Medion 18'' lcd fra Elkjøp
  • 5 uker senere...
Fant noen spesifikasjoner til slutt. Det er riktignok en stund siden nå, men jeg tenkte kanskje at andre kunne dra nytte av informasjonen. Dette gjelder altså en 18" LCD-skjerm fra Elkjøp. De selger den for 4000,- men jeg måtte slite for å finne en butikk som hadde den inne. Jeg er godt fornøyd med skjermen. Ingen pixelfeil og jevnt over gode spesifikasjoner (bra nok til å se film på den, men noget mer tvilsom i forhold til spill).
(følgende er hentet fra en tysk diskusjonsside og kjørt gjennom Babelfish.)
The following technical data:
MEDION MD 7218 - 18.1"TFT display new commodity OVP, unused, price recommendation of the manufacturer 649, - EUR characteristics: integrated stereo loudspeaker design: 18,1 '' TFT asset SXGA LCD Color monitor with 16,7 million colors, TCO ' 99 picture diagonal: 18,1"recommended dissolution: 1280 x 1024 switching times: 30 ms (type.) Point of view: horizontal: 160°, vertically: 160° brightness: 250 cd/m² (type.) Contrast: 350: 1 (type.) Adjustment possibilities: On screen display scope of supply: Equipment, mains connection cable, 15 of poliges Sub D lead, audio cable
Is that now an good deal or not? Serious interest in a "larger" TFT has...
I acquired the display with material - it was within 10 minutes after shop opening sells off.
The processing is tidy, no pixel errors and sturdy foot. The response time (30 ms) is sufficient, in order to regard without streaks TV and DVD. In all other respects the display behaves simply like one it expected - it represents each dissolution to 1280x1024 automatically (or with pressure on dei "Auto" key) full-laminar and good. The large point of view is e.g. with watching television a large advantage, because with this dimension of picture area one must hold distance - during the low dissolution of a television picture.
Result: Very good display, which one can buy also with MediaMarkt as L1811S von LG LG-Electronic for EUR 599, - instead of as Medion for 399, -...
