trenger hjelp til å fikse brenner som ikke fullfører brenning av lyd cd
dvd brenneren som jeg har er kanskje 2 år gammel og er en lightscribe dvd multi recorder om det har noe å si for ekspertene
Jeg prøvde å brenne en vanlig lyd cd med hjelp av nero multimedia suit 10 og tok med simulering når jeg skulle brenne og jeg fikk da denne meldinga
9X03-014M-337H-H1CZ-L2KK-229X-****-****
Windows 7 6.1
AMD64
Wow64Process
Nero Version: 10.2.7.100
Internal Version: 10,2,7,100
Recorder: <TSSTcorp CDDVDW SH-S202N>Version: SB02 - HA 1 TA 1 - 10.2.7.100
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : via Inquiry data
CD-ROM: <HL-DT-ST DVD-ROM GDR8163B>Version: 0L15 - HA 1 TA 0 - 10.2.7.100
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD20EARS-00MVWB051.0 mv64xx Port 6 ID 0 DMA: Off
ArrayPeripheral : MARVELL Virtual Device 1.00 mv64xx Port 6 ID 127DMA: Off
CdRomPeripheral : YLMBO O563WLI38T 1.03 ab3w8fov Port 7 ID 0 DMA: Off
CdRomPeripheral : YLMBO O563WLI38T 1.03 ab3w8fov Port 7 ID 1 DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST DVD-ROM GDR8163B E: CdRom0
TSSTcorp CDDVDW SH-S202N F: CdRom1
YLMBO O563WLI38T G: CdRom2
YLMBO O563WLI38T J: CdRom3
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 4095MB (4194303kB)
Free physical memory: 2696MB (2761424kB)
Memory in use : 56 %
Uncached PFiles: 0x0
Global Bus Type: default (0)
Check supported media : Disabled (0)
6.5.2011
Lyd-CD
15:10:20 #1 Text 0 File SCSIPTICommands.cpp, Line 464
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
15:10:20 #2 CDADOC -1 File Cdadoc.cpp, Line 1737
Audio item log info:
Audio document burn settings:
Burn mode: DAO,
CD Text: On,
Cache disk or network files: No,
Cache small files: No,
Cache files smaller than 65536 bytes.
Audio Multisession: No
List of audio tracks:
Track 01: Length: 02:26.01, Pause frames: 150, Filters: 0, Name: 'Aretha Franklin - Son of a Preacher Man.mp3'.
Track 02: Length: 02:16.01, Pause frames: 150, Filters: 0, Name: 'Bobby Fuller Four - I Fought The Law.mp3'.
Track 03: Length: 02:52.14, Pause frames: 150, Filters: 0, Name: 'Booker T & The Mgs - Green Onions.mp3'.
Track 04: Length: 01:49.28, Pause frames: 150, Filters: 0, Name: 'Box Tops - The Letter.mp3'.
Track 05: Length: 02:40.29, Pause frames: 150, Filters: 0, Name: 'Buffalo Springfield - For What It's Worth.mp3'.
Track 06: Length: 05:02.56, Pause frames: 150, Filters: 0, Name: 'Canned Heat - On The Road Again.mp3'.
Track 07: Length: 03:07.59, Pause frames: 150, Filters: 0, Name: 'Count Five - Psychotic Reaction.mp3'.
Track 08: Length: 02:20.03, Pause frames: 150, Filters: 0, Name: 'Credence ClearWater Revival - Bad Moon on the Rising.mp3'.
Track 09: Length: 02:18.70, Pause frames: 150, Filters: 0, Name: 'Credence Clearwater Revival - Fortunate Son.mp3'.
Track 10: Length: 04:26.14, Pause frames: 150, Filters: 0, Name: 'Deep Purple - Hush.mp3'.
Track 11: Length: 03:20.38, Pause frames: 150, Filters: 0, Name: 'Edwin Starr - War.mp3'.
Track 12: Length: 02:42.57, Pause frames: 150, Filters: 0, Name: 'Guess Who - Shakin' All Over.mp3'.
Track 13: Length: 03:01.00, Pause frames: 150, Filters: 0, Name: 'Jefferson Airplane - Somebody To Love.mp3'.
Track 14: Length: 02:32.27, Pause frames: 150, Filters: 0, Name: 'Jefferson Airplane - White Rabbit.mp3'.
