Sliter med å få satt opp apache2 skikkelig
Gjest Slettet+432
Kan du gi output fra følgende kommando: sudo tail -f /var/log/apache2/error.log
Endret av Slettet+432
[Tue Apr 26 20:36:42 2011] [notice] suEXEC mechanism enabled (wrapper: /usr/lib/apache2/suexec)
[Tue Apr 26 20:36:42 2011] [notice] Apache/2.2.17 (Debian) mod_fcgid/2.3.6 configured -- resuming normal operations
[Tue Apr 26 20:43:59 2011] [notice] SIGUSR1 received. Doing graceful restart
[Tue Apr 26 20:43:59 2011] [notice] Apache/2.2.17 (Debian) mod_fcgid/2.3.6 configured -- resuming normal operations
[Tue Apr 26 20:44:07 2011] [notice] caught SIGTERM, shutting down
[Tue Apr 26 20:44:08 2011] [notice] suEXEC mechanism enabled (wrapper: /usr/lib/apache2/suexec)
[Tue Apr 26 20:44:08 2011] [notice] Apache/2.2.17 (Debian) mod_fcgid/2.3.6 configured -- resuming normal operations
Endret av Lindsay
Har kommet så langt att jeg får
13)Permission denied: /var/www/vhosts/webmappe/.htaccess pcfg_openfile: unable to check htaccess file, ensure it is readable
.htaccess joomla
## Can be commented out if causes errors, see notes above.
Options +FollowSymLinks
AddHandler php5-fastcgi .html
Action php5-fastcgi /cgi-bin/php5.fcgi
# mod_rewrite in use
RewriteEngine On
########## Begin - Rewrite rules to block out some common exploits
## If you experience problems on your site block out the operations listed below
## This attempts to block the most common type of exploit `attempts` to Joomla!
## Deny access to extension xml files (uncomment out to activate)
<Files ~ "\.xml$">
Order allow,deny
Deny from all
Satisfy all
</Files>
## End of deny access to extension xml files
RewriteCond %{QUERY_STRING} mosConfig_[a-zA-Z_]{1,21}(=|\%3D) [OR]
# Block out any script trying to base64_encode crap to send via URL
RewriteCond %{QUERY_STRING} base64_encode.*\(.*\) [OR]
# Block out any script that includes a <script> tag in URL
RewriteCond %{QUERY_STRING} (\<|%3C).*script.*(\>|%3E) [NC,OR]
# Block out any script trying to set a PHP GLOBALS variable via URL
RewriteCond %{QUERY_STRING} GLOBALS(=|\[|\%[0-9A-Z]{0,2}) [OR]
# Block out any script trying to modify a _REQUEST variable via URL
RewriteCond %{QUERY_STRING} _REQUEST(=|\[|\%[0-9A-Z]{0,2})
# Send all blocked request to homepage with 403 Forbidden error!
RewriteRule ^(.*)$ index.php [F,L]
########## End - Rewrite rules to block out some common exploits
# Uncomment following line if your webserver's URL
# is not directly related to physical file paths.
# Update Your Joomla! Directory (just / for root)
# RewriteBase /
########## Begin - Joomla! core SEF Section
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteCond %{REQUEST_URI} !^/index.php
RewriteCond %{REQUEST_URI} (/|\.php|\.html|\.htm|\.feed|\.pdf|\.raw|/[^.]*)$ [NC]
RewriteRule (.*) index.php
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization},L]
########## End - Joomla! core SEF Section
.htaccess phpBB3
# Uncomment the statement below if you want to make use of
# HTTP authentication and it does not already work.
# This could be required if you are for example using PHP via Apache CGI.
#<IfModule mod_rewrite.c>
#RewriteEngine on
#RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization},L]
#</IfModule>
<Files "config.php">
Order Allow,Deny
Deny from All
</Files>
<Files "common.php">
Order Allow,Deny
Deny from All
</Files>
Gjest Slettet+432
Vel... .htaccess må være lesbar for www-data gruppen (hvis du har satt det opp slik). sudo chgrp www-data .htaccess skulle fikse problemet.
Har nok noe også med att jeg kjører suexec
Kjørte også chown -Rf newbie-support:www-data /var/www/vhosts/newbie-support/*
Fant noe her
#!/bin/sh
PHPRC="/usr/local/wrappers/etc/php5"
export PHPRC
PHP_FCGI_CHILDREN=5
export PHP_FCGI_CHILDREN
PHP_FCGI_MAX_REQUESTS=5000
export PHP_FCGI_MAX_REQUESTS
exec /usr/local/php5/bin/php-cgi
Men min ser slik ut
#!/bin/sh
exec /usr/bin/php5-cgi
Og ettersom dette er debian så er jo stien her riktig
Men får jo dette når jeg kjører php -v
XCache' already loaded in Unknown on line 0
Sånn jeg ser det så kjøres ikke apache som fast-cgi?
