John Carmack: "Rage runs faster on xbox 360 than ps3"
Daniel33
The Xbox 360 and PC versions of id's Rage sport higher framerates than the PlayStation 3 version, the latest issue of Edge magazine reveals.
In a ten-page reveal in its latest issue, Edge writes that the Xbox 360 version of Rage - which uses id's new Tech 5 engine - matches the 60fps framerate of the PC version, while PS3 runs at just "20-30fps".
It's not mentioned whether the PS3 framerate will be addressed by the game's eventual release.
"The PS3 lags a little bit behind in terms of getting the performance out of it," John Carmack told Edge. "The rasteriser is just a little bit slower - no two ways about that.
"The RSX is slower than what we have in the 360. The CPU is about the same, but the 360 makes it easier to split things off, and that's what a lot of the work has been, splitting it all into jobs on the PS3," he said.
http://computerandvideogames.com/article.php?id=220530
Likevel tror folk fortsatt at PS3 er så mye kraftigere enn 360. Ganske utrolig. Folk tror de har mer peiling på programmering enn verdens beste.
Gjest