Track 15: Length: 04:00.51, Pause frames: 150, Filters: 0, Name: 'Jimi Hendrix - All Along The Watchtower.mp3'.
Track 16: Length: 02:25.12, Pause frames: 150, Filters: 0, Name: 'Kinks - All Day And All Of The Night.mp3'.
Track 17: Length: 04:55.05, Pause frames: 150, Filters: 0, Name: 'Led Zeppelin - Black Dog.mp3'.
Track 18: Length: 02:55.13, Pause frames: 150, Filters: 0, Name: 'Martha Reeves & The Vandellas - No Where To Run.mp3'.
Track 19: Length: 02:46.67, Pause frames: 150, Filters: 0, Name: 'Nancy Sinatra - These Boots Are Made For Walking.mp3'.
Track 20: Length: 02:47.37, Pause frames: 150, Filters: 0, Name: 'Prozac - Alone in my Prison.mp3'.
Track 21: Length: 02:35.00, Pause frames: 150, Filters: 0, Name: 'Ramones - Surfing Bird.mp3'.
Track 22: Length: 03:45.54, Pause frames: 150, Filters: 0, Name: 'Rolling Stones - Paint It Black.mp3'.
Track 23: Length: 03:49.57, Pause frames: 150, Filters: 0, Name: 'Simon and Garfunkel - Mrs. Robinson.mp3'.
Track 24: Length: 03:30.15, Pause frames: 150, Filters: 0, Name: 'Steppenwolf - Born To Be Wild.mp3'.
Total size: 75:15.33
15:10:20 #3 Text 0 File Burncd.cpp, Line 3189
Super Link aktivert
15:10:20 #4 Text 0 File AudioCompilationImpl.cpp, Line 838
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
15:10:20 #5 Text 0 File Burncd.cpp, Line 3519
Turn on Disc-At-Once, using CD-R/RW media
15:10:20 #6 Text 0 File DlgWaitCD.cpp, Line 314
[F: CDDVDW SH-S202N ] Last possible write address on media: 359842
Last address to be written: 338507
15:10:20 #7 Text 0 File DlgWaitCD.cpp, Line 326
[F: CDDVDW SH-S202N ] Write in overburning mode: NO (enabled: CD)
15:10:20 #8 Text 0 File DlgWaitCD.cpp, Line 2917
Recorder: TSSTcorp CDDVDW SH-S202N;
CDR code: 00 97 15 17; OSJ entry from: Ritek Co.
ATIP Data:
Special Info [hex] 1: C0 00 90, 2: 61 0F 11 (LI 97:15.17), 3: 4F 3B 46 (LO 79:59.70)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid)
15:10:20 #9 Text 0 File DlgWaitCD.cpp, Line 499
[F: CDDVDW SH-S202N ] >>> Protocol of DlgWaitCD activities: <<<
15:10:20 #10 Text 0 File ThreadedTransferInterface.cpp, Line 861
Setup items (after recorder preparation)
0: TRM_AUDIO_NOPRE (Aretha Franklin - Son of a Preacher Man.mp3)
2 indices, index0 (150) not provided
original disc pos #0 + 10951 (10951) = #10951/2:26.1
relocatable, disc pos for caching/writing not required/not required
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 10951 blocks [F: TSSTcorp CDDVDW SH-S202N]
1: TRM_AUDIO_NOPRE (Bobby Fuller Four - I Fought The Law.mp3)
original disc pos #0 + 10201 (10201) = #10201/2:16.1
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 10201 blocks [F: TSSTcorp CDDVDW SH-S202N]
2: TRM_AUDIO_NOPRE (Booker T & The Mgs - Green Onions.mp3)
original disc pos #0 + 12914 (12914) = #12914/2:52.14
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12914 blocks [F: TSSTcorp CDDVDW SH-S202N]
3: TRM_AUDIO_NOPRE (Box Tops - The Letter.mp3)
original disc pos #0 + 8203 (8203) = #8203/1:49.28
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 8203 blocks [F: TSSTcorp CDDVDW SH-S202N]
4: TRM_AUDIO_NOPRE (Buffalo Springfield - For What It's Worth.mp3)
original disc pos #0 + 12029 (12029) = #12029/2:40.29
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12029 blocks [F: TSSTcorp CDDVDW SH-S202N]
5: TRM_AUDIO_NOPRE (Canned Heat - On The Road Again.mp3)
original disc pos #0 + 22706 (22706) = #22706/5:2.56
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 22706 blocks [F: TSSTcorp CDDVDW SH-S202N]
