You can remove the recycler virus both manually and by using any recycler virus removal tool. To remove the virus manually, you need to:
1. Search for the process called CTFMON.EXE and kill it through Task Manager.
2. Search CTFMON.EXE file in the Startup menu and delete it.
3. Boot the system in safe mode and open the command prompt.
4. Disable hidden, system, and read only attributes for autorun.inf and recycled folder delete them.
5. Clean the recycle bin.
6. Repeat these steps for all the drives on your computer.
7. Open registry editor and modify the NoDriveTypeAutoRun entry with 03ffffff value after searching it in following registry folders: HKEY_LOCAL_MACHINESOFTWARE HKEY_CURRENT_USERSOFTWARE
8. Reboot and scan your system with latest antivirus software.
Article Source: http://EzineArticles.com/2314758
Du kan jo kanskje prøve det som står i linken du viste?
