Battlefield: Bad Company 2.
Spesifikk info om updaten:
Precise changelog from R7 and R10.
AEK-971:
Damage is 14.3 at all ranges
XM8:
Range increased to 18 - 64m
F2000:
Damage is 12.5 at all ranges
AUG:
AN94:
Long range damage increase to 16.7
M416:
M16A2:
ALL SMGs:
Range universally now at 18 - 42m
9A91:
Long range damage increased to 14.3
ALL LMGs:
Spread Recovery when Sighted is 5.0 per second, Minimum Hip spread increased to 2.5 and 4.0
PKM:
Long Damage decreased to 12.5, Spread Per Shot (Spray) when sighted increased to 0.5
SAW:
Spread Per Shot increased to 0.44
T88:
Close Damage increase to 16.7, Spread Per Shot increased to 0.5 (T88 and PKM are now essentially identical in power)
M60:
Damage decreased to 20 - 16.7, Spray increased to 0.6
XM8:
Close Damage decreased to 14.3, Spray increased to 0.43
MG36:
Spray increased to 0.43 (MG36 and XM8 are now essentially identical in power)
MG3:
0.0 Spread when sighted, Spray increased to 0.35
Bolt Action rifles:
Long range damage changed to 50, range adjusted to 10 - 36m
T88:
Range changed to 8 - 64, long damage changed to 25
SVU:
Range changed to 18 - 64, long damage changed to 28
VSS:
Nuttin'
M9:
Damage increased to 25 - 16.7, range changed to 12 - 42m
MP443:
Range changed to 12 - 42
1911:
Rate of fire decreased to 260 RPM
REX:
Long Damage increased to 33.4
M93r:
Damage greatly increased to 12.5 - 9.1
Thompson:
Range changed to 18 - 42m
G3:
Damage decreased to 20 - 19.5
Garand and M14:
Long Damage increased to 28
Buckshot:
Damage increased to 12.5 - 6.0, Range changed to 8 - 18m
Slug Pump Action:
Range changed to 10 - 36m
Slug Automatic:
Range changed to 8 - 64m
USAS:
Long Damage decreased to 28
Underbarrel Shotgun:
Damage decreased to 14.3, damage drops to 8.0, Range of 8 - 18m
40mm and Carl Gustav:
Lethal blast radius approximately 66% of original radius
Tracer Dart:
Speed increased to 300 (from 75)
Vehicle Reload Spec:
0.85x effect on reloading
Medic Heal Rate Spec:
15 health Per second
Marksman Accuracy Spec:
0.75x spread decrease
Motion Mine:
Stock of 3, Ammo Box replenish of 1.5 seconds
Mortar Strike:
60 second reload
BMD-3:
Takes 1.0x damage to front
ZU-23 Anti-Air:
Damage increased to 25 at all ranges
Gjest Bruker-127711
Får fortsatt ikke spilt noen steder jeg.. :cry:
Har du prøvd å starte spillet gjennom bf2update?
Funket for meg.
Woo det funka! :D
Jepps, det har vært en god patch egentlig. Lurer på en ting da, hvor mange her er det som foretrekker hardcore?
Jeg syns det er artig å spille på hardcore. Null 3Dspotting og høy dødelighet :D
"Hard core" er en vits i mine øyner. Kun folk som suger ellers, og kun liker å campe med reacon for å få one hit kill. "noob core" spør du meg.
Endret av Magnus.
Jeg har ikke den følelsen egentlig, kan hende det har noe med at jeg er veldig offensiv.
For eksempel kan jeg Spawne løper til frontlinjen og gjennom noen busker headshotter en som spurter over en plass, løper videre bak en stein, skyter ned en sniper og kniver en eller annen som løper forbi før jeg hopper gjennom vinduet på et hus/shack og eventuelt blir flanka av noen.
Campe er jo dødskjedelig (samtidig som at du bare dør av andre campere), spesielt i rush. Det heter jo rush, RUSH MANN, rush!
Som sagt er jeg veldig i action hele tiden så jeg legger kanskje ikke merke til det. ^_^ En sniper får liksom ikke skutt meg når jeg konstant løper fram og tilbake mellom busker og sprengte tankser, ikke er det 3d spot heller, så de kan ikke lokalisere meg når jeg løper bak noe.
Lol, ser at pizzaen du spiser falt ned på tastaturet og forsøker å bestille en idiotpai.
Synes det er moro å spille både HC og vanlig men dette er jo selvsagt avhengig av hva slags spillere du kommer på lag med eller spiller mot. Uansett modus så suger det balle å være på et lag hvor alle gjemmer seg under en busk i påvente av at noen skal løpe inni crosshairen. Hva du synes er fullstendig irrelevant når du avskriver alle som liker HC som folk som suger ellers. Donk.
Må si jeg foretrekker HC, har vel egentlig ikke en forklaring hvorfor det er sånn.
Men merker det er mest aktivitet på normalserverne til Battlefield.no og TV2, så det blir oftest de uansett. HC spiller jeg på randomsservers når jeg spiller sammen med kompiser.
Er jeg lysten på å spille recon eller mye assault spiller jeg HC mode. Engineer og medic syntes jeg fungerer bedre for meg i normal mode, spesielt medic'en da jeg ofte må midt ut i ildlinjen for å hjelpe teammates og da dør man grassalt mye på hardcore. :)
Takk for øvrig til gal_ape for en heftig runde ikveld!. Litt CG morro må til :whistle:
Endret av Keylar
Så det at man må være raskere med aim, får ikke hjelp fra kartet, tåler mye mindre og ikke har HUD er noob?
Tror ikke det er flere sniper-campere på hardcore enn vanlig for og si det sånn. Men du har kanskje noen kilder og vise til? Eller så er det bare en antagelse fra din side, siden du ble eid den ene gangen du testet HC :whistle:
What he said, only for conquest. ;)
Det er en grunn til at jeg ofte har LW-pack, for å si det slik.