6: TRM_AUDIO_NOPRE (Count Five - Psychotic Reaction.mp3)
original disc pos #0 + 14084 (14084) = #14084/3:7.59
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14084 blocks [F: TSSTcorp CDDVDW SH-S202N]
7: TRM_AUDIO_NOPRE (Credence ClearWater Revival - Bad Moon on the Rising.mp3)
original disc pos #0 + 10503 (10503) = #10503/2:20.3
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 10503 blocks [F: TSSTcorp CDDVDW SH-S202N]
8: TRM_AUDIO_NOPRE (Credence Clearwater Revival - Fortunate Son.mp3)
original disc pos #0 + 10420 (10420) = #10420/2:18.70
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 10420 blocks [F: TSSTcorp CDDVDW SH-S202N]
9: TRM_AUDIO_NOPRE (Deep Purple - Hush.mp3)
original disc pos #0 + 19964 (19964) = #19964/4:26.14
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19964 blocks [F: TSSTcorp CDDVDW SH-S202N]
10: TRM_AUDIO_NOPRE (Edwin Starr - War.mp3)
original disc pos #0 + 15038 (15038) = #15038/3:20.38
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15038 blocks [F: TSSTcorp CDDVDW SH-S202N]
11: TRM_AUDIO_NOPRE (Guess Who - Shakin' All Over.mp3)
original disc pos #0 + 12207 (12207) = #12207/2:42.57
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12207 blocks [F: TSSTcorp CDDVDW SH-S202N]
12: TRM_AUDIO_NOPRE (Jefferson Airplane - Somebody To Love.mp3)
original disc pos #0 + 13575 (13575) = #13575/3:1.0
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13575 blocks [F: TSSTcorp CDDVDW SH-S202N]
13: TRM_AUDIO_NOPRE (Jefferson Airplane - White Rabbit.mp3)
original disc pos #0 + 11427 (11427) = #11427/2:32.27
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 11427 blocks [F: TSSTcorp CDDVDW SH-S202N]
14: TRM_AUDIO_NOPRE (Jimi Hendrix - All Along The Watchtower.mp3)
original disc pos #0 + 18051 (18051) = #18051/4:0.51
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18051 blocks [F: TSSTcorp CDDVDW SH-S202N]
15: TRM_AUDIO_NOPRE (Kinks - All Day And All Of The Night.mp3)
original disc pos #0 + 10887 (10887) = #10887/2:25.12
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 10887 blocks [F: TSSTcorp CDDVDW SH-S202N]
16: TRM_AUDIO_NOPRE (Led Zeppelin - Black Dog.mp3)
original disc pos #0 + 22130 (22130) = #22130/4:55.5
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 22130 blocks [F: TSSTcorp CDDVDW SH-S202N]
17: TRM_AUDIO_NOPRE (Martha Reeves & The Vandellas - No Where To Run.mp3)
original disc pos #0 + 13138 (13138) = #13138/2:55.13
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13138 blocks [F: TSSTcorp CDDVDW SH-S202N]
18: TRM_AUDIO_NOPRE (Nancy Sinatra - These Boots Are Made For Walking.mp3)
original disc pos #0 + 12517 (12517) = #12517/2:46.67
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12517 blocks [F: TSSTcorp CDDVDW SH-S202N]
19: TRM_AUDIO_NOPRE (Prozac - Alone in my Prison.mp3)
original disc pos #0 + 12562 (12562) = #12562/2:47.37
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12562 blocks [F: TSSTcorp CDDVDW SH-S202N]
20: TRM_AUDIO_NOPRE (Ramones - Surfing Bird.mp3)
original disc pos #0 + 11625 (11625) = #11625/2:35.0
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 11625 blocks [F: TSSTcorp CDDVDW SH-S202N]
21: TRM_AUDIO_NOPRE (Rolling Stones - Paint It Black.mp3)
original disc pos #0 + 16929 (16929) = #16929/3:45.54
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16929 blocks [F: TSSTcorp CDDVDW SH-S202N]
22: TRM_AUDIO_NOPRE (Simon and Garfunkel - Mrs. Robinson.mp3)
original disc pos #0 + 17232 (17232) = #17232/3:49.57
