Hvordan legger man musikk på HDD fra CD?
Rip a CD to your Xbox 360 Hard Drive
The process of copying digital content from a CD to a hard disk drive is also known as "ripping." You must have an Xbox 360 Hard Drive attached to your Xbox console to rip music from a CD to the console.
To rip music from a CD to an Xbox 360 Hard Drive, follow these steps: Start the Xbox 360 console without a disc in the disc tray.
Put a music CD in the disc tray, and then close the disc tray.
Note The Music Player starts automatically.
Select Rip CD. By default, all the tracks on the CD are selected. If you do not want to copy all the tracks, manually select the tracks that you want to rip.
Select Rip CD to complete the process.
Kilde.
Tror du kanskje må brenne den som Music CD for at det skal fungere.
Kan bekrefte at det er slik det fungerer. For å rippe musikk til Xboxen's harddisk må du brenne ut som en Audio CD.
Edit: Da er det rart det ikke fungerer. Xboxen spiller av all musikken?
Endret av Laland
