Ny Xbox på markedet allerede høsten 2010?
LucarioX
Desverre var jeg en av dem som ble helt frelst av Natal, mulig Wii virus jeg har fått i meg :p
Og Wanden til PS3 ble jeg helt sjokkert over!! Og Sony viste den "wanden" on stage, MS hadde vist den i opptak altså ikke i real time :)!! Ble helt sjokka av dem 2!!
enda mer:
WORLD EXCLUSIVE FIRST DETAILS ON MICROSOFT'S NEXT XBOX
06/13/09 1UP recently posted a new article revealing details on Microsoft's plans for their next XBox, we can officially confirm the information found in that particular report was indeed correct. However today FGNOnline would like to reveal Microsoft's planned specifications of their new unit.
As mentioned in the 1UP piece the system shall indeed integrate the motion sensing technology Natal into the actual device, however our separate sources can now reveal the modest upgrade made to the actual architecture of the new system.
GPU
Whereas the original XBox 360 used a Shader Model 3 GPU with on-board 10MB eDRAM for 720p acceleration, the new XBox has a Shader Model 5 capable GPU with 32MB of eDRAM for 1080p output. The GPU again is designed by AMD and runs at a clock rate of 600MHz.
CPU
The IBM developed CPU shall have 6 cores instead of the 3 found in the original model.
Each single core shall have the same processing throughput as each single core from the XCPU. Meaning the chip is literally 200% as strong and shall now be on equal footing with the PS3 CELL CPU in GFLOPS performance.
MEMORY
The main system RAM has been upgraded from 512MB to 1024MB, and from GDDR3 to GDDR5.
The system retains a Unified Memory Architecture.
OTHER
The platform integrates a 2.5" 32GB SSD (Solid State Drive) instead of a HDD (Hard Disk Drive) as found in the original models. The system also uses a standard DVD drive foregoing Blu-ray thus ensuring backwards and forwards compatibility whilst simultaneously keeping the bill of materials low. Internet connectivity is provided via WiFi.
RELEASE & PRICING
Microsoft plans on a Q4 2010 simultaneous worldwide release. The company is targeting a sub $300 price point.
Zach Morris
I call BS, but what do i know?
Tror nokk at viss MS hadde planer om å lage en oppgradert xbox så hadde vi sett noe omm det på E3. Dessuten var det jo ikke så veldig lenge siden vi så en artikkel hvor det stod at MS ikke vill gi ut en ny Xbox før 2015. Tror mer på det en mange av disse andre ryktene.
Wii bruker flash-minne, 512MB. Men det er mer med plass å gjøre enn varme. Og flash kommer mest trolig ikke til neste generasjons maskiner. Det er ikke økonomisk i forhold til størrelse. Neste generasjon får nok disker på 200GB + Da er 2.5" disker mest fornuftig med tanke på størrelse/pris.