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17232 blocks [F: TSSTcorp CDDVDW SH-S202N]
23: TRM_AUDIO_NOPRE (Steppenwolf - Born To Be Wild.mp3)
original disc pos #0 + 15765 (15765) = #15765/3:30.15
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15765 blocks [F: TSSTcorp CDDVDW SH-S202N]
15:10:22 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1077
Prepare [F: TSSTcorp CDDVDW SH-S202N] for write in CUE-sheet-DAO
DAO infos:
MCN: " "
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 24: Idx 0 Idx 1 Next Trk
1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 26109552, ISRC ""
2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 26109552 26462352 50455104, ISRC ""
3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 50455104 50807904 81181632, ISRC ""
4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 81181632 81534432 100827888, ISRC ""
5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 100827888 101180688 129472896, ISRC ""
6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 129472896 129825696 183230208, ISRC ""
7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 183230208 183583008 216708576, ISRC ""
8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 216708576 217061376 241764432, ISRC ""
9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 241764432 242117232 266625072, ISRC ""
10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 266625072 266977872 313933200, ISRC ""
11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 313933200 314286000 349655376, ISRC ""
12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 349655376 350008176 378719040, ISRC ""
13: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 378719040 379071840 411000240, ISRC ""
14: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 411000240 411353040 438229344, ISRC ""
15: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 438229344 438582144 481038096, ISRC ""
16: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 481038096 481390896 506997120, ISRC ""
17: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 506997120 507349920 559399680, ISRC ""
18: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 559399680 559752480 590653056, ISRC ""
19: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 590653056 591005856 620445840, ISRC ""
20: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 620445840 620798640 650344464, ISRC ""
21: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 650344464 650697264 678039264, ISRC ""
22: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 678039264 678392064 718209072, ISRC ""
23: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 718209072 718561872 759091536, ISRC ""
24: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 759091536 759444336 796523616, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
-150 | lead-in | 0 | 0x01 | 0 | 0 | 0x00
-150 | 1 | 0 | 0x21 | 0 | 0 | 0x00
0 | 1 | 1 | 0x21 | 10951 | 0 | 0x00
10951 | 2 | 0 | 0x21 | 0 | 0 | 0x00
11101 | 2 | 1 | 0x21 | 10201 | 11101 | 0x00
21302 | 3 | 0 | 0x21 | 0 | 0 | 0x00
21452 | 3 | 1 | 0x21 | 12914 | 21452 | 0x00
34366 | 4 | 0 | 0x21 | 0 | 0 | 0x00
34516 | 4 | 1 | 0x21 | 8203 | 34516 | 0x00
42719 | 5 | 0 | 0x21 | 0 | 0 | 0x00
42869 | 5 | 1 | 0x21 | 12029 | 42869 | 0x00
54898 | 6 | 0 | 0x21 | 0 | 0 | 0x00
55048 | 6 | 1 | 0x21 | 22706 | 55048 | 0x00
77754 | 7 | 0 | 0x21 | 0 | 0 | 0x00
77904 | 7 | 1 | 0x21 | 14084 | 77904 | 0x00
91988 | 8 | 0 | 0x21 | 0 | 0 | 0x00
92138 | 8 | 1 | 0x21 | 10503 | 92138 | 0x00
102641 | 9 | 0 | 0x21 | 0 | 0 | 0x00
