Diskusjon rundt Pokémon Platina
Pokey
fannt en guide på gamefaqs til deg: http://www.gamefaqs.com/portable/ds/file/946308/54062
trykk ctrl+f og skriv inn 0303 så kommer du ned til elite 4.
et lite tips fra guiden:
The following list is a general idea of what you should have on your team
while fighting the elite four:
* Giratina at level 55 or so
* Your starter at level 53 or so
* A fire Pokemon at level 54 or so
* A water Pokemon or a Pokemon that knows surf at level 55 or so
* Any Pokemon that has Ice Beam, Flamethrower, Surf, Shadow Ball, Crunch
or various other high level moves at level 55 or so
