Opensuse "Easy install" tilpassninger
# Modified by YaST2. Last modification on lø. april 23 15:20:25 CEST 2011
# THIS FILE WILL BE PARTIALLY OVERWRITTEN by perl-Bootloader
# Configure custom boot parameters for updated kernels in /etc/sysconfig/bootloader
default 0
timeout 8
##YaST - generic_mbr
gfxmenu (hd0,1)/boot/message
##YaST - activate
###Don't change this comment - YaST2 identifier: Original name: linux###
title Desktop -- openSUSE 11.4 - 2.6.37.1-1.2
   root (hd0,1)
   kernel /boot/vmlinuz-2.6.37.1-1.2-desktop root=/dev/sda2 splash=silent quiet  showopts vga=0x317
   initrd /boot/initrd-2.6.37.1-1.2-desktop
###Don't change this comment - YaST2 identifier: Original name: failsafe###
title Failsafe -- openSUSE 11.4 - 2.6.37.1-1.2
   root (hd0,1)
   kernel /boot/vmlinuz-2.6.37.1-1.2-desktop root=/dev/sda2 showopts apm=off noresume edd=off powersaved=off nohz=off highres=off processor.max_cstate=1 nomodeset x11failsafe vga=0x317
###Don't change this comment - YaST2 identifier: Original name: xen###
title Xen -- openSUSE 11.4 - 2.6.37.1-1.2
   root (hd0,1)
   kernel /boot/xen.gz vga=mode-0x317
   module /boot/vmlinuz-2.6.37.1-1.2-xen root=/dev/sda2 splash=silent quiet showopts
   module /boot/initrd-2.6.37.1-1.2-xen
###Don't change this comment - YaST2 identifier: Original name: windows 1###
title windows XP
   map (hd0) (hd0)
   map (hd0) (hd0)
   rootnoverify (hd0,2)
   makeactive
   chainloader +1
###Don't change this comment - YaST2 identifier: Original name: windows 2###
title windows vista SP2
   map (hd1) (hd0)
   map (hd0) (hd1)
   rootnoverify (hd1,1)
   makeactive
   chainloader +1
Disk /dev/sdc: 500.1 GB, 500107862016 bytes
255 heads, 63 sectors/track, 60801 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0xe7b1e7b1
  Device Boot      Start         End      Blocks   Id  System
/dev/sdc1               1         497     3986640   83  Linux
Partition 1 does not end on cylinder boundary.
/dev/sdc2             497        5476    39991297+  83  Linux
/dev/sdc3   *        5476       60802   444405760    6  FAT16
WARNING: GPT (GUID Partition Table) detected on '/dev/sdd'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sdf: 120.0 GB, 120034123776 bytes
255 heads, 63 sectors/track, 14593 cylinders
Disk identifier: 0x502ac21c
/dev/sdf1   *           1       14593   117217248+   7  HPFS/NTFS
/dev/sdf4   *           1           1           0    0  Empty
Partition 4 does not end on cylinder boundary.
Kan ikke dere si hva jeg skal skrive her
Siden jeg ikke forst[r dette
Endret av LMH1
Siden jeg ikke forstår dette
Først må man finne ut av hva som egentlig er galt, og så hvordan fikse det. For å kunne fikse det så må man finne ut av nødvendig informasjon for å få det riktig igjen, det er bare du som har tilgang på denne informasjonen siden du sitter på pc'en ;) Andre kan kun fortelle deg hvordan du kan hjelp de hjelp deg.
Ved å sjekke innholdet i de forskjellige mappene som blir mountet i /media så bør du kjenne igjen mappe strukturen/innholdet og dermed hvilken harddisk som er hva.
For meg ser den grub fila helt grei ut, men jeg har ikke nødvendigvis nok kompetanse til å oppdage alle mulig feil ;)
Grub ser ut til å være installert på hd0,1 så jeg vil tro det skal være nok å skrive inn dette på i grub prompten
root (hd0,1)
setup (hd0)
quit
root (hd0,1)
setup (hd0)
quit
Nå startet jeg vanlig"BASH grub commando linjen uten live CD"
Grub>
root (hd0,1)
(hd0,1): Filesystem is ext2.
Grub>
setup (hd0)
error: unknown commando 'setup'.
Prøvd her med forskjellige hd1 uten resultat.
help commandoen ser ut å fungere på den ene maskinen.
Men er for rask til å kunne se eller bevege meg opp\ned
Endret av LMH1