102791 | 9 | 1 | 0x21 | 10420 | 102791 | 0x00
113211 | 10 | 0 | 0x21 | 0 | 0 | 0x00
113361 | 10 | 1 | 0x21 | 19964 | 113361 | 0x00
133325 | 11 | 0 | 0x21 | 0 | 0 | 0x00
133475 | 11 | 1 | 0x21 | 15038 | 133475 | 0x00
148513 | 12 | 0 | 0x21 | 0 | 0 | 0x00
148663 | 12 | 1 | 0x21 | 12207 | 148663 | 0x00
160870 | 13 | 0 | 0x21 | 0 | 0 | 0x00
161020 | 13 | 1 | 0x21 | 13575 | 161020 | 0x00
174595 | 14 | 0 | 0x21 | 0 | 0 | 0x00
174745 | 14 | 1 | 0x21 | 11427 | 174745 | 0x00
186172 | 15 | 0 | 0x21 | 0 | 0 | 0x00
186322 | 15 | 1 | 0x21 | 18051 | 186322 | 0x00
204373 | 16 | 0 | 0x21 | 0 | 0 | 0x00
204523 | 16 | 1 | 0x21 | 10887 | 204523 | 0x00
215410 | 17 | 0 | 0x21 | 0 | 0 | 0x00
215560 | 17 | 1 | 0x21 | 22130 | 215560 | 0x00
237690 | 18 | 0 | 0x21 | 0 | 0 | 0x00
237840 | 18 | 1 | 0x21 | 13138 | 237840 | 0x00
250978 | 19 | 0 | 0x21 | 0 | 0 | 0x00
251128 | 19 | 1 | 0x21 | 12517 | 251128 | 0x00
263645 | 20 | 0 | 0x21 | 0 | 0 | 0x00
263795 | 20 | 1 | 0x21 | 12562 | 263795 | 0x00
276357 | 21 | 0 | 0x21 | 0 | 0 | 0x00
276507 | 21 | 1 | 0x21 | 11625 | 276507 | 0x00
288132 | 22 | 0 | 0x21 | 0 | 0 | 0x00
288282 | 22 | 1 | 0x21 | 16929 | 288282 | 0x00
305211 | 23 | 0 | 0x21 | 0 | 0 | 0x00
305361 | 23 | 1 | 0x21 | 17232 | 305361 | 0x00
322593 | 24 | 0 | 0x21 | 0 | 0 | 0x00
322743 | 24 | 1 | 0x21 | 15765 | 322743 | 0x00
338508 | lead-out | 1 | 0x01 | 0 | 0 | 0x00
MediaType: CD-R
15:10:22 #12 Text 0 File SCSIPTICommands.cpp, Line 251
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
15:10:22 #13 Text 0 File Burncd.cpp, Line 4232
Caching options: cache CDRom or Network-No, small files-No (<64KB)
15:10:22 #14 PHASE 28 File dlgbrnst.cpp, Line 1827
Maximum transfer rate test started
15:10:22 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2850
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
15:10:22 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2850
Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #11101
15:10:22 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2850
Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #21452
15:10:22 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2850
Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #34516
15:10:22 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2850
Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #42869
15:10:22 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2850
Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #55048
15:10:22 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2850
Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #77904
15:10:22 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2850
Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #92138
15:10:22 #23 Text 0 File ThreadedTransferInterface.cpp, Line 2850
Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #102791
15:10:22 #24 Text 0 File ThreadedTransferInterface.cpp, Line 2850
Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #0): write at #113361
15:10:22 #25 Text 0 File ThreadedTransferInterface.cpp, Line 2850
Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #0): write at #133475
15:10:22 #26 Text 0 File ThreadedTransferInterface.cpp, Line 2850
Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #0): write at #148663
15:10:22 #27 Text 0 File ThreadedTransferInterface.cpp, Line 2850
Verifying disc position of item 12 (relocatable, no disc pos, no patch infos, orig at #0): write at #161020
15:10:22 #28 Text 0 File ThreadedTransferInterface.cpp, Line 2850
