Feilmelding #1?? HJELP
Sitter og pusler med data'n og plutselig dukker det opp en blå skjerm hvor det står: :evil:
*** STOP: 0x0000000A (0x488B1441, 0x00000002, 0x00000000, 0x8046571E)
*** Address 8046571E base at 80400000, DATESTAMP 384d9b17 -ntuskrnl.exe
Beginning dump of physical memory :o
:evil:
Dette skjer selv om jeg ikke driver med noe spesielt hardt for maskina, og den låser seg helt.....
Noen som har noen formening om hva dette er???? :shrug:
HJELP HJELP HJELP
A Stop 0x0A Error After Windows XP Is Already Installed
If you receive the Stop 0x0A error after Windows XP is already installed, use the following troubleshooting procedures to check other components.
Check Third-Party Software or Drivers
If you have installed any third-party software or drivers, try removing them or disabling them so that they do not load, and then restart the computer to see whether that software or driver is causing the error. If that software or driver is causing the error, report the problem to the vendor of the software or driver.
Med andre ord : Driverfeil
