Amd Eller Pentium pc, Hva Mener Dere ?
PC med Pentium Prosessor
-DVD-ROM 16X / 48X ATAPI Internal Bulk WO / SW, SD-616F/EB.................................................341
-CD-RW 52X / 24X / 52X ATAPI Internal Bulk, SW-252BE .....................................................415,-
-Floppy Disk Drive 1.44MB 3.5" Internal, SFD-321B ....................................................135,-
-Harddisk 120.0GB IDE 7200RPM UDMA-100 3.5" 8MB, WD1200JB .............................................1011,-
-Case Midi ATX Tower Black 360W W / Door Scorpio, TX-10B-D P .............................................763,-
-Monitor 17" TCO95 DynaFlat-X 1280x1024 @ 70KHz 0.25DP Silver / Black, Q770S .............................1395,-
-Fan Case 80x80x25mm 12V Sleeve Bearing, TF8-25IM-74 ......................................................74,-
-Fan Case 80x80x25mm 12V Sleeve Bearing, TF8-25IM-74 .....................................................74,-
-Mainboard S-478 Intel 875P ATX Audio GbLAN IEEE1394 Raid SATA 800MHz Retail, MS-6758/875P NEO-FIS2R .....1879,-
-CPU Intel Pentium 4 mPGA-478 2.4GHz 800MHz 512kB Boxed, BX80532PG2400D .................................1891,-
-Memory 512MB PC-400 DDR PC3200 Orginal, 512MB PC-400 ......................................................1073,-
- Skjermkort (Ca 1500)
Totalt kr : 9051 + Et skjermkort
Pc Med Amd Prosessor
-Monitor 17" TCO95 DynaFlat-X 1280x1024 @ 70KHz 0.25DP Silver / Black, Q770S...............................1395,-
-Mainboard Socket-A VIA KT400 ATX Audio LAN IEEE1394 Raid Bluetooth SATA, KT4 ULTRA-BFISR...................1420,-
-CPU Athlon XP 2700 2.17GHz Socket A 0.13u 333MHz Tray "Thoroughbred", ADUAXDA2700DKV3D.....................1339,-
-Memory 512MB PC-400 DDR PC3200 Orginal, 512MB PC-400........................................................1073,-
-SjermKort (ca 1500)
Totalt Kr: 8013 + Et skjermkort :):):):)
skulle vært postet under hovedkort, Prosessor og minne :grumpy:
Aller helst under "Hjelp, jeg skal ha ny PC".
Men, burde vel heller prøve å hjelpe deg, enn å påpeke at det er feil kategori.
Jeg personlig synes begge disse oppsettene ser veldig greie ut, og vet ikke helt hva jeg ville valgt. Har hatt AMD i mine siste PCer, mest fordi da får man mer kraft for pengene (komme egentlig an på hva man bruker PC'n til, På noe er Intel en god del bedre, på andre ting er AMD best, og AMD er hvertfall mye billigere).
Men nettopp siden jeg så lenge har hatt AMD, og siden Intel nå har lansert gode CPUer med 800MHz fsb har jeg fått opp interessen for Intel litt.
Begge CPUene du har satt opp er hvertfall kraftige saker, som neppe blir noe flaskehals på en god stund, om det er spill du skal bruke PCen til