Verifying disc position of item 13 (relocatable, no disc pos, no patch infos, orig at #0): write at #174745
15:10:22 #29 Text 0 File ThreadedTransferInterface.cpp, Line 2850
Verifying disc position of item 14 (relocatable, no disc pos, no patch infos, orig at #0): write at #186322
15:10:22 #30 Text 0 File ThreadedTransferInterface.cpp, Line 2850
Verifying disc position of item 15 (relocatable, no disc pos, no patch infos, orig at #0): write at #204523
15:10:22 #31 Text 0 File ThreadedTransferInterface.cpp, Line 2850
Verifying disc position of item 16 (relocatable, no disc pos, no patch infos, orig at #0): write at #215560
15:10:22 #32 Text 0 File ThreadedTransferInterface.cpp, Line 2850
Verifying disc position of item 17 (relocatable, no disc pos, no patch infos, orig at #0): write at #237840
15:10:22 #33 Text 0 File ThreadedTransferInterface.cpp, Line 2850
Verifying disc position of item 18 (relocatable, no disc pos, no patch infos, orig at #0): write at #251128
15:10:22 #34 Text 0 File ThreadedTransferInterface.cpp, Line 2850
Verifying disc position of item 19 (relocatable, no disc pos, no patch infos, orig at #0): write at #263795
15:10:22 #35 Text 0 File ThreadedTransferInterface.cpp, Line 2850
Verifying disc position of item 20 (relocatable, no disc pos, no patch infos, orig at #0): write at #276507
15:10:22 #36 Text 0 File ThreadedTransferInterface.cpp, Line 2850
Verifying disc position of item 21 (relocatable, no disc pos, no patch infos, orig at #0): write at #288282
15:10:22 #37 Text 0 File ThreadedTransferInterface.cpp, Line 2850
Verifying disc position of item 22 (relocatable, no disc pos, no patch infos, orig at #0): write at #305361
15:10:22 #38 Text 0 File ThreadedTransferInterface.cpp, Line 2850
Verifying disc position of item 23 (relocatable, no disc pos, no patch infos, orig at #0): write at #322743
15:10:22 #39 Text 0 File ThreadedTransfer.cpp, Line 273
Pipe memory size 590400
15:10:47 #40 Text 0 File WriterStatus.cpp, Line 244
<F: TSSTcorp CDDVDW SH-S202N> start writing Lead-Out at LBA 338508 (52A4Ch), length 0 blocks
15:10:47 #41 PHASE 29 File dlgbrnst.cpp, Line 1776
Maximum transfer rate test completed: 186.4x (27 968 KB/s)
15:10:47 #42 PHASE 32 File dlgbrnst.cpp, Line 1827
Simulation started at 48x (7 200 KB/s)
15:10:47 #43 Text 0 File ThreadedTransferInterface.cpp, Line 2850
15:10:47 #44 Text 0 File ThreadedTransferInterface.cpp, Line 2850
15:10:47 #45 Text 0 File ThreadedTransferInterface.cpp, Line 2850
15:10:47 #46 Text 0 File ThreadedTransferInterface.cpp, Line 2850
15:10:47 #47 Text 0 File ThreadedTransferInterface.cpp, Line 2850
15:10:47 #48 Text 0 File ThreadedTransferInterface.cpp, Line 2850
15:10:47 #49 Text 0 File ThreadedTransferInterface.cpp, Line 2850
15:10:47 #50 Text 0 File ThreadedTransferInterface.cpp, Line 2850
15:10:47 #51 Text 0 File ThreadedTransferInterface.cpp, Line 2850
15:10:47 #52 Text 0 File ThreadedTransferInterface.cpp, Line 2850
15:10:47 #53 Text 0 File ThreadedTransferInterface.cpp, Line 2850
15:10:47 #54 Text 0 File ThreadedTransferInterface.cpp, Line 2850
15:10:47 #55 Text 0 File ThreadedTransferInterface.cpp, Line 2850
15:10:47 #56 Text 0 File ThreadedTransferInterface.cpp, Line 2850
15:10:47 #57 Text 0 File ThreadedTransferInterface.cpp, Line 2850
15:10:47 #58 Text 0 File ThreadedTransferInterface.cpp, Line 2850
15:10:47 #59 Text 0 File ThreadedTransferInterface.cpp, Line 2850
15:10:47 #60 Text 0 File ThreadedTransferInterface.cpp, Line 2850
15:10:47 #61 Text 0 File ThreadedTransferInterface.cpp, Line 2850