En ps -A viser att kun apache2 kjører
Endret av Lindsay
disablet suexec men nå er det enste som gjenstår denne feilen
.htaccess: Options not allowed here
Sites-enabled
<VirtualHost *:80>
ServerAdmin [email protected]
ServerName www.newbie-support.com
ServerAlias newbie-support.com
DocumentRoot /var/www/vhosts/newbie-support/
 # Set Document Root directory options
 <Directory />
   Options FollowSymLinks -Indexes Includes
   #Allow use of .htaccess file
   AllowOverride Limit FileInfo
 </Directory>
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/newbie-support/
 # Set CGI-BIN directory options
 <Directory /cgi-bin>
   AllowOverride None
   Options +ExecCGI -Multiviews +SymLinksIfOwnerMatch
   Order allow,deny
   Allow from all
 </Directory>
ErrorLog /var/log/apache2/newbie-support.com_error.log
   CustomLog /var/log/apache2/newbie-support.com_access.log combined
</VirtualHost>
Begge htaccessfiler er defaulte for jomla og phpBB3
Fulgte denne
Endret av Lindsay
Gjest Slettet+432
Sett AllowOverride All på mappene det skulle gjelde. Hvis du vil innskrenke mulighetene, kan du lese her og velge ut de innstillingene du trenger å manipulere i .htaccess.
Ellers skjønner jeg ikke hvorfor du har:
 <Directory />
 </Directory>
Jeg ville ikke under noen omstendigheter tillatt webbrukere eller applikasjoner tilgang til roten. Foreslår at du, med mindre du virkelig vet hva du gjør, bytter ut ovenstående seksjon med følgende (eller helst legg den i apache2.conf, så slipper du å legge den i hver virtualhost:
<Directory />
Order Deny,Allow
Deny from all
</Directory>
og så legger du til følgende i virtualhosten(e):
<Directory /mappe/til/dokumentrot>
AllowOverride All (eller bare de du trenger)
</Directory>
Da har du plutselig en sikrere server. Men det virker jo ærlig talt som om du ikke gidder å lese dokumentasjonen, siden du ikke får noe av dette til. Hvis du setter error-loggen i debug mode, og overvåker loggen mens du laster siden som gir feil, så hadde du funnet ut av dette. Apache er fantastisk godt dokumentert, så det er bare å sette i gang og lese: http://httpd.apache.org/docs/2.2/
Det er veldig dumt å bare følge guider ukritisk, fordi du mest sannsynlig ender opp med en usikker server. Standardkonfigurasjonen i Debian er ganske så sikker, så jeg skjønner ikke hvorfor du driver og endrer på den.
Ellers lønner det seg kanskje å følge en guide som faktisk er up-to-date... Du vil vel ikke ha php4. Finn en annen guide, hvis du absolutt skal følge noe slavisk.
Nei har nok ikke med att jeg ikke gidder å lese, men å forstå.
Det eneste jeg nå sliter med er
mod_deflate.c(615): [client 192.168.0.90] Zlib: Compressed 548 to 331 : URL /index.php
Og
[client 192.168.0.90] Request exceeded the limit of 10 internal redirects due to probable configuration error. Use 'LimitInternalRecursion' to increase the limit if necessary. Use 'LogLevel debug' to get a backtrace.
Har satt LogLevel til Debug i Apache2
Og har aktivert på zlib i php.ini men samme feil om og om igjen
Gjest Slettet+432
Den første du viser der, tror jeg ikke er noen feilmelding. Når du setter LogLevel til Debug, så får du opp mer enn du egentlig trenger å vite til vanlig. Derfor ville jeg satt den tilbake til Warn nå som du har fått rettet opp problemet og ting funker. Hva den siste meldingen kommer av, vet jeg ikke, men forårsaker det noe problem? Hvis ikke kan du sikkert bare la det være.
Jo den ene forårsaker en del ettersom jeg får fortsatt 500 error,det er den feilen her som gjør att jeg får 500 error og har søkt på google etter svar
Gjest Slettet+432
Ok. Jeg vet dessverre ikke hva det er. Ser ut som det er et eller annet skript som overskrider antall tillatte videresendinger eller noe... Prøv å legge til følgende i virtualhost-konfigurasjonen: LimitInternalRecursion 20
Hvis ikke det funker, prøv å øke tallet til det funker. I følge dokumentasjonen, er direktivet til for å forhindre at miskonfigurasjon kræsjer serveren med uendelige videresendingslooper. Hvilket skript er det du prøver å kjøre? Er det mulig at det er feil i skriptet? Sier error_log noe mer i sammenheng med feilmeldingen?
Da fikk jeg vekk dette men får istedet
 [client 192.168.0.90] redirected from r->uri = /index.php
[Thu Apr 28 22:40:26 2011] [debug] core.c(3071): [client 192.168.0.90] redirected from r->uri = /php5/php5-fcgi/forum/index.php
[Thu Apr 28 22:40:26 2011] [debug] core.c(3071): [client 192.168.0.90] redirected from r->uri = /forum/index.php
[Thu Apr 28 22:40:26 2011] [debug] mod_deflate.c(615): [client 192.168.0.90] Zlib: Compressed 548 to 331 : URL /index.php
Spørsmålet er om webfiler og foldere skal inn i mappen /cgi-bin ?
Apache er noe jeg aldri har skjønt meg på utenom standard oppsett :whistle:
Klarer du å hjelpe meg er jeg deg veldig takknemmelig
Endret av Lindsay
Gjest Slettet+432
Webfiler og mapper skal bare inn i dokumentroten... Altså f.eks. /var/www/ eller hvordan du har oppsettet. Vet du hva CGI er? Tviler på at du trenger det... Virker som du bare kjører et PHP-forum uansett, så du trenger ikke legge noe inn i cgi-bin.
