Slette ting fra SE T610
Ok, lest litt om "13sec trick" nå... Virker jo ganske greit da...
Noen her som har prøvd det? Funker det fett? Opplevd noen negative bivirkninger over lengre perioder? Dette er vel ikke noe man mister garantien eller noe på?
Er veldig glad i t610'en min, vil ikke risikere å fuc*e opp...
EDIT: Fjerner master reset også "predefined items"?
Tror ikke 13 sec tricket funker så bra på t610. Les igjennom hele tråden, så ser du at han ene hadde visse klager etc. Jeg gidder ikke gjøre det hvertfall, holder å slette alt det andre. Har BT adapter, så minne på mobben er min minste bekymring.
Works on T300 (tested myself) And is claimed to work on the t68i dont quote me on anyother fones and dont hold me responsible if it goes wrong.
The following may be dangerous for your phone im not sure, this technique work extremely well for me and allowed me approx 625kb of free space compared to the 275kb i had before. It removes the following features: Network customisations (for example on my phone it had a T-Zone icon instead of the normal wap icon and T mobile start up and shut down logos instead of sony ericson ones.) it also removes preinstalled themes and images and sounds which also take up a lot of space, but deleting them normally either doesnt free up space or takes too much time or just isnt possible. Heres how todo.
1) goto settings -> master reset -> reset all, it will then ask you to enter your security code. as you finish entering the code count 12 - 13 seconds (12.5 secs exact) for best effects.
2) when you get to 12 - 13 seconds remove the battery quickly and then wait 30 seconds.
It is important the battery is removed on 13.
When i tried this at first went to 13 seconds but it didnt remove the tmobile icons and one of the tmobile logos, however on a 2nd attemt i accidentally removed at approx 10seconds which removed all the tmobile stuff and all themes everything there was more free space.
3) replace battery and allow for reboot, may take upto 60seconds this time
warning i dont kno if you can damage your phone doing this i suspect it may be possible to prevent the firmware from reloading if the is a bootsector which is not installed because the battery is removed to soon, this is a concern i had but im not sure how the T300 is built so i cant be sure if that idea is correct maybe someone else might kno
dan walmsley"
there you go :woot::yes:
Oooooooooook, i dag tidlig når jeg våkna bestemte jeg meg for å ta en master reset på t610'en min, virka som det funker like bra som 13 sek trikset.
Alt forsvant utenom standard bilder, noen få ringetoner og 3 spill...
Satt igjen med rundt 1986 KB free space på telefonen og et eller annet med 200 KB i bruk tror jeg, virker som om 13 sek trikset er unødvendig.
Uansett, må nesten kjøpe meg en liten bluetooth sak fra komplett og få overført litt småting som themes og bilder :)
Noen som har noen råd om hvilke USB bluetooth devices som funker bra?
EDIT: Noen som veit hvordan man får tilbake ting slik den var da du kjøpte den med alle spill, bilder, ringetoner osv?
Eller må man bare laste opp alt på nytt via bluetooth?
Må også skaffe meg en BT adapter..litt stress og overføre fra t610 til s45 så til pcen og samma stresset tilbake igjen.. :lol:
Så tror jeg satser på en MSI sak, billig.. :yes:
denne
Kan ikke sånn postoppkrav pakker ligge på posten i 2 uker?