15:10:47 #62 Text 0 File ThreadedTransferInterface.cpp, Line 2850
15:10:47 #63 Text 0 File ThreadedTransferInterface.cpp, Line 2850
15:10:47 #64 Text 0 File ThreadedTransferInterface.cpp, Line 2850
15:10:47 #65 Text 0 File ThreadedTransferInterface.cpp, Line 2850
15:10:47 #66 Text 0 File ThreadedTransferInterface.cpp, Line 2850
15:10:47 #67 Text 0 File MMC.cpp, Line 17600
StartDAO : CD-Text - On
15:10:47 #68 Text 0 File MMC.cpp, Line 21603
Set BUFE: Super Link -> ON
15:10:47 #69 Text 0 File MMC.cpp, Line 17830
CueData, Len=400
21 00 00 41 00 00 00 00
21 01 00 00 00 00 00 00
21 01 01 00 00 00 02 00
21 02 00 00 00 02 1c 01
21 02 01 00 00 02 1e 01
21 03 00 00 00 04 2e 02
21 03 01 00 00 04 30 02
21 04 00 00 00 07 28 10
21 04 01 00 00 07 2a 10
21 05 00 00 00 09 1f 2c
21 05 01 00 00 09 21 2c
21 06 00 00 00 0c 0d 49
21 06 01 00 00 0c 0f 49
21 07 00 00 00 11 12 36
21 07 01 00 00 11 14 36
21 08 00 00 00 14 1c 26
21 08 01 00 00 14 1e 26
21 09 00 00 00 16 32 29
21 09 01 00 00 16 34 29
21 0a 00 00 00 19 0b 24
21 0a 01 00 00 19 0d 24
21 0b 00 00 00 1d 27 32
21 0b 01 00 00 1d 29 32
21 0c 00 00 00 21 02 0d
21 0c 01 00 00 21 04 0d
21 0d 00 00 00 23 2e 46
21 0d 01 00 00 23 30 46
21 0e 00 00 00 26 31 46
21 0e 01 00 00 26 33 46
21 0f 00 00 00 29 18 16
21 0f 01 00 00 29 1a 16
21 10 00 00 00 2d 1a 49
21 10 01 00 00 2d 1c 49
21 11 00 00 00 2f 36 0a
21 11 01 00 00 2f 38 0a
21 12 00 00 00 34 33 0f
21 12 01 00 00 34 35 0f
21 13 00 00 00 37 30 1c
21 13 01 00 00 37 32 1c
21 14 00 00 00 3a 25 14
21 14 01 00 00 3a 27 14
21 15 00 00 00 3d 1a 39
21 15 01 00 00 3d 1c 39
21 16 00 00 00 40 03 39
21 16 01 00 00 40 05 39
21 17 00 00 00 43 33 24
21 17 01 00 00 43 35 24
21 18 00 00 00 47 2b 12
21 18 01 00 00 47 2d 12
01 aa 01 01 00 4b 0f 21
15:10:47 #70 Text 0 File ThreadedTransfer.cpp, Line 273
Pipe memory size 83836800
15:11:44 #71 SPTI -1502 File SCSIPassThrough.cpp, Line 217
CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1502)
CDB Data: 0x2A 00 00 01 2A AB 00 00 1B 00 00 00
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x08
Sense Qual: 0x03
Sense Area: 0x70 00 04 00 00 00 00 0A 00 00 00 00 08 03
Buffer x0cdd3640: Len xf810
0x77 00 FD FF 7E 00 FD FF 77 00 FE FF 77 00 FD FF
0x81 00 FD FF 85 00 FE FF 80 00 FD FF 78 00 FD FF
0x70 00 FD FF 75 00 FD FF 9C 00 FE FF E2 00 FD FF
15:11:44 #72 TRANSFER -20 File ThreadedTransfer.cpp, Line 1222
Could not perform Write
15:11:44 #73 CDR -1502 File Writer.cpp, Line 335
DMA-driver error. CRC error
15:11:50 #74 SPTI -1169 File SCSIPassThrough.cpp, Line 217
CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1169)
CDB Data: 0x51 00 00 00 00 00 00 00 20 00 00 00
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x04
Sense Qual: 0x08
Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 04 08
Buffer x02ece980: Len x20
15:12:06 #75 Text 0 File DVDPlusDualLayer.cpp, Line 1460
SetDriveCaps: Set LAST LBA of layer 1 to 0
15:12:06 #76 PHASE 34 File dlgbrnst.cpp, Line 1827
Simulation failed at 48x (7 200 KB/s)
15:12:06 #77 Text 0 File AudioCompilationImpl.cpp, Line 863
DRM: DRM burn session terminated.
15:12:06 #78 Text 0 File AudioCompilationImpl.cpp, Line 892
DRM: Closing entire DRM handling. Bye.
15:12:06 #79 Text 0 File SCSIPTICommands.cpp, Line 301
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
15:12:06 #80 Text 0 File Cdrdrv.cpp, Line 11851
DriveLocker: UnLockVolume completed
15:12:06 #81 Text 0 File SCSIPTICommands.cpp, Line 464
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Endret av sleden
