Hva skjuler seg bak din CTRL+V?
Hvilke typer informasjon får du på disse sidene?
Hvordan reklameres det for produktene?
Hvilke tjenester tilbyr nettsidene deg?
Hvordan navigerer du fra side til side?
Hvor mange tastetrykk må du bruke å finne den informasjonen du er på jakt etter?
Har media..!
DUDE, found a way 10x easier than this, they give you enough boxes to stack up like stairs to the second level and the shield doesnt cover it, so, make stairs to the 2nd floor closest to the health & power, launch the turrets upstairs (only 1 is really necessary..just make sure to activate them all) then climb up and theres an office with bullet proof glass, set up ur turret in the middle of the hall, stand in that room, pick off whatever opposition makes it as far as your front door. The end.
