Streame nettradio via XBMC eller Boxee
I boxee kan du i noen tilfeller gjøre dette ved å gå til settings/media sources > add source manually.
eventuelt denne metoden:
Try this:
1) Open the Boxee browser app and type in the URL of the web stream (i.e. http://live.di.fm/public3/trance.pls).
2) Hit go and it will ask you if you want to keep browsing or open it as a video. Click No, to open it as a video. It will then ask if you want to save this selection.
3) It should open the stream. When it does, click on the now playing button in the upper right hand corner and enjoy the show and it should switch to your screensaver with the music playing in the background.
The good thing about this is it saves the link in your history so you can just go back and click on it when you want to hear it again.
Kilde: forums.boxee.tv/showthread.php?t=13191
XMBC har en egen wikki-side om dette: HOW-TO play internet video and audio streams
Kjempebra svar =) Takker så meget.
Men bare sånn ellers ... hvordan finner jeg da evnt. adressen til mPetre streamen?
Jeg kan gå på www.nrk.no/mpetre og starte live streamen herifra. Og i toppen av explorer vinduet står det en adresse, vil det fungere å lime inn denne i denne fila?
Jeg fikk det nemlig ikke til umiddelbart
