Ring of light, hvordan bytte farge?
gtr86
Gjest Bruker-127711
Well in the actual Xbox you have to open up the main frame of the xbox then you have to hack it pretty much by buying a light off ebay or something like that, but this is bad because then you can get the red rings of death and since you opened it up and changed the light they wont give you a new one, for the controller you have to buy a special screw driver, which costs like a 1$ on ebay its called a T8 screw driver, just look it up real cheap good fun but then you have to buy the light which is also bought on ebay very coool colors though
Endret av Bruker-127711
Jeg vet ikke men regner med at det er 8 forsjellige LED perer på konsollen 4 grønne og 4 røde så biss du skifter de grønne blir de vanelig lysene grønne (dah) men viss du skifter de røde da vil du ikke få red ring of death da vill du få blue ring of death eller orange ring of death.
