode(Composer.java:105) at org.yaml.snakeyaml.constructor.BaseConstructor.getSingleData(BaseCons tructor.java:124) at org.yaml.snakeyaml.Yaml.load(Yaml.java:264) at org.yaml.snakeyaml.Yaml.load(Yaml.java:250) at org.bukkit.plugin.PluginDescriptionFile.<init>(PluginDescriptionFile. java:30) at org.bukkit.plugin.java.JavaPluginLoader.loadPlugin(JavaPluginLoader.j ava:63) at org.bukkit.plugin.SimplePluginManager.loadPlugin(SimplePluginManager. java:160) at org.bukkit.plugin.SimplePluginManager.loadPlugins(SimplePluginManager .java:108) at org.bukkit.craftbukkit.CraftServer.loadPlugins(CraftServer.java:85) at net.minecraft.server.MinecraftServer.e(MinecraftServer.java:217) at net.minecraft.server.MinecraftServer.a(MinecraftServer.java:204) at net.minecraft.server.MinecraftServer.init(MinecraftServer.java:144) at net.minecraft.server.MinecraftServer.run(MinecraftServer.java:259) at net.minecraft.server.ThreadServerApplication.run(SourceFile:394) > hjelp er høyt ønsket Endret 7. mai 2011 av stelar7 Lenke til kommentar
ventrec Skrevet 8. mai 2011 Rapporter Del Skrevet 8. mai 2011 Hvordan skal vi kunne hjelpe deg uten å se på koden? Jeg kan si som så: Grunnen til at du får feil er pga. du har gjort noe galt. Vis oss mer, så får du et mer konkret svar Du ville sikkert fått mer hjelp om du opprettet en tråd på bukkit sitt offisielle forum! Lenke til kommentar
stelar7 Skrevet 9. mai 2011 Forfatter Rapporter Del Skrevet 9. mai 2011 (endret) fikset det selv hadde feil main i plugin.yml filen Endret 9. mai 2011 av stelar7 Lenke til kommentar
sikringsskap Skrevet 25. mai 2011 Rapporter Del Skrevet 25. mai 2011 (endret) ........ Endret 25. mai 2011 av sikringsskap Lenke til kommentar
